Bad Supplies: linkage of +5V & +12V
  • relkin67
    • Sep 2007
    • 36
    I've got a couple dodgy power supplies & I've observed that +5V and +12V seem to be correlated but at opposite extremes of the ATX specification. In one I read +5V=5.3 and +12V=11.5 and in the other (truly bad) one +5V=5.6 and +12V=10.8.
    This is just for my interest, mind you, but I'm curious if this is the normal modus operandi for poor designs and, if you could indulge my curiosity, why this is the case?
  • starfury1
    • May 2006
    • 1256
    Re: Bad Supplies: linkage of +5V & +12V
    well from what I understand you will find that there is a relationship.
    Regulation being tied (Referenced) to the +5 Volt rail, so what happens there will effect the 12 Volt rail
    Exactly how this is done I don't know off hand.
    I do remember round here there is some info on it
    if this is only done with poor or cheap supplies I dont know either for sure
    Supplies tend to take a basic form depending on the era and I guess most of the cheaper ones would follow the same script so to speak
    Some would probably have some changes to improve things like protection etc
    But I dont think you wold see anything major in design till you really get up to the expensive ones build by supply manufactures that know there game and charge you heaps.
    anyway if you what a read on the psu, try here
    Anatomy of Switching Power Supplies
    http://www.hardwaresecrets.com/article/327/1
    here as link to a schematic
    http://spblan.narod.ru/bp/shema/iwp300a2.gif
    do have another just cant find the link but Ive posted around this site before
    it uses the chip refereed to in the article above.
    sure others should have some good input
    HTH cheers
    • linuxguru
      • Apr 2005
      • 1564
      The sense voltages from +5v and +12v are divided down using a resistive divider, then summed to get a feedback voltage that's compared against a reference voltage. If one of the rails drifts higher (due to a bad cap, for instance), the PWM controller adjusts the duty cycle so that the feedback voltage remains constant - this usually means that the other rail has to drift lower. Usually, if +5v drifts higher, +12v will drift lower, and vice versa. How much it can drift apart depends on the cross-regulation imposed by the coupling between the windings of the secondary inductor (which are wound on a common toroid).
      • relkin67
        • Sep 2007
        • 36
        Are just the O/P filtering caps [one of the] causes for voltages to rise or can others be guilty (such as the myriad of smaller electrolytics or perhaps even the primaries)?
        • 999999999
          • Sep 2006
          • 774
          The primaries will not cause this. The myriad of smaller electrolytics generally won't either, unless one was shorting and it happened to be on the rail that's too low, but with a small cap to pull down a rail that much, great internal heat should have vented it already or made it burst if no vent is present.
          Generally the problem is as linuxguru mentioned, if the particular supply's true current output (ratio) is not very well matched to the current demands of the system. In other words, it seems most likely you have supplies biased towards more 5V current but systems not so biased in their usage.
          One potential way to differentiate between these factors is to run the supply with no load, or at least minimum load needed to keep PSu running and stable. For example a hard drive and an optical drive connected (then short PS-On to Gnd to make it run), you can measure voltages in this scenario to see if they're closer to what you'd expect. If there were a bad cap shorting to pull down a rail, it would still be doing so to a measurable extent in this test, unless a matter of changes in temp exacerbating the problem..
          • gonzo0815
            • Feb 2006
            • 1600
            I would second, what is already said. Cross regulation is on of the problems most PSU`s have, even if they have no cap related problems.
            I once used a FSP ATX 2.0 OEM PSU, which was intended for 12v powered AMD K8 systems with an Asrock K7S8XE+, a purely 5v powered SKT A board.
            The 12v was going straight up to about 13v, as this psu was not intended for a low 12v load and a incredibly high 5v load.
            The systems was running over a week until i noticed this issue. I was very happy, that my poor Maxtor hdd has survived this.
            From the datasheet i learned, that this PSu`s OVP would trip at 15v.
            If a cap can`t hold the voltage stable due degradation, this would signal the controller chip that more power is needed.
            But this can lead to any thing from high to low rails, depending on the regulation circuit and on which rail the badcap is.
            • tommy97
              PS5 Dualsense stick drift
              by tommy97
              I’ve been dealing with some stick drift issues on PS5 DualSense controllers. I’ve replaced the analogs on 4 different controllers using parts from 3 different suppliers (Mobile Sentrix and some from eBay), but I’m still getting slight drift, around 0.01 to 0.05 — only noticeable when zoomed in on the DualSense test GUI.
              Anyone else had this happen even after replacing the sticks? Not sure if it’s the parts, or fault with the controller, or just how sensitive these are. Would really appreciate any tips or suggestions!...
              08-07-2025, 02:19 AM
            • iMic
              Vintage AT Power Supplies - Selecting Capacitors
              by iMic
              Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
              The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
              02-19-2023, 06:45 PM
            • SolomonMan
              HP Docking Stations Power Supplies...?
              by SolomonMan
              All,
              I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
              Anyways these docks are HP Model 5TW10UT#ABA.
              Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
              I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
              h...
              05-09-2023, 08:04 AM
              Meanwell Switching power supplies intermittent every capacitor under 100uf
              Here is the eBay website link where I bought them from
              https://www.ebay.com/itm/276135936202
              I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
              11-25-2023, 06:05 PM
            • dbuergi
              PS5 Dualsense controller stick drift a mainboard issue?
              by dbuergi
              I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
              I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
              05-02-2025, 05:00 PM
