Control board for treadmill Horizon Omega II
  • bryanX
    • Nov 2013
    • 12
    Hi guys!
    Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
    I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water dropped accidentally on the board.
    Now to my issue: Can someone help me identify the mosfet? Is destructed exactly on the markings, what i can read is only IRFP3...after can be `0`´ but thats it. The ZD1 was melted to the board, making the markings not to be identifiable anymore. I will attach some pictures, and i hope that someone can help me.
    Thank you for your time and help!
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Hello. In Atemi treadmill mosfet-IRFP460
    • lotas
      • Jan 2016
      • 4708
      • Russia
      Here they write that this is IRFP250.
      https://forum.allaboutcircuits.com/t...1/#post-301923
      • bryanX
        • Nov 2013
        • 12
        Hello guys!
        Thank you for the reply. That is a very useful information.I will try to figure it out what value has this zener diode.
        • bryanX
          • Nov 2013
          • 12
          Hi guys,
          I have replaced the mosfet with IRFP460 and the other damaged components on the board. Since the ZD1 has no markings on it, I have used one 5,6 V. After i have powered up the board, with all the cables attached, the display was powered up and accepting all the settings, but as soon as I started the motor, the mosfet was shorted again. No sparks or fuses were blown away. The motor is already cleaned and tested. It can be that, the mosfet is not the correct one for this current/ controlling? Just as I previously mentioned, the blown one was IRFP3xxx.
          Can someone tell me if I have used the wrong ZD value, or mosfet?
          Thanks in advance for helping me!
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
            Linear Garage Door Opener Control board took a crap install a new control board back normal
            I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
            02-08-2025, 06:52 AM
