ANTEC Basiq BP500U - test transformer?
  • GnatGoSplat
    • Jul 2011
    • 50
    I have a blown ANTEC Basiq BP500U. One day I turned it on, and it buzzed loudly and the computer didn't turn on, so I quickly shut off the power switch. Then when I flipped the power switch back on, it blew my house circuit breaker and also its built-in fuse.
    I found both the Active PFC MOSFETs 20N60C3 were shorted. Some of the CapXon caps in the secondary stage were bloated. Secondary rectifiers and switching FETs all tested good. I had to test the rectifiers out of circuit because they looked shorted due to the secondary windings on the transformer. I tried replacing the Active PFC MOSFETs and was able to get a good +5VSB. However, when I powered on the PSU, I heard a brief squeal sound and then it was dead. It shorted one of the MOSFETs I just replaced and blew the fuse.
    Could this be the transformer? Is there any way to test the transformer? The transformer looks shorted when I check it on my ohmmeter, but then a known good one does too so I'm really not sure how to test it.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: ANTEC Basiq BP500U - test transformer?
    The transformer rarely fails. It isn't unheard of, but it's uncommon. Have you replaced the capacitors before changing the active PFC mosfets? Speaking of which, any burn marks on the active PFC coil? That is a lot more likely to fail than the transformer.
    Use a 100W lightbulb in series with the PSU to keep from blowing stuff up. The bulb should glow dimly when the PSU is turned on. If it lights up at full brightness you have a short somewhere.
    A working TV? How boring!
    • GnatGoSplat
      • Jul 2011
      • 50
      No, I hadn't replaced the capacitors yet. I was thinking since they were on the output side, that they would result in poor quality output but not be responsible for the PSU shorting out. I was planning to replace them IF replacing the MOSFETs worked, but it didn't. No burn marks on the active PFC coil. Could that cause this problem? I thought the active PFC circuit has to be functioning to get a good +5VSB, is this not the case?
      I wish I had used the 100W lightbulb! I knew better, I'd always used the bulb in place of the fuse when working on CRT TVs long ago, but this time I was over-confident so I didn't bother to hunt for it. It was a costly mistake, those MOSFETs are expensive.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        On almost all power supplies the 5vsb supply works directly off the mains and only the main supply is behind the active PFC circuit. The reason probably being that the cheap material they use for the PFC inductor runs warm at all times and needs the cooling provided by the fan.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Check the main 400v cap. They usually don't give problems, but in APFC PSUs they can. If I remember correctly, there were a few cases here on BCN where people actually had the APFC fail due to CapXon (or was it OST?) mains caps going open-circuit. Either way, it's definitely worth checking if you have a capacitance meter.
          • GnatGoSplat
            • Jul 2011
            • 50
            I could almost swear I had checked it before, but I re-checked the 400V cap and it is completely open. No capacitance, no ESR.
            It's a CapXon. If this cap goes open, is it typical that it should immediately short the MOSFETs?
            • c_hegge
              • Sep 2009
              • 5219
              Considering that no cap means that the voltage from the PFC won't be filtered, it wouldn't surprise me.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Yes. Because the energy in the PFC inductor now has nowhere to go.
                • GnatGoSplat
                  • Jul 2011
                  • 50
                  Thanks, I believe that was it.
                  One of the MOSFETs was still good, so I removed the shorted one and temporarily installed a 390uF cap, this time using the 100W bulb instead of a fuse. The PSU was able to come on with no load and I checked all voltages, +3.3V, +12V, +5V, -12V, all look good.
                  There is still a slight squealing sound which could be due to the bad caps in the secondary stage, will they still squeal with no load?
                  I've also noticed significant inrush current that lights up the bulb pretty bright for about 2-3 seconds when the PSU is cold, but only a split second if the PSU hasn't been off long. Is this normal behavior?
                  Also, how critical is the capacitance of the main cap? 390uF worked, but the original was 330uF. Newer versions of this PSU use 390uF, but I assume that cap is matched to the coil, and the newer versions do use a slightly different coil. If it's not critical, would there be any benefit to a larger cap?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Power supplies will generally squeal when there is no load, if it squeals under load it means there's something wrong with the compensation of the control circuit. And yes it is common for bad caps to cause squealing because they change the properties of the output filter when they go bad.
