Re: Replacement Capacitors for PC Power & Cooling, Inc. Turbo-Cool 450ATX Power Suppl
dmill89, thanks for taking the time to answer the questions like usual.
So basically only the primary caps is responsible for the input current, I wasn't planning to increase the capacitance but was thinking of increasing the voltage since I was trying to see if I can get a 2x 220V or 250V caps with the same 1000uF capacitance as 400VDC seems like what the actual voltage can actually hit but there aren't anything in the same dimensions or smaller so that thought basically went out the window.
The only thing I can see with the PVs is that just like you said, it's half the price for the UCC KYs except the Nichicon PVs have a higher impedance. So it seems like at least for this one:
2 x 50v 10uF 6mmx13mm, my choices are United Chemi-Con KY 50v 10uF 5X11mm or the Rubycon YXJ 5x12.5mm which cost roughly the same. I'm leaning towards the KYs unless the YXJ's are better, not sure if the 1.5mm height is going to help any.
I kept forgetting that the objective is to replace the aluminum electrolytics and not the other types of caps. I noticed that the only Sanyo OS-CON 2.2uF 25v polymer caps available is from someone in China selling it on EBay so there is a high chance of it being fake. I did measure the Sanyo OS-CON with a digital multi-meter and it does test at 2.2uF. I was wondering what would actually happen electrically-wise if I did replace that with a 6.8v OS-CON polymer cap should it fail at a later date, would there be any problems since it doesn't seem like there are quality replacements polymer caps available that meets the specs? The Sanyo is part of the daughterboard, any ideas what the daughterboard is actually for since other Power Supplies usually don't have it and seems like other than the big square capacitors that shows 250v/275v, all the capacitors are between 25V-50V on that board.
For the 4 x 50v 1uF 5mmx8mm, I've decided to get Rubycon YXJ 50v 1uF 5X11mm as it seems to be the same impedance as the YXF but with a higher ripple rating. The Nichicon PV's has a way higher impedance.
Seems like in all the Corsair AXi series, they use Panasonic input caps and since it is cheaper than the other options and it's still available at 1/2 the cost, it seems to be the best value for something of quality.
I decided on 4 x 25v 100uF 7mmx12mm -> United Chemi-Con KY 25v 100uF 6.3mmx11mm as KYs has a lower impedance than the Nichicon PV and way cheaper.
Good point on 10v replacements for the 6.3v caps as additional overhead is always good for the same price and last longer since I thought durability was based on the 105c rated hours but I guess when you don't push the voltage to the max on a 10v cap as it will probably be 63% max, it will add to the reliability.
Is there any other good options for the 1 x 25v 22uF 6mmx13mm replacement capacitor as the Nichicon HC was a good option except I can not find it in stock anywhere. The Rubycon ZLG has the exact same 270mOhm impedance and 350mA ripple current as the Nichicon HC except it is also not in stock anywhere.
Just as I thought, that higher ripple rating is a good thing as far as reliability is concerned, thanks for pointing out that lower impedence would reduce filtering performance since I think PC Power & Cooling advertised the Turbo-Cool Power Supplies as being high filtering performance. Hopefully all of these caps will give at least the performance of the original caps.
