Sightings of failed OST capacitors in power supplies?
  • japlytic
    • Oct 2005
    • 2086
    I have found that an Antec EarthWatts unit uses OST capacitors on http://www.jonnyguru.com/review_deta...=51&page_num=3 and I am considering buying a 380W unit (it is around $80!)
    Are there any reports on failed OST capacitors in power supplies?
  • Galvanized
    • Mar 2006
    • 468
    Re: Sightings of failed OST capacitors in power supplies?
    I can not answer your question about OST failing in PSUs. I do know there was considerable disappointment when OST were found on the secondary side of the FSP Epsilons. The Epsilons (and the OCZ units based on the Epsilon) go out of ATX ripple spec at near full output. Not a good sign.
    jonny was really impressed with the EarthWatts unit and thinks it is about the best 500W unit Antec has on offer. Is $80 OZ dollars a good deal?
    jonny reviewed the Teapo filled Enhance ENP-5150GH (500W) very well indeed and it will Froogle here State-Side for < $80 U$D.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      not yet anyway. what we see with caps is either an early fail (within 1 year) which indicates there is something terribly wrong with the cap or the operating conditions...or a typical late fail (3 years).
      i guess a year has passed since we started seeing ost in psus? but not 3 years. If you are very concerned about caps then choose a unit with good caps.
      • gonzo0815
        • Feb 2006
        • 1600
        That is, what i would suggest.
        Why not buying a good Seasonic unit with all good caps inside?
        • bgavin
          • Jan 2007
          • 1355
          I checked out the Seasonic web site, and only found references to premium caps. No specifics were mentioned, so I wrote asking for them.
          I asked them to consider posting on their web site what they use for "premium capacitors". If they offer any of the Con Sisters (Ruby, Nichi, Chemi, etc), Aunt Panny or Samxon, that would make Seasonic a good source for my needs.
          Newegg sells a number of Seasonic supplies at reasonable prices for those in the USA.
          • Spacedye69
            • Nov 2005
            • 698
            • US
            I just posted a mATX Seasonic for sale. All Chemicon and Rubycon.
            • gonzo0815
              • Feb 2006
              • 1600
              I have recently bought a Seasonic S12 430w, and from a inspection through the fan grill i have seen only Rubycon for the most smaller caps and UCC for the other secondary side caps.
              But keep in kind, that the S12 series is not intended for older not 12v powered systems, but probably you need it for a new rig.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                how much better than S12-500 500W is S12-550 550W ''Energy +'' the difference is 99 to 124 euro. oh wait there is also M12-500 500W at 129 euro
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  have seen a bunch of seasonic super tornado 400 with blown ost.
                  mostly on +12
                  • Galvanized
                    • Mar 2006
                    • 468
                    Originally posted by kc8adu
                    have seen a bunch of seasonic super tornado 400 with blown ost.mostly on +12
                    The most recent review of the Super Tornado that a quick Google brought up was 11/03, so three years of heat ought to do'er. I guess. (I'm not trying to be 'smart'. )
                    Here is the SPCR review of the S12-430 like gonzo has, http://www.silentpcreview.com/article226-page1.html
                    The S12-380 is so close, it's hard to tell the difference. Both are filled with Nipponese caps.
                    Here is the SPCR review of the Enhance ENP-5136GH, 360W unit http://www.silentpcreview.com/article305-page1.html
                    jonnyguru.com reviewed the ENP-5140GH, 400W very well and the 500W Silverstone Element very well. Enhance builds the Elements and Strider series for Silverstone as a budget units. They are good but not as good as Seasonic. They are filled with Teapo with maybe one or two very tiny Jamicon caps.
                    • valvashon
                      Repair Success! Middle Atlantic UPS2200R-IP
                      by valvashon
                      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                      02-06-2024, 12:54 PM
                    • dragon3x
                      by dragon3x
                      power on.
                      Here are some examples :
                      switching supply area).
                      than 6.3 V.)
                      03-21-2025, 02:46 PM
                    • iMic
                      Vintage AT Power Supplies - Selecting Capacitors
                      by iMic
                      Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                      The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                      02-19-2023, 06:45 PM
                    • Yambo
                      Bose L1 Compact Speaker, TOP258 IC blowing
                      by Yambo
                      Hey Folks my first post here,
                      I've recently got a Bose L1 compact sound system in for repair. The unit failed to power up one day.
                      After opening the unit up the first thing I noticed was the TOP258 IC was cracked open. Before replacing the IC I had a look for any other components which might have failed. I checked for the obvious culprits and I couldn't find anything which has failed. I checked the diodes and resistors around the IC, checked the main filter caps and the electrolytics near the IC. Checked the secondary side for any shorts or failed caps and nothing. I checked the...
                      08-10-2021, 01:47 PM
                    • Ady2017
                      Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
                      by Ady2017
                      I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
                      06-06-2025, 08:05 AM
