Framework 13 laptop ,Nvram locked ,TPM issue
  • Eotis
    • Nov 2025
    • United Stated of America
    • light gaming
    Hi folks. I have a Framework 13 laptop with these specs.
    Motherboard: Framework FRANBMCPOC AC
    Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
    Graphics: Intel Iris xe
    Installed RAM: 64.0 GB (63.8 GB usable)
    System type: 64-bit operating system, x64-based processor
    Bios: Uefi InsydeH20 3.24
    Edition: Windows 11 Pro/ AtlasOS
    Version: 23H2
    Installed: ‎9/‎16/‎2024
    OS build: 22631.4169
    Intel Chipset driver: 10.1.19502.8391
    This processor seems to have difficulty in staying cool. (90-100 celcius under load and sometimes while idle) I normally do not use this laptop often because after I bought it and noticed it running hot frequently and the fan comes on super loud, I have been disappointed and decided not to use it heavily.
    Recently, I stumbled onto an idea. I have a uefi bios called Insydeh20. At the time my bios was version 3.19. I thought maybe if I updated my bios and drivers that maybe it would help the overheating. So I tried updating to version 3.20 and still my cpu was generating a significant amount of heat. Same as before the update. Then I updated the bios to 3.22 with no change. Now I am currently on bios update 3.24 and it still runs as hot as ever.
    Something else strange is that I can be in game playing Skyrim (that's how I test it) and open up a screen that shows my current cpu and gpu utilization. Cpu utilization is always 10% or less but gpu is always maxed out at 100% unless the game is paused.
    So, not only did I update the bios and by the way, this bios seems very limited in options that you can set. Even though it has an advanced tab, the advanced tab isn't very deep. I also downloaded and installed the latest drivers bundle from framework:
    I am not posting this because I need help with my system heat. I just wanted to give you more details as to what led me to this issue. Apparently, once you update your bios to version 3.22 there is no return. You cannot downgrade. Well there was another unwanted side effect. Before I updated the bios, as far as I knew, I did not have a TPM or if I did, it was not active. After my bios updates, one of them (I'm guessing 3.22) activated the TPM.
    Also, through some research I now believe this particular laptop already has the TPM built into the chipset. I believe it is called Intel PTT. I suppose it was dormant until I updated the bios. As I understand it, windows 11 is not supposed to even install on your pc without tpm but maybe because I am running a custom windows, the ptt never activated but now that I've updated the bios, the ptt seems to be active.
    By the way, I strongly dislike the TPM and the whole idea of a trusted platform module. One detail I forgot to mention is that my laptop has a dual boot configuration. I have win 11 and LMDE 6. I have had issues in the past where my windows would update and during the update, windows would delete my linux from the boot menu. Well, this time I wasn't even updating windows. I was just updating my bios and somehow it acivated that stupid tpm and that tpm decided that having a linux os on my system and boot menu is untrustworthy.
    Well I brought out my trusty LMDE 6 usb live boot and booted from it and opened up the boot repair program. Boot repair fails because it says the nvram is locked. I've never even heard of nvram but I suspected it has something to do with the tpm. I have been researching tpm chips in an attempt to try to disable it and so far the best I have been able to come up with is to disable tpm ownership. At least I think I disabled ownership in an attempt to get the current password and then change it to a password that I will know.
    Also when I type in tpm.msc and open up the tpm console, the action list is very limited, The only 2 options it has is clear tpm and prepare tpm but prepare tpm is greyed out and cannot be used. Many of the options I have seen on the web to try to accomplish a task in the tpm console are not listed in mine.
    Really, all I want to do is take control of the tpm and disable it, shut it down or turn it off in whatever way possible. I do not want a tpm nor do I need nor appreciate it's existence in my hardware and software environment. Actually would it be possible, even though framework says you cannot downgrade your bios, is there any way to downgrade my bios? I found a tutorial online to reset the mainboard. I followed the tutorial and the bios did not revert back to stock.
    Any help and advice will be most welcome and greatly appreciated.
  • yellowtiger
    Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
    by yellowtiger
    Hello Everyone,
    I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
    Here are my laptop details:
    - Model: Lenovo Slim 7i 14IMH9
    - Serial Number: YX09M0K7
    - Machine type: 83D80003US
    **Problem:**
    About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
    Yesterday, 11:04 AM
  • sarovic
    Dell G15 5511 bios locked, tried everything
    by sarovic
    Dell G15 5511
    ST: dkjp5r3
    Service code: 29540580447
    It has an i7 11800h and rtx3060
    Tried all the hacks, tutorials and apps. Currently I don't have an bios programmer tool to flash it or smth...
    Can't extract bios file to fix with "dellbiostools"
    Can someone help, or explain to me what to do? Got the laptop for school, now that I need to install Linux, Bios is locked and starts to bother me...
    Thanks in advance, my first time posting on badcaps, and the site is awsome!
    Can't even update bios and that messes with my battery... Bios...
    12-02-2025, 05:11 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • ilkor
    BIOS Request: Lenovo ThinkCentre M73 Tiny (IS8XM Rev 1.1) - Error 0162 Boot Loop
    by ilkor
    I need help repairing/fixing my corrupted BIOS dump for a Lenovo ThinkCentre M73 Tiny.
    Motherboard Details:
    • Model: IS8XM Rev 1.1
    • Lenovo FRU: 03T7239
    How the problem happened:
    The motherboard was working perfectly before. The issue started after a failed BIOS update that was interrupted by Windows Security settings. After the interruption, the PC was still able to boot into Windows but I could not enter the BIOS setup at all.
    To fix this, I performed the Hardware Boot Block Recovery procedure using the motherboard jumper (Clear/Recovery pin 2-3) and a FAT32...
    05-25-2026, 08:20 AM
  • yellowtiger
    Lenovo Slim 7i (Model 14IMH9) - Failed BIOS Update and Stuck in Boot Loop
    by yellowtiger
    Hello Everyone,
    I'm writing to ask for help on my Lenovo Slim 7i laptop. The model number is 14IMH9 and the machine type is 83D80003US. About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop shuts off and reboots automatically after ~1 minute then repeats the whole process again until I forcefully shut it down by long pressing the power button.
    I have sent the...
    06-13-2026, 11:44 AM
