Where to get replacement caps for an Antec true380?
  • Sparky
    High voltage
    • Jan 2007
    • 234
    My brother has had an Antec truepower 380W PSU for about 5 yeras now. Been a very good unit but recently he had trouble. Seemed to be mobo but after replacing that (and the CPU and RAM since he had an older socket A setup), he still had trouble.
    PSU. Cracked it open and one of the Fuhjyyu caps is bulging some. Only one, but I guess that is all it needs. Not bad really considering the unit is 5 years old. Anyway, it is down to recapping or replacing the PSU. Recapping would seem to be a cheaper alternative (since he is rather low on money now) so I'm wondering what caps to get for this PSU and where to get them? I figure it would be best to replace all the output caps even if only one is bad. There are 4x 3300uF 10V caps and 2x 2200uF 16V caps. Not sure if some of the smaller random caps should be replaced or not, they look fine.
    TIA
  • Nitwig
    • Apr 2007
    • 58
    Re: Where to get replacement caps for an Antec true380?
    My Antec NEO 480 uses the exact same caps and I need them as well. Let me know what you find out. I have a request in to Topcat. I'll let you know what he says.
    • Nitwig
      • Apr 2007
      • 58
      Ok, I just ordered some from ebay. I will let you know how they work out. I had to buy way more than I need. They are coming from China so It may be a while before I repair my power supply. If you haven't gotten any by the time I receive them maybe I can sell you a few. They should be Nichicon. I will get back to you.
      • Sparky
        High voltage
        • Jan 2007
        • 234
        I thought that the neos were Seasonic built and didn't have fuhjyyu craps in them
        • Nitwig
          • Apr 2007
          • 58
          The original Neo 480 was built by Channel Well Technology and it killed my MB
          • Sparky
            High voltage
            • Jan 2007
            • 234
            Would these caps be any good for the Antec 380W?
            http://cgi.ebay.com/3300uf-10v-105C-...QQcmdZViewItem
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              the safest bet is to get them from topcat.
              you will get the right ones and they will not be counterfiet.those ebay caps look fishy..
              • Sparky
                High voltage
                • Jan 2007
                • 234
                The cap request form is for mobos, but do I use that or just PM topcat?
                • Logistics
                  • Apr 2007
                  • 721
                  Yep! ^_^ Just send him a PM... err, he's on vacation till the 14th, though.
                  • Sparky
                    High voltage
                    • Jan 2007
                    • 234
                    That's fine, the 14th is tomorrow, so maybe the 15th or 16th he might get it
                    Thanks guys.
                    • Nitwig
                      • Apr 2007
                      • 58
                      I purchased my caps from the same Ebay seller. We shall see what he sends me. The picture in my auction showed Nichicon. I decided to take a chance. I will report what type of caps I get when they arrive.
                      • Sparky
                        High voltage
                        • Jan 2007
                        • 234
                        Any updates Nitwig? Have those caps come in yet?
                        I'm still waiting on a response from topcat.
                        • Sparky
                          High voltage
                          • Jan 2007
                          • 234
                          bump... need some caps.
                          • Nitwig
                            • Apr 2007
                            • 58
                            I have not received them yet. They are coming all the way from China. I will let you know when they arrive and post some pics. I hope that I have not been tricked.
                            • Spacedye69
                              • Nov 2005
                              • 698
                              • US
                              Those look like Nichicon VZ series. They are not low esr. You can get the same caps from Mouser.
                              • Sparky
                                High voltage
                                • Jan 2007
                                • 234
                                OK while I'm waiting on topcat to reply to my PM I figure I'll ask some dumb questions
                                The 3300uF 10V caps are on the 3.3V and 5V rails, and the 2200uF 16V caps are on the 12V rail. Now I was digging through my bag of salvaged caps from dead mobos and I found 4 Rubycon MBZ 2200uF 6.3V caps and 2 Nichicon HM 1800uF 16V caps. How bad of an idea would it be to put the Rubycons in replacement for the 3300uF 10V caps on the 3.3V and 5V rails and the Nichicons in replacement of the 2200uF 16V caps on the 12V rail? Technically the lower voltage rating on the rubycons shouldn't matter since it shouldn't get more than 5V anyway, but I'm wondering about the lower capacitance...
