Will it explode?
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Will it explode?
    Suppose this PSU, whose label says '19A max on +5V':
    But that as a matter of fact comes with one 30A rectifier on +5V, of this model:
    Then suppose I use it to power an old Athlon XP system without 'P4' connector on the mobo, meaning the CPU draws all its juice from +5V (as opposed to from +12V like modern stuff).
    Thus total system draw is something like say 25A from +5V, 5A from +12V, and 5A from +3.3V.
    Will that PSU cope with, or will it bust?
  • Stefan Payne
    • 1267
    Re: Will it explode?
    Isn't that a rather cheapishly CWT plattform?
    Besides, some math:
    5*19= 95W
    minor rails combined = 130W.
    Something wrong here is...
    Because 3V3 is often generated out of the +5V rail, so it should be at least 130/5 = 26A
    But then again, the rail distribution can be specified by rolling the dice...
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      is the one behind it in parallel?
      • TELVM
        • Oct 2012
        • 547
        • Spain
        Yep, CWT GPA.
        The small pic with two rectifiers in parallel is from another PSU and just to show the type of rectifier.
        This PSU has only one PFR30V45CT rectifier on +5V.
        • TELVM
          • Oct 2012
          • 547
          • Spain
          OK so (just to be sure) where does exactly this '130w max +3.3V & +5V combined rating' come from?
          This PSU has one 30A rectifier on +3.3V (30A * 3.3V = 99W) and one 30A rectifier on +5V (30A * 5V = 150W).
          99W +150W = 249W
          So it's not from the rectifiers.
            You can put in 50A rectifier but it does not mean you will get 50A out if the transformer and the drive circuit are not designed to put out 50A. You always use higher rating component than what you need.
            '130w max +3.3V & +5V combined rating' come from? That sure is confusing.
            • TELVM
              • Oct 2012
              • 547
              • Spain
              I meant to ask what exactly phisycally limits the combined +3.3V & +5V output to 130W.
              So it is the transformer and the drive circuit, and they'll blow if I ask say 140W from +3.3/+5V combined on this particular PSU? Even though +12V draw is very little, say just 24W/2A?
              Just to be sure.
                The drive circuit will have protection circuit that will detect the over current draw (also will have over Voltage protection) by the load so if the protection circuit is well designed it should stop the circuit before something blow up badly.
                The confusion is on that 130W label. I think they are trying to indicate that for example, if you are using 100W on the 5V then you can get 30W from the 3.3V.
                If you look at the +12V1, +12V2 rating, it shows 408W 34A MAX so you cannot draw 24A from +12V1 and 21A from 12V2 at the same time, you have to derate one or the other with combined 34A MAX.. That is the way I see it. Do they details info at the web site?
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  Just to be sure.
                  The combined rating suggests that +3.3V and +5V are taken from the same transformer tap unless +5V and +3.3V are stepped down from +12V through a buck DC-DC converter. So the combined limit is representative of the maximum current that particular transformer winding can handle or the buck regulator in any case, whichever method the PSU uses to get +5V and +3.3V. In some older PSUs, they use a cheap design that linear regulates +3.3V from +5V (very inefficient but results in an exceptionally clean output).
                  The maximum current on each output is determined by a number of things - the size of the toroid, the number of turns, the core material it uses (-52 or -26, etc), the width of the PCB traces, the transformer taps, how many layers the PCB is made of, the current rating of the rectifiers, the rating of the output MOSFETs used for DC-DC conversion, etc. Are you asking if the rectifiers would explode or if the main switchers would explode? The output rectifiers could potentially short if you exceed the current rating for too long or if you exceed the peak repetitive reverse voltage. Depending on the topology as well, a half wave rectified output (forward topology) will result in a lower current limit for the rectifiers than a full wave rectified output (half bridge), since in a half wave rectified output, one of the diodes has to be used in a double diode pack to discharge the output inductor (and complete the current path). But that can all change depending on how well the PSU is ventilated and cooled. Of course, this might work a bit differently if the whole power supply uses synchronous rectification instead.
                  The two +12V rails are usually split through shunts after the output capacitors, so the +12V rail is basically split into two. This means that the limit for both +12V rails is given by the rectifier(s) themselves, but as stated before will depend on some other factors as well.
                  • TELVM
                    • Oct 2012
                    • 547
                    • Spain
                    ^ Thanks. Guts pic of PSU in cuestion, looks like +3.3 & +5V come from same transformer tap:
                    Originally posted by Wester547
                    ... Are you asking if the rectifiers would explode or if the main switchers would explode? ...
                    Basically I'm testing the waters about the dangers of using modern PSUs, designed with large +12V loads and little +5V loads in mind, to power old comps of the Athlon Classic/XP pre- 'P4 connector' era, which draw relatively heavily from +5V and little from +12V.
