Troubleshooting guide for Macbook m2 A2681 - No power issue
  • boyseth
    • Jul 2024
    • Philippines
    hello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
  • mon2
    • 14735
    Use a usb-c meter to gauge the voltage and current draw by the logic board. Post the measurements.
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • pcbmaniac
      MacBook A1278 (3115) No PPBUS_G3H Issue
      by pcbmaniac
      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
      1. U7000 Measurements:
        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
      2. Resistors:
        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
      • If I also decide to replace the SMC, do I need to order it pre-programmed,
      12-02-2024, 04:12 PM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • Stephen
      A2141 MacBook Pro 16" lid sensor issue.
      by Stephen
      Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
      11-01-2024, 03:45 PM
    • Gueric
      MacBook Pro 2019 820-01700 Speaker amp issue.
      by Gueric
      I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
      I don't how to troubleshoot speakers. Any help would be very much appreciated.
      A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
      05-19-2025, 03:08 AM
