PSU Woes - Need Help!
  • Darky8
    • Jul 2013
    • 40
    Hi Folks! I hope you can help me.
    I'm not new to electrical work, but I am new to electronics. I seem to have reached the end of my somewhat limited knowledge with this PSU.
    It's from a Panasonic WJ-HD316A Digital Recorder, which popped a few surface mounted fusible resistors (R101, R123) and a couple on another board. After replacing these fuses, the PSU now just cycles and as the protection circuit kicks in.
    If I remove R101, the cycling stops and if I replace R101 but take away L101 it's also OK. So what ever it is within the IC101 area.
    As far as I can tell all the components are ok (I have a really crap multimeter!), I have replaced SCR101, the capacitors marked 330 are ok (Checked ESR out of circuit), the diodes appear to do what they should etc
    So I'm stuck and somewhat down hearted that I've managed to get this far, and yet have failed to make the thing work.
    Any help would be gratefully received.
    • 31278
    Re: PSU Woes - Need Help!
    see if any of the ceramic capacitors are shorted out.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      The SCRs might be part of some "crowbar" circuit. I wonder if they are protecting (blowing the fuse(s)) the circuits down the line. Maybe one of the large ICs is bad?
      Muh-soggy-knee
        BTW, the original thread is here:
        https://www.badcaps.net/forum/showthread.php?t=45537
        • Darky8
          • Jul 2013
          • 40
          Once replaced, none of the fuses blew again.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Hm? Once what was replaced? The SCRs?
            Muh-soggy-knee
            • Darky8
              • Jul 2013
              • 40
              Thank you for your reply.
              No, when I replaced the fuses. Both on this board were blown and one on another. They never blew again once replaced, it just cycles every second or so making the chirping noise.
              • selldoor
                Slow Learner
                • 7870
                When it is cycling and chirping is it all connected up?
                Have you tested the voltage each side of the fuses and worked across the board testing voltage at the inductors or the input output voltage on the ICs
                Does the volatage vary with the on/off /chirp.
                Can you pinpoint where the chirp is coming from.
                • Darky8
                  • Jul 2013
                  • 40
                  It does it with everything connected up and without anything connected. As long as the far left circuit is connected it freaks out.
                  Going to replace IC101 as I can't find anything else wrong.
                    "It does it with everything connected up and without anything connected. As long as the far left circuit is connected it freaks out."
                    So the left circuit DOES NOT FREAK out when no load connected it? or as you said "It does it with everything connected up and without anything connected"
                    You should try using the resistors dummy load, the loads may have shorted circuits and cause the switching power supply to go into shutdown/re-start mode.
                    the board contain three switching power supplies.
                    https://www.badcaps.net/forum/showpo...90&postcount=8
                    • Darky8
                      • Jul 2013
                      • 40
                      It's the left circuit that freaks it out. Disconnect the left circuit and half the machine runs ok. With nothing connected it's exactly the same, as soon as the left circuit is connected you can hear the PSU restarting.
                      I replaced the left circuit IC and it half ran for the first time with the left circuit connected. However, I think I noticed a small puff of smoke and now it's back to square one. It lasted about 2 mins.
                      I may just junk this PSU and fit it with an old ATX one.
                      Cheers
                      • Darky8
                        • Jul 2013
                        • 40
                        It's all over, it went up in smoke so a complete failure :/
                        However, seeing the machine is PowerPC based it only requires the usual 3.3, 5, 12v. So I plan to use a small ATX PSU instead.
                        So I didn't win this time, hey ho on with the next dead thing!
                        Thanks for your help, I did learn something from all this but I'm not quite sure what.
                        Cheers!
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          You learnt that when the Magic Smoke escapes things stop working? lol
                          • toddw65
                            LN55C650L1FXZA Backlight Woes
                            by toddw65
                            Hi All,
                            I have a Samsung LN55C650L1FXZA with the BN44-00342B PS/Inverter with backlight troubles. It was working intermittently and once on, would stay on, but then once it was warm and was shut off the backlights wouldn't come back on when the set was restarted.
                            Now all it will do is flash for a couple of seconds and then there's a picture/sound but no backlights. Every so often I can power it up with the main board disconnected from the power board and the back lights will stay on, but not every time.
                            With the set powered up I get:
                            18.8v on all...
                            08-02-2024, 01:52 PM
                          • CuriousJohn
                            Bowflex nautilus firmware woes
                            by CuriousJohn
                            Hi Folks i dont post much but i have need today please read on and maybe we can get these things sorted.
                            I am on a health drive and last week bought a Bowflex max M7 to push on with my desire to get fitter but it was bought with a none functional "console screen" though the screen is dead the machine still works fine you can adjust the resistance manually like a bicycle brake adjustment it is cable fed but i want the programs and heart rate/calorie functions for my health drive. A new console is available but im getting quoted £520 or thereabouts and Bowflex as of yet have...
                            06-11-2024, 06:41 AM
                          • chaoshusky
                            Ongoing Acer Predator Triton 300 G53G LA-L191P woes
                            by chaoshusky
                            Well, this is the second laptop of the exact same model and spec to die on me, the first one lasting a month. Fortunately that was returnable, but apparently the seller lied to me about this one and had even had its warranty registered, so very much out of luck there and can't afford to lose £900..
                            Anyway, it had been having issues for a while again with throttling, after fixing it briefly..almost like the heatsink is defective and slowly coming away! Worked great for a while, but started throttling on the GPU and throwing the odd blue screen, even when running in non turbo or...
                            08-22-2023, 01:42 PM
                          • mcplslg123
                            DELL 3521 PS_ID Woes
                            by mcplslg123
                            Modelell Inspiron3521
                            M/B-LA-9104P
                            Problem: PS_ID isfluctuating between 0.9V to 1.8V,Adapter Unknown. Laptop is booting fine with adapter only. Works with battery Only but doesnt charge.
                            Here is what i've observed and done so far.
                            01.Resistance on PJPDC,pin1=134K Ohms
                            02.PR904/900/906/905/902/903-all as per schematics(tested out of circuit)
                            03.PQ901-gate is stable 5V, Source /drain pulsing between 0.9V to 1.8V
                            04.PQ900-Collector is 5V, Base is 0.1V to 0.2V
                            05.Connectivity between SIO,pin16 and PD901,pin1 is intact....
                            06-06-2022, 06:44 AM
                          • syndromo_downs
                            Imfamous M60-C3 woes
                            by syndromo_downs
                            Hey all.
                            I've learned a large bit from this forum. I'm happy to report that after following the troubleshooting methods listed from the veterans on this page, I was able to get this older TV going again. I picked this TV up from FBOOK market for little to nothing. The fella I got it from said the power button does nothing, etc etc. Brought it home, found the power cord included was wrong. Was the rounded on both edges cord, needed the one with the flat spot on one side. Took cover off found fuse on PSU to be blown. Ordered proper fuse and soldered it in. TV would power cycle nonstop....
                            02-18-2021, 07:06 PM
