PCB fuse types
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    PCB fuse types
    I found a faulty PCB fuse in a PSU.
    It's labelled as H 5A. So I presume it's a 5 Amp, but is it a quick or slow blow type? It's on the output side so I assume it might be fast blow but as it's soldered in I'd like to get it right and not have to dig it out again.
    Is there a way of classifying these PCB fuses? A guide or chart?
    I can't find anything on them at all.
    Thanks,
    Habcat.
    • 30941
    Re: PCB fuse types
    foto?
    • habanerocat
      • Nov 2014
      • 96
      • Ireland
      Re: PCB fuse types
      See atached.
      Are they colour coded or something?
        • 30941
        Re: PCB fuse types
        that's a picofuse.
        http://www.rapidonline.com/electrica...l-fuses-518522
        • habanerocat
          • Nov 2014
          • 96
          • Ireland
          Re: PCB fuse types
          Thanks, but how do I know if it's slow or fast acting?
            • 30941
            Re: PCB fuse types
            no idea - maybe the letter in the circle.
            your foto is too crap to see it though.
            there are about 5 speeds btw.
            • habanerocat
              • Nov 2014
              • 96
              • Ireland
              Re: PCB fuse types
              Ok Thanks, it's a H in a circle. I don't know what it means either and can't find out. I'll go with a quick blow as it's on the output side of the PSU and hope for the best.
              Thanks again!
                Re: PCB fuse types
                LittleFuse use Green color body for Fast-Blo, Yellow for time-delayed/Slo-Blo.
                • habanerocat
                  • Nov 2014
                  • 96
                  • Ireland
                  Re: PCB fuse types
                  Thanks, I must remember that.
                  • socketa
                    Bestec ATX0300F5WA - fast,or slow blow, fuse?
                    by socketa
                    I bought a dead motherboard, and connected it to this PSU,
                    Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                    So now i truly got a bang for my bucks, and something else to try and fix.
                    The fuse was blowen, and the top was blowen off of a TNY276PN chip
                    The glass fuse didn't have any marking to say if it was fast or slow blow
                    So i checked the marking on the PCB thinking that that would tell me,
                    but it 's got a T/F8A printed on the board
                    So should i get a fast blow fuse, or should...
                    05-17-2022, 01:22 AM
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • paulmars
                    bad cap cause fuse to blow?
                    by paulmars
                    microwave oven Fuse blew, replacement blew too after 1\2 second.
                    Following common resistance test procedures found on the web the magnetron and transformer are fine.
                    The big capacitor tests open. The diode attached to it reads mostly open in one direction, although sometimes my dvm will jump down to several meg ohms for a fraction of a second. Testing in other directions reads a constantly changing value of 5xxMeg to 8xxMeg.
                    Would these cause the fuse to blow?
                    Emerson mld mw8987b
                    Tks,
                    Paul
                    05-26-2022, 04:24 PM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
                  • jshhh
                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                    by jshhh
                    Hi guys,
                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                    Anybody know how to remove this type of fuse?
                    (The fuse is toward the bottom of the image labeled F2)...
                    06-17-2025, 01:35 AM
