CEMO:ATX-500W-24P (+5vsb shorted)
  • LENOVO-A880
    Not A Bad BIOS
    • Feb 2014
    • 79
    • MALAYSIA
    Diagnosing A Dead ATX-500W-24P PSU *Identical* Knock Offs From China
    Hello everyone I have a problem with my power supply. The PSU in any way is not powering on (no green light and fan is not spinning). When opened it up I found short on +5Vsb. I had removed 2 bulge capacitors in that line and still trying to find out the main problem here. These are some of the basis findings which I have done :
    1. Suspect a short circuit on the main board. The suspected component are the filter capacitors and power transistors. A faint smell comes from the board and suspected to be an overheating MOSFET. A few months ago the power supply actually had failed to power on my PC which has probably a dead mother board. Pls refer to this link of the thread here for the dead motherboard (https://www.badcaps.net/forum/showthread.php?t=38542)
    2. Check that the fuse is usually still good from my inspection. Before proceeding to further diagnosing the problem of the power supply I think to actually replace the capacitors with good one first except for the power transistors.
    3. Inspect the solder-side of the board and found burning sign on one of the components near the transistor/transformer combination. The main board soldering is really quite bad from my inspection just after removing the heat sinks and live wires.
    4. Have not attempt to use a multimeter to check for proper voltages on the pin-3 and pin-9 of the ATX to main board supply
    Questions
    1. What type of series of capacitors should be changed here as a proper capacitors replacement to the dried up capacitors on the C507 and C508 label capacitors which has rating of 470uF/16V and 1000uF/10V? Main manufacturers like Panasonic recommended us using the EEU-FC series capacitors for a replacement.
    2. Where can I purchase this type of capacitor for a replacement to the dried up capacitors? Digikey?
    3. What is the best practice to replace the dried up capacitors of this kind of board?
    4. How can I check the voltages between pin-3 and pin-9 of the ATX to main board connector. Should I also check the main voltages of the primary side or primary power voltage as well before proceeding to another further test?
    "If you cannot do great things, do small things in a great way."
    -Napoleon Hill
    "The chip that functions abnormally will be desoldered, as they say."
    -Charles Stross
    "Why is it you're always too small or too tall?"
    -The Mad Hatter
    Re: CEMO:ATX-500W-24P (+5vsb shorted)
    You can use FR series also, they are made in Malaysia.
    You should look at the ESR value of the FC and compare to FR to make sure that sometime too low of the ESR can cause problem.
      • 31278
      worth adding, if the FR/FC caps are too large, you can get compact FK versions.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        It is not worth fixing in my opinion.
        • new2019
          • Aug 2014
          • 49
          • Srilanka
          You have same problem as mine , you will have a short circuit in the primary side which extends to secondary side .
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            This uses the infamous 'two-transistor' design for the 5vsb. I've seen them fail and put out 20+V, killing the motherboard. I recommend replacing ALL the electrolytic capacitors on this board.
            Take a look and see if the 5vsb rail has any shorted diodes on it.
            Muh-soggy-knee
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • FlameOnion
              MSI 7600 GT, shorted capacitors
              by FlameOnion
              I got this gpu that does not work, is not detected in windows(not shown as a pcie device),the heatsink got a little warm. MSI 7600 GT PCIE, NX7600GT-T2D256EZ.
              Tested in different motherboards, same issue. I got it with a capacitor broken(one leg was left), and an broken indictor related to fan pwm I think.
              As a hobby I tinkered with arduino, I got a soldering iron and a hot air gun, no experience in repairing(occasionally watched videos of northridgefix)
              I measured randomly capacitors for short and found some shorts on a few, and found short on a few mosfets....
              05-23-2024, 07:30 AM
            • nicktasios
              Macintosh Quadra 840AV PSU
              by nicktasios
              I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
              12-22-2024, 05:07 AM
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • Mugar
              asus fa507re - hn021 plyta DA0NJNMBAD0 REV D model NJN - no reaction, main power rail shorted
              by Mugar
              Hey guys got laptop like above. Came to me with shorted main power rail and battery protecion on ( 0V on output). Got rid of short but nothing. Bench power supply says it takes nothing, but still got all voltages 1,2v,3.3v,5v - all good. Thermal cam showed nothing is starting even for a sec. I believe that since all coils etc are good resistance to ground it's probably one of chips. Can be IO chip or maybe something else? Could somebody help me out with this one - it's blowing my mind lol
              05-12-2024, 01:53 AM
