Hantol worst AC Adapter ever!
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Let's start with the case/label:
    https://www.badcaps.net/forum/attach...1&d=1447624309
    According to the label it is a multiple voltage adapter, however I wasn't able to find the plastic screw that serves as a voltage selector... I found a pdf online that claims that the psu changes output voltage according to the DC output pin that you attach. Well, this does not work well, because with the DELL/HP pin attached my multimeter shows 23.5V!
    The thing is thin as air. No way it can output 90W.
    Cracking it open was too easy. I could do it with my bare hands! Cheap and thin plastics bended when pressed with just 1 finger!
    https://www.badcaps.net/forum/attach...1&d=1447625016
    Oh no! Who stole the parts? Well, they were not installed in the first place! Who needs extra parts? It works without them anyway
    Input filtering:
    https://www.badcaps.net/forum/attach...1&d=1447625101
    No need for that! Be grateful that they installed a fuse and they spent time and money to cover it with heat-shrink tubing.
    The AC socket ground pin goes to nowhere! LOL this is terrible!
    Secondary: https://www.badcaps.net/forum/attach...1&d=1447625346
    Output filtering is there! Let's drink on that And it consists of a core-less coil and 2x "KW" 1000uF 25V "LOW ESR" caps. One cap is slightly bulged, but don't worry about that, we've got the other!
    Let's take a look on the soldering side:
    https://www.badcaps.net/forum/attach...1&d=1447625712
    https://www.badcaps.net/forum/attach...1&d=1447625920
    Looks worse than in the pics... It has turned black from heat. And it smells burnt too. This side has no plastic or aluminum cover, so it comes in direct contact with the external case of the psu. If you look carefully you will see the burn marks:
    https://www.badcaps.net/forum/attach...1&d=1447626031
    Secondary soldering:
    https://www.badcaps.net/forum/attach...1&d=1447626096
    Heat discoloration present here too.
    And finally the "smart" voltage selector DC Pin:
    https://www.badcaps.net/forum/attach...1&d=1447626258
    I let the adaptor on AC, with no load connected on its DC output. Next morning I touched it and surprisingly it was quite warm! This means terrible standby efficiency...
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hantol worst AC Adapter ever!
    Ohh dear what a pile of trash Thanks for the thread
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      already losing an output cap.
      we see those crummy things come in all the time.customers often buy these to attempt to fix the laptop themselves.i tell folks to return it.and grab a good used original out of my stash.this often gets it running.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        waaa what a crappy ac adaptor indeed! i think not even everell will wanna save that sheet from the landfill... in fact, it deserves to go into the landfill and be long forgotten.
        then maybe centuries later, when aliens discover and visit our ruins on earth, these alien archaeologists will unearth that sheety ac adaptor and discover that in the year 2015, humans made these terrible ac adaptors which caused the eventual downfall of their civilization. man being looked down by imaginery aliens sucks!
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Well, I don't know... It might actually do 90W for a minute but with terrible efficiency and ripple.
          Before you say I've lost my mind just take a look at its silicon:
          KBP307 3A bridge rectifier
          CS8N60F N-Channel MOSFET
          Continuous Drain Current : 8A
          Pulsed Drain Current: 32A
          MBR20100CT 20A Schottky Rectifier
          3843B Current Mode PWM Controller
          and LM358 Dual-Operational Amplifier. This should be for the automatic output voltage selection.
          Not so bad. Do you think I could rebuild it and turn it into something semi decent?
            • 31066
            not in the original casing.
            in theory a bigger heatsink and better / any airflow.
            combined wih better output filtering and it could be good.
            • robert
              • Jan 2008
              • 69
              I highly doubt the transformer fulfills any safety requirements. Approved TIW is very expensive and there is no space for necessary creepage distances with this core shape, so they will just have used normal magnet wire and no clearances whatsoever.
              Combined with the fact it doesnt have any grounding (ie. Class II device) it IS dangerous. No way this will withstand the 3kV AC inslation testing needed for a class II device.
              Also, no EMI filtering at all. Throw it away, right now.
                • 31066
                you arent supposed to PAT test switching psu's - only the cables.
                • ddscentral
                  • Mar 2008
                  • 151
                  • Lithuania, EU
                  Remember the Hantol PSU with fake PFC...
                  https://www.badcaps.net/forum/showthread.php?t=37611
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Before:
                    https://www.badcaps.net/forum/attach...1&d=1454202906
                    After:
                    The adapter suffered some serious overheat on the underside.
                    I though this might help:
                    • Behemot
                      • 4845
                      • CZ
                      Also add the ground reference to the secondary.
                      BTW I've tried some chinese adapters too. Last time some 60W +12V ones for about 5 bucks on discount. The voltage dropped to just slightly above 11 V at 3 A already, at 3.5 A it started heavil oscillating and then turning off and on again. Also weights nothing, I'll try to crack it open later.
