Corshair RM750 - doesn't allow for board to turn on
  • kotel studios
    • Dec 2024
    • 152
    • Poland
    While back I got this Corshair RM750 PSU from a friend which said it was broken. Plugged it into my bulb protection and turned it on. Was greeted with two 60w bulbs turning on (barely at max with PSU generating the voltages. I thought it was the APFC needing more current so I removed the bulb protection and plugged into my wall socket.
    All the rails were fine, all generating the correct voltages when turned on.
    Now, I have plugged in an known good board (intel i7 0th gen with iGPU, nothing else) and pressed the power button. Nothing happened besides the 5vsb LED onboard going dim for a split second. No sounds, beeps, fan spin and other LEDs. Measured the PS_ON and 5vsb rails when pressing the power button and there weren't any issues I could spot (5vsb is 5.08v all the time, PS_ON dips from 5v to 4.8v and then back to 5v). No obvious signs of burns/damage on the PCB.
    This is my first time seeing such an issue. I have no idea what's the cause for it.
    Any ideas?
    • 31017
    over current protection circuit probably false-tripping.
    look for a big current-shunt and work back from there.
    • kotel studios
      • Dec 2024
      • 152
      • Poland
      Okay, I have done reverse engineering on the parts which were exposed and I couldn't find any big resistors which represented current shunts.
      Here are the pictures.
      Any ideas?
      • kotel studios
        • Dec 2024
        • 152
        • Poland
        Nobody is gonna belive this, but when I was going outside to take better pics of it, the corner of the PCB (near the primary MOSFETs) had shorted against the case and now I have 10ohms between positive DC and negative DC on the diode bridge rectifier in circuit, 31 ohms between Drain and Source on all of primary MOSFETs. There is also an burning smell inside.
        • CapLeaker
          Leaking Member
          • 8153
          I guess you have to fix the shorted out components in this PSU now. What you should have done first place was checking the state of the supervisor IC in the secondary of the PSU when connected to a motherboard and didn’t work, vs not connected and forced on.
          • CapLeaker
            Leaking Member
            • 8153
            Drain and source of the mosfet short could be because you turned the gate on. Do a proper test of the mosfet with your DMM in diode mode and try turning the gate off an on. There are you tube vids on how to do that,
            • kotel studios
              • Dec 2024
              • 152
              • Poland
              Quick update:
              The resistance dropped to 5ohms on both the positive and negative outputs of rectifier and on gate and drain of primary MOSFETs. My idea is to remove the rectifier and if that doesn't fix it remove those MOSFETs (that's where the burnt smell is). Hopefully only one went bad and not anything else...
              • kotel studios
                • Dec 2024
                • 152
                • Poland
                Order of solder wicks finally came and I found the culprit for the short on primary DC side.
                One of the primary MOSFETs went short. Luckily it was only one so the damage should be minimal, but just for sanity I'll need to replace all 3 60R190E6 MOSFETs.
                Now here's my question, what are the equivalents to 60R190E6​ inifeon MOSFETs? I can't find any online.
                  • 31017
                  that part number covers 3 parts - which is it?
                  • kotel studios
                    • Dec 2024
                    • 152
                    • Poland
                    I believe the IPP60R190E6 (TO-220 case).
                      • 31017
                      it may have been replaced by the 60R190P6, TME sells it.
                      send a mail to infineon asking about P6 vs E6
                      • kotel studios
                        • Dec 2024
                        • 152
                        • Poland
                        Yup, the P6 series is an more efficient drop-in replacement for the E6. Now before I order the MOSFETs from TME I need to troubleshoot the current sensing part.
                        EDIT: Supervisor IC is on the fan controller board.
                        Useful link: https://www.techpowerup.com/review/corsair-rm750/4.html
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Just to shed some light on the original issue of the PSU here...
                          If you have a PSU that turns On and appears to output the proper voltages on *all* of the output rails, but the connected motherboard does NOT turn On, then the issue is likely with the PG signal - either it's not there or not coming on at the correct time.
                          But now with the shorted MOSFET(s), that's a completely different issue and probably unrelated to what was going on originally. Just putting this here for anyone else who reads this thread so they can keep track of what's going on.
                          • kotel studios
                            • Dec 2024
                            • 152
                            • Poland
                            Hmm... That's an theory I haven't thought of. Any suggestions on what could cause it?
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • jb_Bak
                              by jb_Bak
                              CN6401
                              Pin 01 NC
                              Pin 02 NC
                              Pin 03 "BL_ON": 0V
                              Pin 04 "N/C"
                              Pin 05 "STBY 3.3V": 3.5V
                              Pin 06 "GND": N/C
                              Pin 07 "AC_OFF"...
                              09-27-2021, 04:52 PM
