Hey all.
I've learned a large bit from this forum. I'm happy to report that after following the troubleshooting methods listed from the veterans on this page, I was able to get this older TV going again. I picked this TV up from FBOOK market for little to nothing. The fella I got it from said the power button does nothing, etc etc. Brought it home, found the power cord included was wrong. Was the rounded on both edges cord, needed the one with the flat spot on one side. Took cover off found fuse on PSU to be blown. Ordered proper fuse and soldered it in. TV would power cycle nonstop. Visually inspected PSU and found caps c203/c204 to be bloated. Replaced them with proper rated caps. Still no go. Checked all voltages and and found no return signal for t-con from mainboard to psu. T-con wasn't getting supplied voltage either. Suspect mainboard. Mainboards are about $100 now - found a routine in here to reflow in the oven. Performed that routine and TV now works properly, however there's slight ghosting/flickering regardless of runtime on tv. Happens atleast one-ten times a minute. It is not localized to one section of the screen, it impacts the entire screen for a fraction of a second. Is the ghosting/flickering the result of a faulty mainboard or are there other known reasons ie: bad ribbon cable to t-con, another cap issue on psu, etc? This will most likely turn into a garage TV due to the issue.
Thanks for any suggestions, and thankyou all so much for the information found in this gold-mine of a forum.