                      After that, I think I give up search for something usefull from chinese. if I wanted to make it into something good with the manufacturer, with all the changes, import costs etc. it would cost almsot as a quality one and it will still be no-name chinese…
                      So I started looking after some decent PSUs in Europe. Got some adepts already…
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Seems like I missed seeing this thread... :\
                        Wow, what a piece of turd, that adapter.
                        You can see the primary heatsink extending all the way to the secondary without any insulation on it whatsoever. Similarly, secondary heatsink extends onto primary with very little insulation. And I would be very surprised if that blue-dipped cap next to the transformer between primary and secondary is a safety-approved Y2-class cap.
                        It's all good, though, because:
                        Which means you can connect any part of the secondary side to primary side AC or either primary cap positive or negative side, and nothing will blow . Just the user might get some "tingly" sensations if he/she so happens to touch the output
                        Oh, and only then the adapter might go
                        That is some pretty sad filtering. Might be enough for 2 to 2.5 Amps, but not more. (Provided this adapter can even go that far)
                        Yes, you can tell the PCB has gotten a little toasty a few times.
                        Would be fun to check the input and output power going into thing. To get "quite warm", that means it must be burning at least 3 to 5 watts of power doing nothing. Compare that to about 1 to 2 Watts of power momentarily once every 2 to 3 seconds for a genuine Delta Electronics 65 Watt power adapter from an HP laptop.
                        I doubt that transformer will let you do that. But do try - I think it would be fun to see how far it goes.
                        If you move the guts out of the case and attach some bigger heatsinks, possibly. It may still only be able to put out 40-60 Watts max, though.
                        Looks like it's mostly from the transformer and the snubber network on the primary side. Possibly some of the other SMD resistors too. In fact, I wouldn't be surprised if the snubber is way undersized.
                        Good job with the modding though.
                        Since there IS a "Y2" capacitor between primary and secondary, I would also suggest you connect the grounding wire on the input plug to secondary ground.
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          These things, with questionable insulation and unbonded secondaries, are shock hazards. Untrimmed leads, glue/crap on the PCB, or failed transformer insulation will place line voltage on the negative output lead and the laptop's chassis.
                          If this happens with a bond to the EGC, you get a blown fuse or tripped GFCI.
                          There were external HDD supplies, w/o the bond/EGC, that liked to backfeed line voltage up the USB cable to the computer (the only return path present), or "give tingles" when not connected to a computer.
                          Without that bond, you just get a larger version of those fake apple chargers- those were good for shocks in 240V line-to-gnd countries. Touch a radiator while holding your charging iphone and surprise! Or worse w/o GFCI/RCD...
                          "pokemon go... to hell!"
                          EOL it...
                          All style and no substance.
                          guilty,guilty,guilty,guilty!
                          guilty of being cheap-made!
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Wow that thing is wimpy. And fake Ltec? I mean, come on...
                            • Behemot
                              • 4845
                              • CZ
                              Better tripped protection but being grounded than not being grounded and getting shocks IMO
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                that explains it. i had a wd power brick for an elements external drive. everytime i connected the usb cable to the computer, i would see a spark. dunno wtf was wrong with it... until now... i disposed of the drive and adaptor in a second hand forum anyway after rma-ing the drive. also no wonder the drive failed! i dont imagine a hard drive likes being connected directly to the ac line!
                                besides killing the drive, i think it also temporarily corrupted the bios chip and temporarily dmged the southbridge too. the board suffered from esd related symptoms and refused to power on. it behaved exactly like it was an asus p4c800 when u try to plug stuff in or out without shutting down and unplugging the power cord. i had to do the remove cmos battery, hold the power button down trick to get it to start up again. had to reflash the bios as it would keep refusing to start after a shutdown. after reflashing the bios, the board was fully working again! yay!
                                i dont mind getting shocked but killing my mobos while leaving me still alive is strictly forbidden territory!
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                  by sam_sam_sam
                                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                  I bought this from an eBay seller but unfortunately they only had one
                                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                  I bought three of from them to also make battery packs with this output power limit in mind
                                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                  04-23-2025, 05:50 AM
                                  Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                  by momaka
                                  Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                  So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                  09-19-2021, 08:44 PM
                                • CoppellTVRepair
                                  Troubleshooting PFC with SPC1012T not raising output
                                  by CoppellTVRepair
                                  It has been a long while since I posted here to ask anything....hope you can help.
                                  I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                  I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                  03-09-2025, 10:38 PM
                                • flibidy
                                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                  by flibidy
                                  I have here a Magnum IA.100 which belongs to my parents.
                                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                  What Ive done........
                                  01-01-2025, 01:26 PM
