PLP-60-48 Single Output LED Power Supply - "chirping" noise
    • 31298
    did you meter the mosfet out of the board?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      #42
      Originally posted by tester001
      Hi CapLeaker,
      Sorry! I've not been very clear. The removed capacitor is showing resistance of 4-5 MOhm and counting. Unable to get capacitance reading..
      Resistance of a ceramic cap should be infinite, even in the meg-ohms is not normal. Also not normal if you get no capacitance reading.
      Probably it was shorted before but the heating/movement of desoldering it changed things internally.
      -David VanHorn
      • tester001
        Tony
        • Dec 2023
        • 24
        Not yet, as I couldn't identify its model and therefore wasn't sure how to test!
        • tester001
          Tony
          • Dec 2023
          • 24
          So it's not abnormal for the whole circuit (with mosfet and cap removed) to show at its input (the prongs) the resistance I specified (1.795 kOhm and if I switch the probes around it - 34 kOhm)?
            • Jul 2011
            • 6070
            Might be alright with these readings but with out a working board you will not be sure of it unless you get this board working correctly again then you will know what the actual readings should be
              • 31298
              the tab is a connection, the first 3 pins are the second connection, the 4th pin is the gate.
              check resistance between them all - specially from the tab
              • CapLeaker
                Leaking Member
                • 8352
                I am not getting something... first, you had a short on the 2 prongs. You took the Mosfet off, made no diff. Then you took that SMD cap right above the 2 prongs off, now the short is gone on the prongs but the SMD cap isn't shorted? Doesn't make any sense to me.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5095
                  • New Zealand
                  #48
                  SMD ceramics are rather delicate, they can be damaged if you solder them wrong and thermally or physically shock them, it's possible to disturb the short internally or crack the capacitor by desoldering it, especially if done with a soldering iron rather than hot air. Then the short would appear to vanish.
                  I've also had disappearing short circuits on tactile buttons, once the part is desoldered. My guess would be tin whiskers internally on the switch contacts that melted, or similar.
                  -David VanHorn
                    • 31298
                    tactile switches are usually silver plated, maybe the black tarnish that builds on them is conductive.
                    • CapLeaker
                      Leaking Member
                      • 8352
                      Nah… that black stuff makes contacts worse, not better. At work I have sometimes trouble with switches because they use cleaner on them.
                      • FrancescoV
                        Onkyo HT-R390 no sound output, video output ok
                        by FrancescoV
                        Good morning everyone,
                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                        The firmware reported is the following:
                        M:1.00/11107BLP
                        D:?.??/????????
                        O:1.00/11107AL
                        The DSP firmware given the question marks seems corrupt.
                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                        05-11-2025, 02:59 AM
                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                        by sam_sam_sam
                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                        I bought this from an eBay seller but unfortunately they only had one
                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                        I bought three of from them to also make battery packs with this output power limit in mind
                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                        04-23-2025, 05:50 AM
                        Corsair CX750M [Model 75-002019] - burned output toroid inductor
                        by momaka
                        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                        09-19-2021, 08:44 PM
                      • Francesc V.
                        Tele-master AS-20 amplifier. No output sound, just noise
                        by Francesc V.
                        Hi:
                        I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                        I've checked fuses and all are ok.
                        I've continued with capacitors:
                        • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                        • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                        The 4 transitors are perfect. Desoldered and tested individually.
                        There are also components which I don't know exactly what they are....
                        02-16-2023, 07:55 AM
                      • MegaZAC
                        Onkyo TX-SR805 noise in one channel
                        by MegaZAC
                        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                        There's some logic behind it. As soon as I select an input I get only left...
                        04-23-2025, 10:09 PM
