Powerlink LPK2-30 400W - Linkworld PSU
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Got a Linkworld PSU to work with.
    It's a LPK2-30 (which I suppose is 300W) which was rated at 400W.
    What it provides:
    -18AWG wire
    -Ruilian Science fan - replaced with some noname fan from a 7team (Seventeam) AT PSU I threw away
    -P4 plug
    -6 pin AUX
    -4x HDD plugs
    -2x floppy plugs
    -20pin ATX
    Insides look like this (Pentium4's pic since my camera's batteries are dead atm)
    The only differences between my Powerlink and Pentium4's Linkworld are that mine has LOTS of PI coils (small,big...they're everywhere!),primaries are Fuhjyyu LP (his are MK).
    Also,anybody know what are the blank spots near the bridge rectifier?
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • everell
    • Jan 2009
    • 1514
    Re: Powerlink LPK2-30 400W - Linkworld PSU
    Looks a lot like the IMicro and Coolmax V-500 I recently posted. Fun to play with, puts on a great show when they blow up, but would not want to trust them powering a computer over extended time. Old Chinese proverb says you get what you pay for......if you are lucky!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      Recapped it and it works flawlessly. I was amazed by the voltages:
      Code:
      3.3V = 3.36V
      5V = 4.94V
      5VSB = 4.96V
      12V = 11.91V
      -5V (it has a -5 rail) = -4.74V
      -12V = -11.62V
      Ironically,the only one coming close to this is my Premier LC-C400ATX (Deer) I have.
      Also,it's powering a old system:
      Code:
      MSI K7N2 Delta-L
      512MB RAM
      20GB Maxtor 6E020L0 - brand new
      LiteOn DVD-ROM
      Athlon XP 1900+ 1.2GHz
      FX5200+ 128MB
      C-Media 8738 PCI Audio card (onboard ports are dead)
      RTL8139D NIC
      MSI D-Bracket
      Floppy Drive
      For the recap,I used mixed caps until I can get some japanese caps,as I think I can get something useful out of it.
      Until then,the caps I used were:
      3x Ltec - from a dead Delta
      2x OST RLX - from a dead S754 MB,one is on the 5VSB and the other on one of the output rails
      1x Sanyo WG - from a dead LGA775 MB
      Also,the fan was wired to 12v from the factory
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • c_hegge
        • Sep 2009
        • 5219
        Here I was thinking Deltas were immune to failure. You just burst my bubbe
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Deltas die too. Very rarely though - but when they do, they are usually next to impossible to fix. They don't die from bad caps tho.
          A working TV? How boring!
          • c_hegge
            • Sep 2009
            • 5219
            I know. I was just joking. They are my favourite OEM, though.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              They make quality though,and bad caps aren't a concern on Deltas. I have a PFC from that dead Delta that is heavy enough to smash a CRT
              My favourite PSUs are FSP tho.
              Back to the thread's PSU,some Linkworlds can be good if recapped and modded. However I'd advise avoiding the proprietary PWM Linkworlds. I've seen such Linkworlds and they're utter crap. SG6105D ones are good though.
              Also worth mentioning,I've seen Linkworlds give solid voltages (and ironically "high end,beefy" Deers too). EI-33 transformer though.
              Funny thing,the PSU was built with 2 common mode chokes in mind! What does that mean?
              Another question would be if Bestec or Delta transformers work on those cheap PSUs. If they do,how much watts would you be able to pull from it?
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Why?
                • everell
                  • Jan 2009
                  • 1514
                  Here is a Delta that died in a flame of glory!
                    • 31055
                    that went out viking style!
                    you should wash the soot off so we can see what actually happened.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      see https://www.badcaps.net/forum/showthread.php?t=9660
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        And you even managed to fix it ... you are the master of PSU repair!
                        Muh-soggy-knee
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • disorder
                          ps5 edm-033 dead after hdmi/usb ports destroyed
                          by disorder
                          hello guys,
                          i need help to repair a edm-033 ps2
                          history : as always hdmi port and usb ports destroyed after unplugged
                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                          so i changed it
                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                          i don't see any projection of liquid metal on pcb.
                          01-14-2025, 12:48 PM
                        • zunasthegreat
                          Chieftec GPS-450-AA with dead 20N60C3
                          by zunasthegreat
                          Hello everyone hope all doing well!
                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                          09-01-2024, 07:12 PM
                        • Beton
                          Finding a dead short component
                          by Beton
                          Hi guys!
                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                          I have a bench PSU and if I try to inject voltage the voltage...
                          12-10-2021, 01:05 PM
                        • FiguringITout
                          MSI Raider GE75 - Not posting, probable dead CPU
                          by FiguringITout
                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                          07-25-2024, 07:27 AM
