Ryobi 12v Li-Ion Battery Charger dead
  • sambul83
    • Mar 2015
    • 134
    Hi guys,
    My Ryobi CH120L Li-Ion Battery Charger suddenly died after sitting in the closet for some time without being used. No lights at all, doesn't charge any battery, no voltage btw Battery Charging Terminals. It measures 0.06V btw Battery Control Terminals. The fuse checks OK for continuity. Here's its Manual.
    I suspect its the same Bad Caps saga again, may be more.
    Can you suggest how to pinpoint the failing parts? I don't have any electronic components stocked, so can't try freely which replacement will do.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Ryobi 12v Li-Ion Battery Charger dead
    get rid of the yellowish brown glue.esp on the primary side.see the mess around that 33k resistor? a leak to ground stops your startup.
    • sambul83
      • Mar 2015
      • 134
      Not sure where exactly, can you circle the right places? Also, it was working well like that for 3 years, I never opened it before, then it suddenly doesn't work anymore without being used. As I read, they glue the parts on one side so they don't fall out from hits in transportation.
        • 31283
        c106 is my primary suspect.
        • electronicsurplus
          • 210
          Also test D106 to make sure it is not shorted
          This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
          Help keep these from the landfills
          • sambul83
            • Mar 2015
            • 134
            c106 is CapXon 47uF 50V Vent P828 GL 105C. As I understand, reliable checking it is only by replacing with the same value cap - correct?
            I also read somewhere that c201 cap CapXon 1000uF 50V was the problem, but in their case there were some lights working on the charger. Can this cap be a problem here with no lights and no voltage on battery terminals?
            d106 I checked for continuity on the board like a fuse in both directions under power, and its not shorted in one direction, and shorted in the opposite. Was that a correct method? It looks like a diode should work like this?
            What's position of "33k resistor under glue", or position near it?
              When you resistance testing or Diode mode testing, no power to the unit.
              Check the DCV between the two leg of C106 with power applied, since you will be working in the primary (deadly side) side of the circuit, you must be real careful not to touch anything with your hands or body, you should at least plug this unit into GFCI outlet for some protection.
              • sambul83
                • Mar 2015
                • 134
                Hi budm,
                Glad to meet you again. I checked DCV, and its 0V on c106, and respectively 0v on c102 and c103. Its 14.3V on c201. I checked the diod d106 with power off, and it shows no continuity in both directions.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Ok thats a bad reading on the diode... Remove from circuit and test
                  • sambul83
                    • Mar 2015
                    • 134
                    Ops... my error. When I checked the diode on the board, I only listen for multimeter beep. Now I looked at the display, and it shows OL in one direction, and 540 mV in opposite direction. Does it mean the diode is OK?
                      • 31283
                      yes, a good diode is around 450-550 usually.
                      • sambul83
                        • Mar 2015
                        • 134
                        How about the caps measurements? Should I replace c106 now? Only that one?
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          whats the voltage at the primary caps?
                          thats the 2 big ones side by side.
                          edit...
                          0v at 102 103 means problem between the wall and there.
                          • sambul83
                            • Mar 2015
                            • 134
                            Sorry again, it was too late yesterday night, I was sleeping. Measured it today again, and the accurate voltages are:
                            6.65V on c106 (CapXon 47uF 50V), and respectively 181.7v on c102 and c103 (both are CapXon 100uF 200V). Its 16V on c201 (CapXon 1000uF 50V). All these voltages are stable. Wall outlet is at 116ACV.
                              What is P/N on that multi-leg SMPS IC? 6.65V for the start-up/running Voltage is too low, we need the spec sheet of the SMPS IC.
                              181Vdc on the main filter caps do not look right either, higher than it should be based on only 116Vac input.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Please check your meter/battery just to make sure
                                • sambul83
                                  • Mar 2015
                                  • 134
                                  My meter VC9808 had a fuse open after an error in Temperature measurement. I changed the fuse, but it may need some calibration now. Though it measures 9v batteries at 9.8 to 10.2v, and 1.5v batteries at 1.5-1.6v, so DCV seems to be accurate, when compared to a battery tester measurements. But for wall outlet AC it shows 136ACV, while UPS shows 118ACV, so the meter's AC circuit may need calibration now. Not sure, how to calibrate it?