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      main issue is regulation is done on 12v rail so a heavy load on 5v rail causes 5v rail to dip low.
                      My pc
                      CPU : AMD PHENOM II x4 @ 3.5Ghz
                      MB : ASUS M4A89TD PRO USB3
                      RAM : Kingston ValueRAM 16gb DDR3
                      PSU : Cooler Master 850W Silent Pro
                      GPU : ATI Radeon HD 6850
                      • TELVM
                        • Oct 2012
                        • 547
                        • Spain
                        ^ Yep, old-style +5V-heavy crossloading would be a problem with group-regulated PSUs like the CX430:
                        But not with modern PSUs which use DC-DC conversion for +5V & +3.3V, like the Seasonic G-550:
                        ^ In these the main transformer only generates +12V, then buck converters step down the minor rails directly from +12V.
                        I wonder if these PSUs with DC-DC generated minor rails would be perhaps more tolerant of a (moderate) overload on the +5V rail?
                        • Stefan Payne
                          • 1267
                          Well, depends on the buck converters.
                          Some do, others don't...
                          Some just switch off, others burn.
                          But what I don't understand with those DC-DC units is the minor rail combined voltage.
                          Why do they do that?
                          • Behemot
                            • 4845
                            • CZ
                            I would not use S12G or G series units, they are not really that good. Corsair RMx or RMi is completely different league.
                            I also have the feeling all these series will be EOL'd very soon as Seasonic is launching new ones, hopefully much better.
                            • Stefan Payne
                              • 1267
                              Overall build quality on those Corsair units is really bad, sometimes there is threadlocker on the screws for the modular PCB, sometimes there is not. They are semi fanless (the S12G is not), use just a rifle bearing fan...
                              And last but not least:
                              They use those stupid and almost dangerous PCIe-Y Cables with 2 8pin connectors per 8pin connector (8+6 pin would be barely OK by the way).
                              Just because the voltage regulation is a bit better and riple and noise is a bit better doesn't really mean that the unit overall is better at all...
                              Oh and those Corsair units also have a whole lot of solid caps on the modular PCB as well...
                              Well, yeah, they are a couple of years old, so one would think that seasonic did a completely new plattform in the same (price) range...
                                master hoarder
                                • May 2008
                                • 12175
                                http://i.imgbox.com/Wv9DSMPr.png
                                http://i.imgbox.com/H5ZR0wwv.png
                                Ignoring the possibility of severe cross-loading, the PSU will more than likely be fine with that load on the 5V rail. That 30 A rectifier should allow you to pull up to 20-22 Amps on the 5V rail (but not 30 Amps, because this PSU uses a forward-converter topology, after all)
                                Realistically speaking, however, with that heavy 5V load, the voltage on the 12V rail might get out of spec (too high). So be prepared for that and don't attach your most valuable HDDs.
                                Newer group-regulated PSUs that are made for 12V-based PCs usually have an extra turn or two for the 12V rail in the main transformer in order to keep the 12V rail high even when it is under load with a light or no load on the 5V rail. Conversely, older group-regulated PSUs made for 5V-based PCs are the other way around, so with a heavy 3.3V/5V load, the 12V rail is normal.
                                Not exactly.
                                This PSU has a forward-converter topology. That means the 30 Amp rectifier on the 5V rail will NOT be able to supply 30 Amps of current, unlike in a full or half-bridge topology (or any other topology that has a center-tapped output on the main transformer).
                                The 19 Amps rating was probably given for what this PSU can do without having the 12V rail go sky-high due to cross-loading.
                                That said, 19 Amps x 5 Volts = 95 Watts, indeed as you stated. There were very few 5V-based systems back in the day that could exceed this limit. You would probably need a Pentium 4 motherboard that draws power from the 5V rail (i.e. one that doesn't have a 4-pin 12V CPU connector) and a "high-end" Pentium 4 Willamate or Northwood CPU. Or a high-TDP Athlon XP combined with a Radeon 9800 Pro/XT.
                                ** Transformer tap wire thickness for the 5V rail.
                                ** output inductor wire thickness for 5V rail
                                ** size of filtering caps on the 3.3V and 5V outputs
                                ** the maximum power the PSU can supply from the 5V tap before the 12V rail goes too high.
                                *edit*
                                Don't know why I wrote all of that above . Wester547's explanations in post #9 are spot-on.
                                https://www.badcaps.net/forum/showpo...59&postcount=9
                                • TELVM
                                  • Oct 2012
                                  • 547
                                  • Spain
                                  Thanks Momaka.
