Recapping of Corsair VS450
    replied
    Re: Recapping of Corsair VS450
    Originally posted by Behemot
    LXV, LXY, LXZ, KZE are utterly obsolete. KY are just obsolete.
    So?
    Sure they might be a bit bigger than the newer series, but if they fit and work, the rest doesn't matter. Online stores like Mouser and Digikey (and possibly a few other places as well) still have them too last time I checked.
    Don't give me that "newer is always better" Micro$haft attitude now.
    In the meantime, you guys can stay in last decade for couple more months
    I don't mind. My 10+ year old PSUs are still working
    Originally posted by goodpsusearch
    They look it up on datasheets. Esr / C meters offer you the ability to see if a capacitor has failed or started to fail, because when that starts to happen most of the times its esr and capacitance will be clearly out of specs.
    Exactly.
    When a cap starts failing, usually the ESR will increase many times the normal. 10x to 100x rise in ESR is not uncommon, especially for low quality brands. Most circuits will usually tolerate quite a bit of ESR rise as well before something catastrophic happens.
    Momaka you rule!
    Yes. Now bow to me, my little minions. Bow!
  • Behemot
    replied
    Originally posted by momaka
    Chemicon KYB (preferably), KY, or KZE
    Chemicon KYA, LXV, LXY, and LXZ
    You still live in 2000's.
    KYA, KYB, KZN, KZM, KZH are the new and worthy series. Rubycon has some new and interesting series as well, but I won't market them till I got them on stock. In the meantime, you guys can stay in last decade for couple more months
  • goodpsusearch
    replied
  • omega
    replied
    just as a curiosity: how can you be so accurate with ESR values? I read from you that you can guess milliohm! My dear Blue ESRmeter does not go beyond centiohm :-(
  • goodpsusearch
    replied
    Momaka you rule!
    replied
    Originally posted by Stefan Payne
    I wouldn't use KY as replacement for the new CapXon GF.
    The Impedance of a 2200uF/16V CapXon GF is about 0.022.
    KY is about 0.043 Ohms, wich would be a great replacement for the KF series.
    Have a look again.
    KY @ 16V 2200 uF (12.5 x 25 mm can) has 27 mOhms ESR and 2230 mA RC. I would say that is reasonably close to the CapXon GF specs for the same 16V 2200 uF size.
    I should also say I made my recommendation based on the 6.3V 2200 uF CapXon GF and not the 16V version. If you read post #3 again, according to omega, his PSU only has CapXon KF on the 12V rail. Every other CapXon is GF series.
    So for the 6.3V 2200 uF CapXon GF, specs are 37 mOhms ESR and 1720 mA ripple for the 10 x 25 mm can.
    Chemicon KY with same capacity and voltage rating: 42 mOhms ESR and 1650 mA of ripple. That's reasonably close. But, if you re-read my post, you will see that I put "preferably" next to the KYB series, which have 37 mOhms and 1650 mA of ripple current for the same cap - an almost spot-on replacement for that particular CapXon GF cap.
    Don't have datasheet for the others. But if my mind isn't wrong, the Panasonic FR and FM aren't the best choice due to rather high impedance.
    No, FR and FM have even lower ESR than KZE. About the same class as KZH and KZM, which is more or less between motherboard grade and PSU grade.
    replied
    FR esr for 2200/16 is 0.018ohms
    FK is 0.025
  • Stefan Payne
    replied
    For CapXon GF:
    Nichicon HE (preferably) or HD,
    Panasonic FK (preferably), FR, or FM
    Rubycon ZLJ (preferably), ZL, or YXG
    [/quote]
    KZH and KZE would be fine though...
    But I have to look those values up.
    replied
    Originally posted by omega
    While I am not 100% confident of the respective rails...
    If you want us to confirm, it is best to put pictures both of the top side and solder side of the PSU. For the top side, do not zoom in too much. A picture like the one TELVM uploaded in post #11 is good.
    My purpose is to replace every cap with the IDENTICAL ones but of good quality (and low ESR in the secondary zone), any suggestion?
    For CapXon GF:
    For the rest, you can use the capacitor series in the above list as well as these:
    Nichicon PW, PS, PM, PJ, and PV
    Panasonic FC
    Rubycon YXJ
    1. is the capacitance of the filter big cap high enough (180uF), or should I consider (if it is possible) to increase it?
    It's probably big enough for 300 Watts or so. Shouldn't be a problem with just about any basic computer that doesn't have a power-hungry video card.
    That said, the bulk cap in your PSU is non-Japanese brand, and non-Japanese brands do seem to fail more often on PSUs with APFC (usually, it takes some time, though). So if you are replacing it, you might as well get a cap with slightly bigger capacity. 220 to 330 uF would be more than enough.
    Of course, those big caps are usually expensive (relative to the cost of other caps for the PSU). So I'll leave that decision up to you here. Chances are, that PSU will last at least several years with the bulk cap that's in there right now.
    2. how is it possible to put together caps of different voltages besides different capacitances as I saw in some rails of this PSU?
    The voltage rating of the capacitor just needs to be higher than the voltage on the rail that it is going to filter. (Typically, 25% higher or more is an okay margin, and 50% is a very safe margin.) So for the 3.3V and 5V rails, it is possible to use 6.3V, 10V, and 16V caps. For the 12V rail, however, you must use at least a 16V -rated capacitor. 25V will work too.
    Difficult to read the value of this cap, even with a knife blade as a mirror. I will be confident once I desolder.
    Indeed it can be sometimes.
