LN55C650L1FXZA Backlight Woes
  • toddw65
    • Jan 2014
    • 108
    Hi All,
    I have a Samsung LN55C650L1FXZA with the BN44-00342B PS/Inverter with backlight troubles. It was working intermittently and once on, would stay on, but then once it was warm and was shut off the backlights wouldn't come back on when the set was restarted.
    Now all it will do is flash for a couple of seconds and then there's a picture/sound but no backlights. Every so often I can power it up with the main board disconnected from the power board and the back lights will stay on, but not every time.
    With the set powered up I get:
    18.8v on all of the 13/18 pins
    12.9v on all 13v pins
    5.6v on all the 5v pins
    Lamp_Det is zero volts
    Sw_Inv: 5.09v
    Pow_Sw: less than 1v
    And on the large caps I'm only getting 162v
    I didn't see any obviously bad parts and I pulled and checked ci818 because I've seen that mentioned as a common failure and it tested fine. I also pulled and checked several electrolytic caps even though they looked fine, but all tested ok.
    Thanks in advance for any assistance.
  • nomoresonys
    • 12328
    • U.S.
    I think this is the is the issue, "Pow_Sw: less than 1v" maybe try hitting power on while monitoring this pin, see if it changes in voltage at all, so power on and power off, see if voltage changes.
    • toddw65
      • Jan 2014
      • 108
      Well, now I can't get the thing to fail. It's firing up properly every time I've tried it over the last couple of days. I did try to monitor that pin and there is a spike but my meter doesn't have the option to capture a peak value and it's too fast for me to tell what it is. Once it settles, it's at ~.88 vdc.
      It's a tv I'd picked up and given my daughter months ago so most likely the problem will reoccur as soon as I get it back together and take it to her. 😆
      If/when the problem surfaces again, I'll come back to this thread.
      Thanks.
      • nomoresonys
        • 12328
        • U.S.
        Well that's good karma, have you guys helped any old ladies across the street lately, lol.
        • toddw65
          • Jan 2014
          • 108
          Only my wife. Just kidding honey! I meant to say your mom! 🤣🤣
          • nomoresonys
            • 12328
            • U.S.
            LOL, that cracked me up.
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
