85W Macbook magsafe PSU troubleshooting
  • izzzzzz6
    • Jul 2014
    • 24
    • France
    Can anyone help here? I have an 85W magsafe adapter that has semi failed! It is not the flex. I cut the end off and was getting a very low voltage, by shorting the wires together i could trick it to kickstart and it would goto 6V once plugged into the mac and trick started with a short of the power cable at the same time it go's to 16 or 17V and works fine!
    I am thinking it is a bad Capacitor. I know it is really difficult to open these things up without destroying some of the components in the process. Any views on this?
    James
  • izzzzzz6
    • Jul 2014
    • 24
    • France
    Re: General PSU Discussion and FAQ contributions
    Hi Guys, does anyone know why an 85W Macbook magsafe PSU may be acting up? It is not a broken flex.
    I cut the end off and was getting a very low voltage. When tricking it by shorting the leads together i could get it to jump to 6V
    Once plugged into the mac and again tricking it by shorting the cable together at the same time it jumps to it's normal operating voltage around 17V!
    I'm thinking it's a bad capacitor. Has anyone had similar problems with other/similar PSU's?
    Ps. How do i start a new thread on this if i want to?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Re: 85W Macbook magsafe PSU troubleshooting
      I merged your 3 separate posts here, please do not litter the FAQ's with content that does not belong there.
      • selldoor
        Slow Learner
        • 7870
        As Per says we do not like multiple posts for the same question and definitely not in FAQ stickies. If you want to make a new thread (on another subject!!) then scroll down to
        Forum Jump and pick a suitable forum. When that forum opens there will be a blue box at the top left where you can create a new thread.
          • 31304
          foto's and all that.stuff
          • izzzzzz6
            • Jul 2014
            • 24
            • France
            Right you are. Sorry guys every time i come to this forum i can't work out how to make a post. I have been looking over and over to try to make a new post and it has got me baffled. I can't even work out how i posted this question about the charger a few years ago.
            Why isn't there an obvious button that says create new post?
            Thanks.
            James
            • diif
              • Feb 2014
              • 6978
              • England
              Thanks.
              James
              There is.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                2 years later......
                • izzzzzz6
                  • Jul 2014
                  • 24
                  • France
                  Yes 2 years later
                  Things move slow around here.
                  I see what the problem was. First i need to navigate to the appropriate forum subject. Once there the button appears.
                  I did not realise what the forum jump button was for or how to find the list of topics.
                  Once i got there the rest was easy.
                  Sorry for being an idiot.
                  Thanks guys.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    I have an old Magsafe charger that does the same exact thing: it barely outputs any voltage until you short the wires, and then it turns of?
                    I originally intended to fix it and use it for a project, but never got around to it. I still have it though. Last time I was playing with it, I *almost* managed to get it open. Looks like it's glued together.
                    • envym
                      MacBook Pro 2018 with Activation Lock
                      by envym
                      Hi everyone!
                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                      06-27-2025, 08:54 AM
                      MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview
                      MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview...
                      10-28-2024, 03:29 AM
                    • boyseth
                      Troubleshooting guide for Macbook m2 A2681 - No power issue
                      by boyseth
                      hello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
                      08-14-2025, 01:28 AM
                    • Flasman90
                      Macbook Pro DFU Restore Issues
                      by Flasman90
                      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                      08-30-2025, 10:27 AM
                    • shivahoj
                      Macbook A1297 Mid2010 820-2361a Magsafe schematic?
                      by shivahoj
                      Hello, the Magsafe connector of the above Macbook was defective(burnt pins). It is located on a small DC-IN board labeled 820-2361a sitting in the top right corner of the macbook, connected to the main PCB with 5 separate cables.
                      While replacing the magsafe, I must have unsoldered and lost a small SMD Resistor that is silkscreen-labeled R1 on the solder side(opposite of the magsafe and ferrite filter). It carries the 1bit-bus to the Amber/green LED driver chip in the Magsafe plug, and without connection to the 1-bit chip in the plug, the macbook won't charge.
                      ¿Can anyone please provide...
                      12-31-2020, 08:13 AM