    The easiest thing to do is to number each cap and make a "cap-map" as you remove them one-by-one. You can do that digitally (on the computer with Paint, Photoshop, etc.) or by hand on paper. Or, as you remove each cap, note down its specs (voltage, capacitance, brand, etc.) and then see which designator number on the board (i.e. C15, C20, Cxx, etc.) it corresponded to, then write down the info on paper.
    That way, you won't get lost when all of the caps are removed.
  • goodpsusearch
    replied
    An exception.
  • TELVM
    replied
    1110uF of primary caps for 1000W of APFC PSU: http://www.jonnyguru.com/modules.php...tory5&reid=459
  • goodpsusearch
    replied
    APFC boosts voltage
    Q=C*V
    So, if the V is higher you get away using lower C primary caps.
    Of course this cap is on the low side. But there is no need to follow rule of thumb that says:
    total primary C = Psu max W
    This only apllies to NO PFC or Passive PFC units
    330uF is more than enough. He should pay attention that the Voltage is 420V or 450V
  • TELVM
    replied
    Originally posted by mariushm
    ... the inrush current could kill the fuse in your power supply or in your house's panel, or the bridge rectifier in extreme cases ...
    Agreed, but the VS450 comes OEM with a NTC thermistor to limit inrush current:
    ...A lot of capacitance won't make much of a difference in day-to-day use of the power supply. Above a certain value it doesn't matter ...
    "... Problem is with those (primary) caps being so small, the transistors have to work in overdrive to put more current through the transformer to keep the output stable. They usually don't manage it so you see 600~1000mVp-p of ripple on the output in a 100Hz sawtooth wave. See this picture from a "430W" PSU with 350W load. It used 680uF primaries, predicting 340W max output... and the ripple is already through the roof:"
    https://www.badcaps.net/forum/showpo...&postcount=445
  • mariushm
    replied
    One good reason... the inrush current could kill the fuse in your power supply or in your house's panel, or the bridge rectifier in extreme cases.
    A power supply with such a low input capacitor won't have anything to limit the current flowing into the capacitor so you'll see probably 20-30A pulled for a few milliseconds.
    Going from 150uF to 330uF won't make much of a difference but way higher values could do bad.
    A lot of capacitance won't make much of a difference in day-to-day use of the power supply. Above a certain value it doesn't matter.
    You'd only want to increase the primary capacitance if you want the power supply to respect the atx standards, as in have enough capacitance to stay on if there's no mains power for one AC cycle, which would be 1000ms / 50 Hz = 20ms if I remember correctly at full load.
    But I think it's rare that you'd have such drops in the mains power and you won't use your power supply at full load... chances are if the mains power is unreliable, it will be unreliable for more than just one ac cycle.
  • TELVM
    replied
    I wouldn't increase the primary capacitors C too much ...
    Why not?
  • goodpsusearch
    replied
    Originally posted by TELVM
    180uF for a 450W PSU is on the low side of capacitance (bulk caps are relatively expensive, the VS450 is a budget PSU, and they've penny-pinched on this), but it isn't mission critical.
    If you're in the mood and there's room for a larger bulk cap, a 330~470uF of higher 420~450V voltage rating wouldn't harm (though I'd better invest first on improving the secondary caps).
    For +3.3V you may see from 6.3V to 10V or 16V caps (and combinations of them).
    For +5V, from 10V to 16V caps.
    For +12V and -12V, from 16V to 25V caps.
    For +5VSB output filtering, from 10V to 16V.
    Within reason, the higher the voltage rating, the less stressed the cap will be and the longer it will last.
    I wouldn't increase the primary capacitors C too much. 330uF should be more than enough.
    6.3V caps are good for 5V too if you have space issues
  • TELVM
    replied
  • omega
    replied
    Are you sure the -12V has 1x Capxon 2200uF, 16V??? Isn't it 220uF?
    Thanks for your support!
  • mariushm
    replied
    Chemicon KZE or KY, Nichicon HW , Panasonic FM or FR will work great.
    I wouldn't use Panasonic FC simply because there's better capacitors out there for about the same price.
    Don't go with ultra low esr, don't go with too high esr... get something close to the Capxon's esr but don't stress yourself too much, the design of the power supply is not that great to require such "special" capacitors.
    As for -12v, what you use there doesn't matter much .. 220-470uF, anything will work. It's only used for serial communication nowadays (if your motherboard has the header and connector) and pretty much any device will accept voltages in the range of -13v .. -10v , they won't care about accurate voltage on -12v.
  • goodpsusearch
    replied
    Nice. Definitely worth recapping.
    The caps are just low esr. You can use Rubycon YXG, Panasonic FC, FK, Nichicon HE, Chemicon KY etc.
    Isn't it 220uF?
  • h0m3w0rk
    Random Shutdowns/Startup Failure with Corsair SFX 450
    by h0m3w0rk
    I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
    For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
    02-09-2025, 03:19 AM
  • RukyCon
    ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
    by RukyCon
    Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
    So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
    04-15-2022, 11:20 PM
  • thanibee
    Troubleshooting Corsair VS450
    by thanibee
    Need schematics for this power supply. PSON input is supposed to be pulled up to 5v. Getting only 1.82V
    Thanks for any help
    12-07-2020, 07:36 AM
    Corsair CX750M [Model 75-002019] - burned output toroid inductor
    by momaka
    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
    09-19-2021, 08:44 PM
  • hobostove
    Corsair RM1000e - Help identify 5VSB Zener diode
    by hobostove
    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
    There's a 22ohm resistor that's melted and open, but it still has the bands.
    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
    It looks like the diode connects the source and drain of a TNY284...
    03-27-2025, 02:25 PM