                                  As to the charger parts, the controller P/N is Atmel TBGA-FEB AU0820 - on the back
                                  The board P/N 260111007 REVO0.21/070817 UL94VO ROHS - on the back
                                  On the front side: WAN NIEN 03VO (A) E88653 94V-0
                                  Other parts:
                                  sfh617a optocoupler next to D106 diode
                                  fbh42 fod 17p06 mosfets on the back
                                    The SMPS IC is mounted on the heatsink, it has 4 or 5 pins on it.
                                    https://www.badcaps.net/forum/attach...9&d=1429058201
                                    • sambul83
                                      • Mar 2015
                                      • 134
                                      That one SMPS IC on the larger heatsink is H826 TOP245YN, and the other one on a smaller heatsink is hidden behind the transformer, but it looks and feels exactly like the 1st one.
                                        OK, here is the spec sheet, and per page 5 the control pin needs to have 5.8V to start the circuit:
                                        The CONTROL pin is a low impedance node that is capable
                                        of receiving a combined supply and feedback current. During
                                        normal operation, a shunt regulator is used to separate the
                                        feedback signal from the supply current. CONTROL pin voltage
                                        VC is the supply voltage for the control circuitry including the
                                        MOSFET gate driver. An external bypass capacitor closely
                                        connected between the CONTROL and SOURCE pins is required
                                        to supply the instantaneous gate drive current. The total amount
                                        of capacitance connected to this pin also sets the auto-restart
                                        timing as well as control loop compensation.
                                        When rectified DC high voltage is applied to the DRAIN
                                        pin during start-up, the MOSFET is initially off, and the
                                        CONTROL pin capacitor is charged through a switched high
                                        voltage current source connected internally between the DRAIN
                                        and CONTROL pins. When the CONTROL pin voltage VC
                                        reaches approximately 5.8 V, the control circuitry is activated
                                        and the soft-start begins. The soft-start circuit gradually
                                        increases the duty cycle of the MOSFET from zero to the
                                        maximum value over approximately 10 ms. If no external
                                        feedback/supply current is fed into the CONTROL pin by the
                                        end of the soft-start, the high voltage current source is turned
                                        off and the CONTROL pin will start discharging in response
                                        to the supply current drawn by the control circuitry. If the
                                        power supply is designed properly, and no fault condition
                                        such as open loop or shorted output exists, the feedback loop
                                        will close, providing external CONTROL pin current, before
                                        the CONTROL pin voltage has had a chance to discharge to
                                        the lower threshold voltage of approximately 4.8 V (internal
                                        supply under-voltage lockout threshold). When the externally
                                        fed current charges the CONTROL pin to the shunt regulator
                                        voltage of 5.8 V, current in excess of the consumption of the
                                        chip is shunted to SOURCE through resistor RE as shown in
                                        Figure 2. This current flowing through RE controls the duty cycle
                                        of the power MOSFET to provide closed loop regulation. The
                                        shunt regulator has a finite low output impedance ZC that sets
                                        the gain of the error amplifier when used in a primary feedback
                                        configuration. The dynamic impedance ZC of the CONTROL
                                        pin together with the external CONTROL pin capacitance sets
                                        the dominant pole for the control loop.
                                        When a fault condition such as an open loop or shorted output
                                        prevents the flow of an external current into the CONTROL
                                        pin, the capacitor on the CONTROL pin discharges towards
                                        4.8 V. At 4.8 V, auto-restart is activated which turns the output
                                        MOSFET off and puts the control circuitry in a low current
                                        standby mode. The high-voltage current source turns on and
                                        charges the external capacitance again. A hysteretic internal
                                        supply under-voltage comparator keeps VC within a window
                                        of typically 4.8 V to 5.8 V by turning the high-voltage current
                                        source on and off as shown in Figure 8. The auto-restart
                                        circuit has a divide-by-eight counter which prevents the output
                                        MOSFET from turning on again until eight discharge/charge
                                        cycles have elapsed. This is accomplished by enabling the
                                        output MOSFET only when the divide-by-eight counter reaches
                                        full count (S7). The counter effectively limits TOPSwitch-GX
                                        power dissipation by reducing the auto-restart duty cycle
                                        to typically 4%. Auto-restart mode continues until output
                                        voltage regulation is again achieved through closure of the
                                        feedback loop.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                          by sam_sam_sam
                                          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                          So I have put them on the battery testing machine to drain each battery cell down to...
                                          09-04-2022, 04:45 PM
