LVDS side converters. Also, Q about LED power pull
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    I'm about to put an original LG gaming screen from a ROG gamers dead laptop, into an i3 acer. Both 17.3". Would the higher quality and brighter screen pull more from the LVDS LED power circuits or do they all have a standard power requirement?
    I found a video from laptopscreen.com about using a converter ribbon cable to get the plug to the other side as, well, it is on the other side. Is this a good idea? Even a generic screen here is ~$50-70
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LVDS side converters. Also, Q about LED power pull
    Go ahead as long as the screen is supported. Power requirement is more or less same of an led screen.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • flibidy
      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
      by flibidy
      I have here a Magnum IA.100 which belongs to my parents.
      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
      What Ive done........
      01-01-2025, 01:26 PM
    • ashyt16
      Toshiba TV bad panel half screen dark - pull tabs or not?
      by ashyt16
      Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
      The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
      Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
      I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
      10-26-2020, 05:47 AM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
