20 to 24-pin PSU Converters, anyone using them?
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Recently bought this from a local store here in Cebu. I was just wondering if there are any problems using this thing.
    original position:
    http://img180.*************/img180/2764/dsci0816cb3.jpg
    picture in reverse:
    http://img509.*************/img509/3047/dsci0817ry8.jpg
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • shadow
    • Feb 2007
    • 732
    Re: 20 to 24-pin PSU Converters, anyone using them?
    I would not think there are any problems with these converters. The only real issue that I can think of is that with this converter is keeping the ATX cable nice and tidy in the case. I am talking about keeping good airflow by keeping cables neat and hiding them away in corners and unused areas of the case so that the air can circulate better. This may be difficult with the converter since effectively the cable is longer than usual.
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      The only problem I can think of is if you have an older ATX PSU that doesn't put out much amperage on the 12v rail, with most on the 5v. Most of the newer systems power the CPU from the 12v rail, so you might be overloading an older unit.
      A man convinced against his will is of the same opinion still.
      • Galvanized
        • Mar 2006
        • 468
        As long as there is enough wattage for the system and no clearence issues(like a coil or capacitor in the way) a 20 may be used on a 24 pin board or a 24 may be plugged into a 20 pin board without any adapter. The extra 4 pins will just hang off the end of the port.
        • brianl703
          • Dec 2007
          • 8
          What about those motherboards that have the extra "ATX12V" 4-pin power connector? (which consists of two ground wires and two 12V wires)
          Can you power those with a supply that doesn't have the ATX12V connector?
          I've got a lot of ATX power supplies that do not have the ATX12V connector. I think they make adapters to convert a disk drive power connector to ATX12V for the motherboard, do these work?
          • grss1982
            • Mar 2007
            • 225
            • Philippines
            I have an Enermax 431W DUal Fan PSU. Using the converter its only going to be powering this system:
            ECS RS400-A
            Intel Pentium 4 3.0Ghz HT
            2 x 512MB PC533
            Nvidia 6600 LE
            IDE HDD
            • tvtech
              • Oct 2006
              • 48
              Yes they do make those adapters and they do work,you just have to make sure that your psu can handle the extra 12v load.And yes you must use the atx 12v connector because that powers the cpu vrm.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                The ATX12V connector is connected through the board to the 12v on the 20/24 pin anyway.
                The only reason for it is to use more wires to get the 12v to the board.
                By using more wires they can pass more amps without overloading the wires.
                They could do the same thing using larger wires but larger wires are harder to twist around to plug things in.
                Most PSU's use AWG 18 gauge wire.
                18 gauge wire is rated for something like 6 amps per wire.
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  >> The ATX12V connector is connected through the board to the 12v on the 20/24 pin anyway. <<
                  May not be true on all boards. Has been on any I bothered to check.
                  - Dr Seuss
                    Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                    Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                    I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                    09-13-2024, 06:47 AM
                  • FALKLAN
                    Running Line Voltage and Integrating LED Pods - Automotive
                    by FALKLAN
                    Howdy everyone! I hope all is well where ever you are!
                    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                    02-05-2025, 12:30 AM
                  • Dannyx
                    Idea for protecting DC-DC converters on laptop boards ?
                    by Dannyx
                    Good day folks. So I've been struggling with laptop motherboards for a while now. Most of my repair attempts so far have failed one way or another, mostly due to a lack of tools rather than human error, but they did help me gain more and more experience and build up skill in the long run. This idea came from one of my failed attempts which you can read all about HERE.
                    To sum up, this Acer laptop had a dead MOSFET on one of its standby power rails (page 48 of the manual in the original post). The controller chip PU5 responsible for that rail was also shot. I replaced the chip but apparently...
                    02-18-2020, 12:32 PM
                  • Uranium-235
                    LVDS side converters. Also, Q about LED power pull
                    by Uranium-235
                    I'm about to put an original LG gaming screen from a ROG gamers dead laptop, into an i3 acer. Both 17.3". Would the higher quality and brighter screen pull more from the LVDS LED power circuits or do they all have a standard power requirement?
                    I found a video from laptopscreen.com about using a converter ribbon cable to get the plug to the other side as, well, it is on the other side. Is this a good idea? Even a generic screen here is ~$50-70
                    08-11-2019, 10:16 PM
                  • broke_boi
                    Asrock B450 Pro4 motherboard won't power on.
                    by broke_boi
                    Hello all,
                    (I am just getting into electronics repair so excuse the noobness )
                    I have an Asrock B450 Pro 4 motherboard which doesn't power on. I have access to the Broadview file.
                    I have checked that the PSU is working. I have the 5V standby on pin 9 and the 5V PSON# on pin 16. When I short the pin 16 and the ground I see the fan running and other voltages as well.
                    I have removed everything from the motherboard except the CPU fan and have only connected the 24pin power from the PSU. I have not connected the 12V power from the PSU...
                    09-09-2023, 09:21 PM
