PLP-60-48 Single Output LED Power Supply - "chirping" noise
  • harp
    • Jun 2022
    • 598
    • Planet Earth
    Originally posted by tester001
    I read your '240v is fine - only the wattage matters' as 'voltage doesn't matter'
    LOL, fearless logic...
    • CapLeaker
      Leaking Member
      • 8146
      So you reused that same little board on the new PSU and it’s same thing what it was before? It’s the little board alright. I’d go for the MOSFET, the diode and the two large SMD caps first. If the mosfet is bad, you have to check the gate drive IC as well.
        • Jul 2011
        • 6039
        I was thinking the same thing about the mosfet possibly being shorted I would agree with you about that
          • 31013
          deleted post
          • tester001
            Tony
            • Dec 2023
            • 24
            Based on the overview of the components and its placement within the device, can you tell what the little board does?
            Click image for larger version  Name:	image.png Views:	0 Size:	244.8 KB ID:	3163858
            Click image for larger version  Name:	image.png Views:	0 Size:	1.07 MB ID:	3163860
            For example, if you say that the purpose of the little board is to conver 48V DC (constant current) to 40V DC (as the device specifies), I'd be tempted to replace the board with an equivalent that would bring down the voltage.
            Thank you in advance.
            EDIT:
            I've done a bit of legwork online, and my guess is that the little board is a 48v -> 40v 60W buck converter
              • Jul 2011
              • 6039
              EDIT:
              Thank you for posting this because now it makes sense about what this little board does if the LED light fixture actually works on 40 volts because this not a standard voltage for a switching power supply
              • CapLeaker
                Leaking Member
                • 8146
                It’s a converter all right, but I think it may be a boost converter, not a buck converter, as the inductive coil is before the mosfet, not after. Seeing the PSU itself without this little board is adjustable too, I think, the output voltage of the little board got to be out of range of the PSU itself?
                Make a note of the PSU’s output, make a mark with a waterproof pen on the blue variable resistor right next to the secondary output caps and turn it. The voltage should go up and down. What is the voltage written on these caps on the little board?
                • tester001
                  Tony
                  • Dec 2023
                  • 24
                  It's a converter all right, but I think it may be a boost converter, not a buck converter, as the inductive coil is before the mosfet, not after.
                  Could be! I replaced the little board with this:
                  And set the adjustable power supply to output 40V with 1.5A max. The LED device sprung to life!
                  I ran it for a while in different modes and noted that it didn't draw more than 38W in power (as displayed at the adjustable power supply above).
                  I don't know. But I can confirm that the device works great when fed with 40V 1.5A max, as tested this morning.
                  Make a note of the PSU's output, make a mark with a waterproof pen on the blue variable resistor right next to the secondary output caps and turn it.
                  This is an awesome idea! I can't see that it's allowed in the datasheet, but it might be. Let me try to get 40V out of it..
                  • tester001
                    Tony
                    • Dec 2023
                    • 24
                    Turning the SVR1 knob on the PSU made absolutely no difference to the voltage read on the CN2 outputs - it stayed at 47.8 V
                    What does this resistor actually do?
                      • Jul 2011
                      • 6039
                      If I read the data sheet correctly it would adjust the current not the voltage you would have to have a load on it when you adjust the pot control
                        • Jul 2011
                        • 6039
                        Click image for larger version  Name:	image.png Views:	0 Size:	423.8 KB ID:	3164191
                        Did you try adjusting the buck converter to a slight higher voltage than 40 volts I suspect that your current would go up somewhat as well but do not exceed the current rating of the LED light module otherwise you could damage it if pulls to much current
                        if It bright enough at 40 volts try it at a lower voltage until it gets real dim or LED light bulbs go dark and then increase the voltage until all of the LED lights bulbs are lighting and see what voltage that is then you can determine what is the best voltage to run it at with the least amount of current the LED light module will last longer in the long run
                        • tester001
                          Tony
                          • Dec 2023
                          • 24
                          EDIT: duplicate post
                          • tester001
                            Tony
                            • Dec 2023
                            • 24
                            Do you mean adjusting the output voltage on the adjustable power supply I have posted above?
                            I could, but I usually connect its output to the module that controls the LED - I'm worried that I might damage it if I supply, say, 48 volts instead of 40.
                            Not sure what to do really. I've ordered this buck converter https://www.aliexpress.com/item/1005004336673431.html but I suspect it would crumble when having to deliver 30 W to the LED, even if I install the heatsink.
                            There is no room within the case for a larger, more powerful buck converter or an adjustable Mean Well PSU model that outputs 40v.
                            Whoever designed this device felt that this little board was capable of acting as a reliable buck converter from 48v to 40v at 1.2A, but all models for such spec that I've seen online are much larger and have heatsinks. To make matters worse we can't even identify the mosfet model used - must be some noname chip that is no longer manufactured
                            • tester001
                              Tony
                              • Dec 2023
                              • 24
                              To everyone who has been celebrating - Merry Christmas!
                              With help from colleagues I have desoldered the mosfet from the buck converter board and the resistance across the input terminals is now 159 Ohms.
                              Should it have increased after de-soldering the mosfet if that component was broken? Just trying to understand the logic behind questining the low resistance across the input terminals being a sign of the problem.
                              Thank you!
                              • CapLeaker
                                Leaking Member
                                • 8146
                                Take that mlcc smd capacitor above the 2 pin prong out and check it out of circuit.
                                • tester001
                                  Tony
                                  • Dec 2023
                                  • 24
                                  Thank you for your suggestion!
                                  I've taken the capacitor out of the circuit and the meter fails to get a capacitance reading (I gave it time!):
                                  Click image for larger version  Name:	image.png Views:	0 Size:	563.9 KB ID:	3170293
                                  The resistance across the input prongs of the little board with one polarity is now 1.795 kOhm and if I switch the probes around it is 34 kOhm.
                                  Does this mean anything?
                                  • CapLeaker
                                    Leaking Member
                                    • 8146
                                    Shorted input capacitor. Check the resistance of that cap and you see it has the weird ohms you measured before between these 2 pins. You can just put a regular electrolytic capacitor in its place (keep the polarity of the cap in mind) like 63v or 100v at 10, 22 or 33uF. This circuit should work without this cap too.
                                    • tester001
                                      Tony
                                      • Dec 2023
                                      • 24
                                      Hi CapLeaker,
                                      Sorry! I've not been very clear. The removed capacitor is showing resistance of 4-5 MOhm and counting. Unable to get capacitance reading.
                                      The 1.795 kOhm and if I switch the probes around it is 34 kOhm resistance readings are now across the prongs Click image for larger version
ID:	3170436​ with capacitor removed.
                                      • CapLeaker
                                        Leaking Member
                                        • 8146
                                        Is that mosfet out too?
                                        • tester001
                                          Tony
                                          • Dec 2023
                                          • 24
                                          Yes, Mosfet has been out (as pictured a few posts above) and the little yello cap that was above the prongs is now out too
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
                                            Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                            by momaka
                                            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                            09-19-2021, 08:44 PM
                                          • Francesc V.
                                            Tele-master AS-20 amplifier. No output sound, just noise
                                            by Francesc V.
                                            Hi:
                                            I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                                            I've checked fuses and all are ok.
                                            I've continued with capacitors:
                                            • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                                            • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                                            The 4 transitors are perfect. Desoldered and tested individually.
                                            There are also components which I don't know exactly what they are....
                                            02-16-2023, 07:55 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
