Teami Skincare Fridge TM10L power board goes kablooey
  • lkvee
    • Feb 2009
    • 198
    Turned it on. Green LED is on (set to cool), but the fan did not spin. Opened up the back, and found two blown capacitors. One blew up dramatically enough to remove the outer covering. Not sure if I can find that outer covering. I *think* the power board is the JWBX-12V5A-A (source: nbjianwei.com). She just wants to cool off her skincare products. If I were to buy an 12V AC adapter (Amazon has one by HKY), can I use it with this compromised power board?
    If I need to repair this power board, how can I identify the specs of the nekkid capacitor? I can identify the one with the covering, but I am not sure whether the other one has the same specifications. If anything, they look similar physically. Not sure if other parts are also compromised (MOSFETs?).
    If I want to replace this board entirely, will this JWBX-12V5A-A board suffice?
    • 31260
    show the underside of the board to see if the 2 caps are connected together - if they are then they are probably identical.
    then replace them with panasonic FR series, rated for 25v.
    are the originals 25v or did the makers ride close to the limit with 16v parts?
    also check the diode on the heatsink isnt shorted - incase it blew the caps
    • CapLeaker
      Leaking Member
      • 8342
      Looks like the 12V output of a power supply and 2 capacitors in parallel. Change both caps to 25V and 105C rated and you can increase the capacitance a little too as long as they fit inside.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5083
        • New Zealand
        What happened to the photos?
        -David VanHorn
        • CapLeaker
          Leaking Member
          • 8342
          Some photos and files got corrupted. Very unfortunate.
          • R_J
            • 9607
            Best the wayback machine can supply
            • R_J
              • 9607
              I found them on another site. Looks like the board is a JWBX-12V5A-A
              Post #6 can be removed to save space
              • Agent24
                I see dead caps
                • Oct 2007
                • 5083
                • New Zealand
                Oh no, server crash or something?
                Whee! Now that's a crapcap for sure when the can flies off the bung rather than popping the vent!​
                -David VanHorn
                • CapLeaker
                  Leaking Member
                  • 8342
                  [QUOTE=Agent24;n3671250]
                  Probably both.
                    • 31260
                    check the output diode, replace the 2 caps
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • dropfry
                      Need help with a wine fridge controller board.
                      by dropfry
                      Model: Frigidaire FFWC18L2QB
                      Board: FX101B PCB16006F1 110 HANYI
                      This fridge was turning on, but wouldn't cool and the fans wouldn't spin in the back. Removed the back panel and found two controller boards and a power supply. The controller board at the top had burn marks under two heatsinked transistors (photo titled Top_Left). They said 13005D on them. I could not find those in America, so after a lot of googling and cross checking datasheets it looks like E13005 are replacments. Tested them with the diode setting and they both look good.
                      Put the board back...
                      10-07-2023, 04:55 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
