Just got another L&C.....
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    ...and it blew.
    Fuse blew when I plugged it in,and it also TRIPPED. Few sparks went like 4th of July's fireworks.
    PSU is ANS LC-B350ATX. Has voltage selector (set to 230V btw),chip of the year 2003,diodes on a bracket,our usual 4 diode treatment ,all the signs of a PSU worse than Powmax.
    Strange thing is the fan is a Ruilian Science RDM8025SA. IIRC Deer/L&C love using Globe Fans,so this is quite weird.
    Also,have a laugh at the output it claims:
    3.3V - 28A
    5V - 35A
    +12V - 16A
    -12V - 0.8A
    -5V - 0.3A
    +5VSB - 2A
    A shot of the carnaige. Look at the blown fuse . It has a bit of copper wire underneath it for a reason I really don't understand.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Just got another L&C.....
    Did the fan seize?
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      Originally posted by goodpsusearch
      Did the fan seize?
      No. Entire PSU was brand new,with very light dust.
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        The caps look ok. Maybe the switching transistors shorted.
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          I don't think it's that either. I've had a Premier like this one with the switching transistors shorted and it wouldn't turn on at all. Just a fan twitch and that was all.
          I'd say the 5A fuse it has would have been bad itself,but not sure about that.
          Also,I checked the green thingy next to it (does anyone know what is it?) and it's cracked.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            THE ntc thermistor. If it cracks it indicates something is shorted.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Well,what can I do then? Replace the fuse and the thermistor? Or replace both and then proceed with replacing the switching transistors (guess they're the ones on the heatsink next to the primary caps)?
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Before replacing the fuse, check with the diode mode of your multimeter the 4 diodes, the 2 switching transistors, the 5vsb transistor and anything else that could have gone bad. The 2003 IC could be bad too. Check it and if most of its pins look shorted then you can assume it is bad.
                Also check the underside of PCB and post a photo of the soldering.
                  • 31281
                  primary side of the standby is blown, look between the standby transformer & heatsink!
                  btw, that foto is a good demonstration of why we are supposed to use ceramic fuses on psu's!
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    • Romania
                    Checked the underside of the PCB. No burn marks on the underside.
                    Now,more pics as you asked:
                    Replaced fuse and NTC thermistor
                    Replaced 2N60A transistor w/ thermal pad
                    Solder side (brown stuff is lots of rosin core I used)
                    The transistor w/thermal pad and NTC thermistor came from a Codegen 200X 350W PSU I discarded.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                      • 31281
                      this area.
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        • Romania
                        Originally posted by stj
                        this area.
                        What's with it? It just seems darkened but that's it.
                        Do you mean I should replace the diode and the blue cap?
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                          • 31281
                          something has sparked and blown away part of the resistor leg!!
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            • Romania
                            Okay...any ideas what value was it?
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              • 31281
                              that's not the point, yuo need to find out what it sparked to/from and test every part related to that circuit.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                +1
                                In cases like that you need to check everything or else it will blow again when you connect it to mains.
                                • Sparkey55
                                  • Jan 2010
                                  • 1523
                                  You need to use a dim bulb tester in line with the power input side just incase of a short circuit still exists.
                                  • everell
                                    • Jan 2009
                                    • 1514
                                    The three components stj circled are the snubber circuit (diode, capacitor, and resistor). From the picture of the bottom of the pc board, it looks like one of the legs of the capacitor is not well soldered.
                                    Check that diode. If it is shorted it can cause these symptoms. Sometimes the manufacturer uses a 1N4007 diode which is a slow poke at these frequencies. So they tend to short over time. A lot of these cheap power supplies use a FR107 diode (FR meaning fast recovery) and are OK for this circuit.
                                    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      That thing can not deliver a single watt of power in spec and is nothing but a poorly built motherboard and HDD killer. The only thing that will improve that PSU is a sledgehammer.
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1866
                                        • Romania
                                        Originally posted by c_hegge
                                        That thing can not deliver a single watt of power in spec.
                                        Because of missing PI coils? If so I added them to the board.
                                        Also just because a PSU is bad it doesn't mean it can't be improved.
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • brightest_z
                                          Hot Air Blew Away Resistors Near Bios
                                          by brightest_z
                                          Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                          Does anyone with more knowledge, and experience than I, know if this is the case?
                                          12-11-2024, 08:34 PM
                                        • Kurgan77
                                          Greetings all. Blew a cap off and don't know the value of it
                                          by Kurgan77
                                          I found a short on a mosfet in the vrm and used my air station to remove the bad component. and after viewed my work and noticed that had also blew the cap above it off as well... it went to cap heaven. I don't need the boardview file just what cap values are needed to replace the component. This is on a gigabyte r927xoc-4gd Windforce. I am a novice at repairing as that was a rookie mistake, + side is removal of the shirted package cleared up the short.
                                          05-12-2024, 02:36 PM
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                        • eccerr0r
                                          blew a 2N3055
                                          by eccerr0r
                                          I was playing with a 2n3055 as a voltage dropper circuit with a zener diode, and accidentally pumped 4A into the base in a common emitter configuration.
                                          The transistor instantly blew and shorted all ways around. No smoke (TO-3) but the transistor gets tossed into the round file.
                                          *sigh* oh well.
                                          08-08-2023, 02:59 PM
                                        • shanedev93
                                          Spot welder capacitor blew up
                                          by shanedev93
                                          Spot welder capacitor blew up should just replacing them fix it? The board is very dirty gonna remove it and clean it an see if I notice anything wrong that could cause this issue.
                                          Video of the smoke show
                                          https://youtube.com/shorts/AFJgRbsHGhs?feature=share
                                          06-21-2023, 01:02 PM