                                  Originally posted by momaka
                                  ... older group-regulated PSUs made for 5V-based PCs are the other way around, so with a heavy 3.3V/5V load, the 12V rail is normal.
                                  Yep the best option would be to get a decent old-style PSU with plenty of amps on +5V, then recap and recondition it.
                                  But I'm thinking about people that like keeping retrocomps alive, but can't recap and will never tinker inside a PSU. Old PSUs with OEM aged dubious caps inside (like those Fuhjyyu-loaded old Antecs ) aren't a reliable option for them.
                                  So if you had to power an ancient +5V·heavy Athlon Classic/XP system, and you had to choose from amongst brand new current (2016) PSUs, which ones do you think would tend to give less headaches for this application?
                                  Perhaps something in the style of the Seasonic S12II 520W (group-regulated, 24A on +5V, 130W combined +5V/+3.3V)?
                                  Or perhaps a DC-DC regulated one like the recently released Corsair CX650M (25A on +5V) to prevent crossloading problems?
                                  • Stefan Payne
                                    • 1267
                                    Thanks Momoka!
                                    Puuh, that's hard...
                                    Because you should have around 20Amps on the +5V rail. And very little 'normal group regulated' units have that...
                                    So that leaves the DC-DC things.
                                    But they are rather expansive...
                                    Is there any other choice but to get either an older PSU and recap it or get a PSU with DC-DC?
                                    But there are also other options I'd take a look at...
                                    Like cooler master G-Series, InWin GreenMe, Xilence Performance A+ and probably some others too.
                                    But if you want higher currents on +5V, you'll run into problems with the price...
                                    The be quiet Straight Power E10 with 500W or more seems like a decent choice for older systems with 24A on +5V and +3,3V.
                                    But the price is rather on the high side...
                                    • dmill89
                                      • Dec 2011
                                      • 2534
                                      ^This, and if you don't want to recap, older workstation/server grade PSUs which often have Japanese caps can be had pretty cheap (even NOS units), just about anything that only has a 20-pin ATX connector sells for next to nothing these days (since any remotely modern system needs a 24 pin).
                                      If you have to have new go with a DC-DC converter PSU that drives all the minor rails off the 12V so cross-loading isn't an issue.
                                      • gc4e7t2u
                                        • Apr 2017
                                        • SK
                                        I bought RM550X which isn't connected yet before reading this thread.
                                        Is it safe to use it in PC with 65W non-overclocked CPU and integrated GPU which means peak load won't exceed 80W?
                                        • vanminhscdt@gmail.com
                                          Lenovo Legion Y7000P IRX9 LA-N211P REV: 1A, IC Explode
                                          by vanminhscdt@gmail.com
                                          Hey guys
                                          I got a Lenovo Legion Y7000P IRX9 with no fan power.
                                          Found a shorted line, IC explode.
                                          No boardview or schematics available, but i'm unable to identify it to be able to replace.
                                          ​Can someone assist ? ...
                                          12-25-2024, 11:21 PM
                                        • spleenharvester
                                          Good power bank shells for 18650 cells?
                                          by spleenharvester
                                          I did a cell salvage run on some Dyson batteries to build out a new fleet of Milwaukee batteries and the yield was a lot higher than expected, so I now have a lot of extra Sony VTC4s that are in reasonably good health. I'd like to build them into power banks, there's a glut of shells for 18650s on AliExpress but I don't know which are any good (read: won't explode). Can anyone recommend some (especially the ones that just fit a single cell)? Weld or weldless are fine, I have a spot welder
                                          I suppose USB-PD and/or quick charge would be desirable too
                                          Cheers
                                          05-11-2025, 01:47 PM
                                        • bryanX
                                          Control board for treadmill Horizon Omega II
                                          by bryanX
                                          Hi guys!
                                          Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
                                          I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...
                                          03-05-2024, 01:11 PM
                                        • seppde
                                          Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                          by seppde
                                          I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                          ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                          The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                          In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                          02-09-2024, 05:19 AM
                                        • Eotis
                                          Framework 13 laptop ,Nvram locked ,TPM issue
                                          by Eotis
                                          Hi folks. I have a Framework 13 laptop with these specs.
                                          Motherboard: Framework FRANBMCPOC AC
                                          Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
                                          Graphics: Intel Iris xe
                                          Installed RAM: 64.0 GB (63.8 GB usable)
                                          System type: 64-bit operating system, x64-based processor
                                          Bios: Uefi InsydeH20 3.24
                                          Edition: Windows 11 Pro/ AtlasOS
                                          Version: 23H2
                                          Installed: ‎9/‎16/‎2024
                                          OS build: 22631.4169
                                          Intel Chipset driver: 10.1.19502.8391
                                          This processor seems to...
                                          11-18-2025, 08:55 PM