                                Just a stupid question while I wait
                                • gonzo0815
                                  • Feb 2006
                                  • 1600
                                  As for the MBZ i owuld have no worries, but HM caps? shure theyre not related to the overfilling problem?
                                  I think 3300uF for an 480w unit should be ok, at least most FSP and Delta PSu`s i have seen are usually equiped with capacitance in this region. On ly the newer 12v PSU´s do have usually 3300uF 16v at the 12v rail and abouth 2200uF on the other.
                                  • Sparky
                                    High voltage
                                    • Jan 2007
                                    • 234
                                    Well these HMs are a couple years old and look like new, so I'm guessing maybe they aren't part of the overfilled batch. Maybe, I dunno.
                                    I just wasn't sure about dropping the capacitance from 3300uF to 2200uF on the 3.3V and 5V rails and from 2200uF to 1800uF on the 12V rail. Not sure what effect this would have.
                                    I have a few options available for the replacement of the 4 Fuhjyyu 3300uF 10V caps on the 3.3V and 5V rails:
                                    Option 1: four Rubycon MBZ 2200uF 6.3V caps
                                    Option 2: two Rubycon MBZ 3300uF 6.3V caps and two OST RLX 3300uF 6.3V caps
                                    Option 3: two Rubycon MBZ 3300uF 6.3V caps and two Rubycon MBZ 2200uF 6.3V caps
                                    And a few options for the 2 Fuhjyyu 2200uF 16V caps on the 12V rail:
                                    Option 1: two Nichicon HM 1800uF 16V caps
                                    Option 2: two OST RLX 1500uF 16V caps
                                    Option 3: two KZG 1500uF 16V caps
                                    Option 4: two Rubycon MBZ 1500uF 16V caps
                                    The overall option for the PSU is wait on a reply from Topcat.
                                    Input?
                                    • gonzo0815
                                      • Feb 2006
                                      • 1600
                                      I would say it all depends in what system you want to put this psu (e.g. it is 5v supplied or 12v powered).
                                      In generall i do not recomend to dropp the capacitance, but on PSU`s i would say it is may be not that critical.
                                      So i would use in that case the 1800 HD on the 12v rail and the 2200uF MBZ for the other rails.
                                      If the system is 5v powered, i would put the 3300uF MBZ on that rail.
                                      Ost are probably ok for short therm use, but only if esr is measured.
                                      • Sparky
                                        High voltage
                                        • Jan 2007
                                        • 234
                                        The system it'll be running right now is 5V powered for the CPU (socket A). It may do an A64 later on. The reason why I even mentioned the OST caps was I've heard they don't do well on mobos (replaced a bunch of those) but they seem happy in PSUs.
                                        Maybe instead of cutting corners I should just get the right replacements the first time...
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
                                        • crosswinds
                                          Assistance with identifying replacement caps on ASUS P5VDZ-MX
                                          by crosswinds
                                          So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                                          Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                                          Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                                          Its a ASUS P5VDZ-MX board.
                                          I would really appreciate some assistance on what the best replacement caps would be for these:
                                          Panasonic(M)...
                                          04-17-2024, 04:25 PM
                                        • HectoPascal
                                          Replacement caps ok? (smoothing caps, PSU heating controller)
                                          by HectoPascal
                                          Hallo,
                                          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                                          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                                          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                                          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                                          Nichicon should be 'VY' series (linked).
                                          I couldn't find anything about Samwha...
                                          09-06-2023, 08:30 PM
                                        • Techboxcomputer
                                          XBOX One S caps value and replacement
                                          by Techboxcomputer
                                          Hi -
                                          I saw there was another post similar to this, but I do not believe he was referring to the same caps I am seeking.
                                          These caps are in the “B” section of the board and the board is marked C9C11, C9C4, C988. The caps appear to be aluminum sheathed and are marked “FP 95 CD 271 16” The Digikey tech's best guess was Nichicon 16v 271 uf but I don't want a guess and solder in the wrong cap. Do any of you know exactly the value of these caps and a good replacement for them?...
                                          12-21-2022, 08:35 AM
