MSI 7600 GT, shorted capacitors
  • FlameOnion
    • Nov 2021
    • 6
    • ROmania
    I got this gpu that does not work, is not detected in windows(not shown as a pcie device),the heatsink got a little warm. MSI 7600 GT PCIE, NX7600GT-T2D256EZ.
    Tested in different motherboards, same issue. I got it with a capacitor broken(one leg was left), and an broken indictor related to fan pwm I think.
    As a hobby I tinkered with arduino, I got a soldering iron and a hot air gun, no experience in repairing(occasionally watched videos of northridgefix)
    I measured randomly capacitors for short and found some shorts on a few, and found short on a few mosfets.
    The big black square 1R0 inductor, has 4 leads and are all shorted with 0 ohm.
    Now I am at:
    Lifted the Source pins of mosfet Q10 and Q11 that connect to ground(that I did not knew they were ground)
    I somehow found a schematic that looks like the gpu I have.
    Found https://www.badcaps.net/forum/troubl...801#post918801
    Someone talks about something that I don't know, situation when it may appear shorted but is not:
    Q4, Q5, and Q10 are all "low-side"-type MOSFETs (i.e. they are connected between GPU/RAM power rail and ground. Therefore, they may appear to be shorted between Source and Drain while on the board, but actually be okay when removed. This will vary for different GPUs. If they show a short-circuit or less than 20 Ohms resistance, then the only way to know for sure is to remove them from the board.
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    Shorted mosfets have usually also shorted source pin, this is a good indication for a shorted mosfet. Else u can just remove the coils or lift one pad of them if possible, this is optimal way to check mosfets. Remember mosftes can stay electronically on (shorted) some longer time even not powered, so to go sure it might be necessary to switch them off with correct voltage on source, before measuring a short between source and drain.
    • DynaxSC
      Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
      by DynaxSC
      I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
      I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
      Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
      Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
      05-04-2025, 12:08 PM
    • barry101
      Apple 820-3662 VCore shorted to ground.
      by barry101
      Hi, Would appreciate some help.
      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
      Get charger light but no fan spin or chime. No liquid damage.
      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
      06-24-2025, 07:34 AM
    • blablaro
      Philips PSU (715G7350-P01-000-002S) No stand by light (0V)
      by blablaro
      This is the source from a Philips TV 43PUH6101 that suddenly stopped.
      I know it's the source since I have ~ 0 volts on outputs 12VA/16VA, 12V/16V, +3.5/+5V
      For the latest weeks I've been trying to figure out the problem with this. I've ordered all kind of mosfets, a capacity meter and other things to try to figure out the issue with this PSU. My wife thinks I'm crazi but I want to repair it
      Initially, when I started the testing with the multimeter on diode mode (220 V on):
      - discovered that was Q9101 shorted (or I shorted it)
      09-24-2025, 10:21 AM
      Acer Predator PT516-51s-7600 Notebook Triton 500 SE Specification for Upgrade or Repair
      This specification for the Acer Predator PT516-51s-7600 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT516-51s-7600 boardview and PT516-51s-7600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
      09-07-2024, 03:10 AM
      ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
      This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
      09-07-2024, 02:50 AM
