blew a 2N3055
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8705
    blew a 2N3055
    I was playing with a 2n3055 as a voltage dropper circuit with a zener diode, and accidentally pumped 4A into the base in a common emitter configuration.
    The transistor instantly blew and shorted all ways around. No smoke (TO-3) but the transistor gets tossed into the round file.
    *sigh* oh well.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8344
    Re: blew a 2N3055
    I played transistor toss with the exact same transistor driving a 120v led on a 12v battery through a transformer and that transistor. It did work!
      • Jul 2011
      • 6070
      Re: blew a 2N3055
      Back many years ago I also played with 2n3055 with a LM723CN or something similar to this part number
      I also fried some as well
      • petehall347
        • Jan 2015
        • 4448
        Re: blew a 2N3055
        no great loss
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8705
          Re: blew a 2N3055
          was surprised how quickly it failed.
          today I had an errant switch mode PSU controller and a poorly thought out turn off for a mosfet, well the mosfet would not turn off and drew 5A through the inductor, heated up with smoke, and survived...
          • magneh
            Behringer Eurolive B205D repair - help identifying transistor
            by magneh
            Hello
            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
            Still, I need to replace this transistor....
            06-18-2025, 02:34 AM
          • elsomer
            help to identify transistor msi ms-15ck1
            by elsomer
            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
            02-17-2025, 05:30 PM
          • rddube
            Help with blowing transistor NAD T752 receiver
            by rddube
            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
            09-01-2022, 05:19 AM
          • amigo744
            xbox series x u82 5 pin transistor voltages ?
            by amigo744
            hello there,
            xbox series x hdmi u82 transistor 5 pin,
            can anybody tell me voltages of this transistor in standby and power on mode ???
            on which pin of this transistor are the voltages ?
            regards
            08-16-2023, 08:05 AM
            AO4601 AO4601L Transistor (Applications Laptops) Datasheet
            Complementary Enhancement Mode Field Effect Transistor
            The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
            11-05-2024, 08:21 AM
