Dell went downhill choosing Huntkey, a known bad psu manufacturer as an OEM.
https://www.badcaps.net/forum/attach...1&d=1400339914
I don't know what led to that result..
Just look at those pics:
The 5vsb IC has been blown in 2 pieces and one diode has been cut by itself
All the caps were tested and found ok. In fact, about the primary capacitors HEC 680uF 220WV, their actual capacity is 920uF!
The destroyed MOV indicates that the psu might have been hit by a power surge or maybe someone chose the wrong voltage in the voltage selector switch.
Otherwise the psu isn't bad.
-passive pfc. The first I see that is not covered with insulator material, you can actually see the copper turns:
-UC3843B PWM controller
-1x W10NK80Z N channel mosfet in a single forward topology
-1x STPS2045CT for 3.3V
-1x STPS3045CT for 5V
-1x STPS30H100CT for 12V
-Voltage comparators AS339P and AS393P for UVP and OVP
-ST9S313 for OPP & SCP & OVP & UVP, cannot find datasheet.
Is it worth repairing? I have read that Huntkey power supplies are not greatly designed.
