Water droplets sign of bad cap?
  • mikay786
    • Aug 2014
    • 765
    Just working on another subwoofer and identified some bulging caps on the power supply side of the board but looking at the other board with the inputs noticed some of the caps have little droplets of water / electrolytic on the black glue that surrounds them?
    Is this electrolytic leakage from the caps, and a sign they are bad too?
    • 31246
    Re: Water droplets sign of bad cap?
    is that black shit epoxy, or is it flexable?
    you need to remove it from the board and find why some of those resistors are cooking.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ahhh they are crappy JH aka Just Horrendous. They do look blown out from the bung, remove them and check.
      • mikay786
        • Aug 2014
        • 765
        It's flexible to a degree, but a bitch to remove. Peels off / cracks off. Why the hell do they (monitor audio) cake their boards in it!
        Tested some other JH ones in the psu side and they are toast and some were OK. (They are all JH I think)
        Ordered replacement caps for all of them as am going to recap it anyway, so wil test when I get them removed tommorrow.
        Just first time I've seen liquid droplets.
        • Behemot
          • 4845
          • CZ
          You may already try audio caps when its for sub…
          • mikay786
            • Aug 2014
            • 765
            Panasonic FR series not suitable?
              • 31246
              will be fine.
              • Behemot
                • 4845
                • CZ
                Audio caps are supposed to provide lower signal noise. If they are on the signal trace, it is preferred, if on the power traces, you may use everything.
                And while most people here is crazy about Panasonic, they are one of the most expansive brands. Have a look for new Chemi-Con series (KZM, KZN, KYB). They are often superior.
                  • 31246
                  price depends on country and supplier.
                  • mikay786
                    • Aug 2014
                    • 765
                    A few of them were dead around the droplets. The capacitance was within range but the esr on them was 30 ohm+
                    I had a £5 voucher to use at farnell for leaving a review on trust pilot, so worked out only costing me £5. Only thing with farnell is on some caps they only sell in minimum quantities of 5 or whatever.
                    At first I was like who cares they cost peanuts anyway, but now that i'm using more it adds up quickly, plus I have loads left after completing repair. Ive got two small compartments full of caps now, perhaps a good time to organise them in values so can use in future.
                      • 31246
                      it's good to have some spares on hand.
                      saves time next time you fix something.
                        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                        by sam_sam_sam
                        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                        04-09-2023, 08:04 PM
                      • Ugur87
                        MacBook Air M4 A3240 Brand New Water Damage no Image
                        by Ugur87
                        I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                        08-28-2025, 01:09 PM
                      • edugimeno
                        Stagg sms12p audio amp has water damage
                        by edugimeno
                        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                        There is only one signal wire connecting the first boards...
                        05-24-2025, 06:00 AM
                      • RetroComputingGrotto
                        Water Damaged Toshiba 48L1435DB
                        by RetroComputingGrotto
                        I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                        The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                        10-07-2024, 08:23 AM
                      • x_orange90_x
                        Samsung UN65AU8000FF fried by water
                        by x_orange90_x
                        I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                        10-16-2025, 08:40 PM
