Water droplets sign of bad cap?
  • mikay786
    • Aug 2014
    • 765
    Just working on another subwoofer and identified some bulging caps on the power supply side of the board but looking at the other board with the inputs noticed some of the caps have little droplets of water / electrolytic on the black glue that surrounds them?
    Is this electrolytic leakage from the caps, and a sign they are bad too?
    • 31047
    Re: Water droplets sign of bad cap?
    is that black shit epoxy, or is it flexable?
    you need to remove it from the board and find why some of those resistors are cooking.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ahhh they are crappy JH aka Just Horrendous. They do look blown out from the bung, remove them and check.
      • mikay786
        • Aug 2014
        • 765
        It's flexible to a degree, but a bitch to remove. Peels off / cracks off. Why the hell do they (monitor audio) cake their boards in it!
        Tested some other JH ones in the psu side and they are toast and some were OK. (They are all JH I think)
        Ordered replacement caps for all of them as am going to recap it anyway, so wil test when I get them removed tommorrow.
        Just first time I've seen liquid droplets.
        • Behemot
          • 4845
          • CZ
          You may already try audio caps when its for sub…
          • mikay786
            • Aug 2014
            • 765
            Panasonic FR series not suitable?
              • 31047
              will be fine.
              • Behemot
                • 4845
                • CZ
                Audio caps are supposed to provide lower signal noise. If they are on the signal trace, it is preferred, if on the power traces, you may use everything.
                And while most people here is crazy about Panasonic, they are one of the most expansive brands. Have a look for new Chemi-Con series (KZM, KZN, KYB). They are often superior.
                  • 31047
                  price depends on country and supplier.
                  • mikay786
                    • Aug 2014
                    • 765
                    A few of them were dead around the droplets. The capacitance was within range but the esr on them was 30 ohm+
                    I had a £5 voucher to use at farnell for leaving a review on trust pilot, so worked out only costing me £5. Only thing with farnell is on some caps they only sell in minimum quantities of 5 or whatever.
                    At first I was like who cares they cost peanuts anyway, but now that i'm using more it adds up quickly, plus I have loads left after completing repair. Ive got two small compartments full of caps now, perhaps a good time to organise them in values so can use in future.
                      • 31047
                      it's good to have some spares on hand.
                      saves time next time you fix something.
                        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                        by sam_sam_sam
                        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                        04-09-2023, 08:04 PM
                      • edugimeno
                        Stagg sms12p audio amp has water damage
                        by edugimeno
                        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                        There is only one signal wire connecting the first boards...
                        05-24-2025, 06:00 AM
                      • RetroComputingGrotto
                        Water Damaged Toshiba 48L1435DB
                        by RetroComputingGrotto
                        I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                        The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                        10-07-2024, 08:23 AM
                      • rzsn
                        water damaged G513I
                        by rzsn
                        Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                        Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                        12-22-2024, 09:02 PM
                      • abajor
                        A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                        by abajor
                        Like title says A2141 came in with Water Damage, customer desperately wants the data.
                        The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                        I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                        That said after cleaning up the...
                        12-21-2024, 07:16 PM
