Hantol HPSU550. Worst power supply. Εver.
    Worse than the psu itself is the fact that it powered a quad core PC, 2 dimm ram and 8600GT....
    https://www.badcaps.net/forum/attach...1&d=1400287499
    There is nothing useful even for parts inside that power supply unit.
    The case is thin like tinfoil, the fan had its label loose and the rubber seal wasn't fitting in hole, awfully thin heatsinks, tiny transformers, 330uF primary caps and 1x1000uF secondary capacitor for every main voltage output, without any coil!
    There are also the usual 13007 transistors, 20 Ampere schottky rectifiers and 10 ampere STPR1020CT for 12V!!!
    I can't believe that this ultra fast rectifier didn't blow considering it powered a Quad core cpu and 8600GT GPU. The PCB is burnt around it. The fan worked at 12V of course!
    https://www.badcaps.net/forum/attach...1&d=1400287716
    Well, at least it has passive PFC. But wait, I saved the best for the end... This PFC made me suspicious right after I saw it. Let's look more closely:
    https://www.badcaps.net/forum/attach...1&d=1400287865
    It's absolutely fake!!!
    If you are as interested to see what's inside as I was, I took photos of its "core":
    I think they waste their money.. They should fake the PFC cable too! Look at the PCB:
    https://www.badcaps.net/forum/attach...1&d=1400288885
    Like the Powertech gutless wonder psu I got 2 months ago, the PFC connector is on the same PCB track! Mystery solved! Powertech probably also comes in "PFC" editions with fake PFC, so no need for a real connector!
    Re: Hantol HPSU550. Worst power supply. Εver.
    At least it didn't have a 2 transistor 5vsb, but yeah, everything else about this PSU is total junk.
      Yes, I forgot to mention there is DM311 for 5vsb. Btw this thing is still being sold here for 20euros...
      https://www.badcaps.net/forum/attach...1&d=1400291046
      What?
        Hahahahah!!
          i'm surprised they spent the money on a fake choke,
          i have a psu that said "active pfc" with a choke in it,
          and i binned several really crap ones that said "active pfc" and had no pfc at all in them - just the sticker!
            Wow, that's an amazing find!
            Why not take it back to the place that sells them and ask what they think about their fine product?
              The small toroid coil in the secondary must be fake too. One of its legs is soldered to nowhere:
              https://www.badcaps.net/forum/attach...1&d=1400324885
              All the 3 main voltage rails are group regulated with the other toroid coil. Just like the Powertech power supply.
              The customer doesn't remember where he bought it. But there are plenty of computer stores that have it for sale right now:
              https://www.skroutz.gr/s/311241/Hant...120mm-Fan.html
                What a wimpy piece of @#$%! 200W max, unless you need a night light. Wimpy heatsinks, small I/P rectifiers, MJE13007-type switch transistors, wimpy O/P inductors and capacitors, 330uF I/P capacitors. 550W? Only if you are armored against shrapnel.
                The fake PPFC inductor probably is a way to dispose of scrap sheet metal while charging a few extra Yuan for the P/S.
                PeteS in CA
                  That is a bad one indeed!
                  Note, it looks like the AC line (if they did the color coding of the wires correctly! - should be black for the line) wire goes to the diodes, whereas the neutral goes to the fuse... BAD!!! bad bad bad bad bad! The electronics could still be live even in the fuse blows!
                  Edit: Hmm, someone else has a hantol with a fake choke also!
                  Muh-soggy-knee
                    Where is your god now?
                      praying to a schuko connector?
                        Wow.could those heat sinks be any thinner!
                        Some people just can't take a joke...
                        But Powmax power supplies? That's a joke everyone can take.
                        sigpic
                          From the same place as goodpsusearch, too, LOL. Looks like an epidemic!
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                            Originally posted by c_hegge View Post
                            At least it didn't have a 2 transistor 5vsb:
                            Good thing, imagine how hot that thin heatsink would get!
                            Yeah, that thing is terrible. Even if it had a full input filter I would just part it out and then throw it away.
                              And to think that I have doubts that my rebuilt PSUs are getting "stressed" with a 67W TDP CPU and 40W video card
                              I think I have a headache now from -ing myself too many times.
                              Yeah, in one of the pictures, it looks like you already bent the case. I bet the "330 uF" primary caps aren't even 220 uF. And what do you expect from that fan? WAM, it works!
                              The resistors in front of the big torroid look quite toasty too. Are these load resistors or in series with some ceramic caps (i.e. secondary snubber network)?
                              All I can say is... that's one hell of a solid core!
                              Hey, at least they used metal fillings. Could have been concrete or even a sand bag... and then you be wondering why there's sand inside your computer every time you bump it .
                              That's what I thought too. The Chinese bean counters are clever people .
                              Okay, maybe not so clever after all
                              Originally posted by Per Hansson View Post
                              Meh, what's wrong with the good old Schuko plug?
                              In Europe, safety is second. In China safety is... irrelevant, since the population is too large anyways.
                                I think "WAM" is the noise that the rest of the computer will get when it receives the supposedly 220V output of this thing (see the 3rd post).
                                  The reason I posted the picture of the Schuko plug was in reply to ben7's post.
                                  Maybe I was being a little too vague.
                                  But the thing is that 100% of the powersupplies I have looked at don't have a double prong off switch which AFAIK should be mandatory in all countires with this plug.
                                  Because just as ben7 says the system can be live, and in the case of the Schuko connector it can be live even with the PSU switch in the off position.
                                  That is since the "Live" and "Neutral" can be reversed by plugging in the connector 180deg you can have power coming in on the "neutral", all the way through the PSU and being "stopped" at the powersupply switch.
                                  So if you touch any component in a PSU like this and ground, well let's just hope you have a ground fault detector in your house in case you do something so stupid
                                    No, you were fine. I know exactly what you were talking about which is why I joked that safety is second in Europe. After all, I did live in Eastern Europe when I was a kid, so I'm very familia with these Schuko plugs .
                                    Actually, other than this design "flaw", I like them better than what we have in the US. With the US plugs it's very easy to short out the two prongs on the plug if you accidentally pull it out a little and drop something metal on it. Likewise, it is very easy to touch the Live prong on a US plug while trying to plug it or unplug it. I did that multiple times, but each time I was lucky that I wasn't touching anything else that's grounded and I was sitting on a nice fluffy carpet.
                                      I like the UK plug the best in terms of safety. Earth pin is longer than the other pins and the covers over the wall socket won't open without the earth pin being present (no such thing as an unearthed UK socket, unless it's not wired properly) But they are DAMN painful to tread on!
                                        Here is the cousin to your Hantol power supply. It is the Coolmax I-400. You can see from the pictures that the transformers have the same part numbers, and the primary capacitors are the same brand and value. The difference is that the output circuit is different......not too sure which is worse. The Coolmax has a two transistor 5vsb which is a step down. Wiring is 20AWG. Like a bird......cheap, cheap, cheap...........
                                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