                    The inrush current is normal. The power supply has a NTC thermistor after the fuse, which deals with this. It has a high initial resistance thus limiting the inrush, then when it heats up its resistance becomes insignificant. By contrast, a bulb acts as a PTC thermistor - its initial resistance is very low, and the higher the current passed thru it, the brighter it will light, and the more it will limit.
                    The cap value isn't critical - a larger cap can only improve things. The only downside to a larger cap is that it'll take longer to charge from a cold start - therefore you get a higher inrush current. If your house electrical is wired properly this is no reason to worry. After all, it's not like this is a washing machine or anything.
                    • GnatGoSplat
                      • Jul 2011
                      • 50
                      Thanks, I think all I need now that I'm confident it's fixable is one MOSFET, fuse, and to recap it.
                      This PSU lasted maybe 1-year, but was out of warranty due to having been stored for some time before use. It looks like CapXOns used in this PSU don't last, so I'll try to get some good ones that hopefully won't cost too much and exceed the cost of a new PSU.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Post the series and sizes of those Capxons, and state your location in your profile. That way we can recommend some proper replacements and a parts distributor in your area. If you're in the US you can help support this site and buy from the badcaps.net online store.
                        • GnatGoSplat
                          • Jul 2011
                          • 50
                          I'm in the USA, it looks like only 2 of the caps in the secondary were swollen, I checked ESR and the non-swollen ones look okay, at least in-circuit. The 2 swollen ones test bad, they are both CapXon 2200uF 6.3V KF 105C, both on the 3.3V rail. Main is a CapXon 330uF 400V LP VENT 85C.
                          Other than that, I will need a T8AH250V ceramic fuse with solder leads and one 20N60C3 MOSFET, TO-220FP (insulated).
                          MOSFET will be hardest to find, they are OOS at Digi-Key and Mouser, I may have to pay extra to buy one from eBay unless I either try to cross-ref it to something else or use a standard TO-220 and insulator kit.
                          If I use a different MOSFET, do I need to try to match the RDS(on), delay, rise or fall times? Since they are in parallel, I wonder if it's critical that they load balance properly.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I don't think topcat sells suitable replacements for them. These would probably work. Replace ALL capxon caps, bloated or not. In-circuit tests are unreliable and capxon are pure junk. Even if they are OK now, the won't be for much longer
                            NEVER use two different MOSFETs in a PSU. If you're gonna replace one with a diferent one, replace the other two. It is indeed critical that they balance properly.
                            • GnatGoSplat
                              • Jul 2011
                              • 50
                              Got my new parts from Digi-Key today, caps replaced with Nichicon HM (HE series were a bit too large diameter). Main line cap replaced with a 390uF 420V 105C Panasonic TS-HC. I had to use an uninsulated SPP20N60C3 MOSFET and a mica insulating kit because I couldn't find a SPA20N60C3 insulated, but it's electrically the same anyway.
                              So far so good, it's been running a few hours now.
                              Thanks for all the help! Wish I had as much luck with my FSP PSU.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                That's a bit of a problem.
                                The ESR of Nichicon HM is way much lower than the CapXon KF. While your power supply may *seem* to work fine, it is most likely outputting a lot more ripple than it should. The reason behind that is because the caps in a power supply are matched with the inductors - they create a tuned circuit that is specifically built to filter noise from the power supply. Change the ESR too much and you can actually make ripple and noise worse than it was with the original crap caps. And generally speaking, Nichicon HM isn't suitable for power supplies.
                                Most motherboards are built fairly tough (in terms of how much ripple and noise they can handle before becoming unstable) and probably won't have a problem if there is extra ripple. But if you ever test a more picky motherboard, you may run into stability issues.
                                At least the new HMs won't give you any trouble in terms of reliability, though.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I've run into FSP's with 8mm 2200uF KF and HM was the only option due to space.
                                  I think the early Basiqs were FSP and he may have the same problem.
                                  IIRC, the KF's were also extra long so the ESR would be lower than 'stock' KF in the data sheet.
                                  Kind of the same situation as the damned 10mm 4700uF Fuhjyyus.
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • GnatGoSplat
                                    • Jul 2011
                                    • 50
                                    Yep, that's right, I needed 8mm. I may have to check the ripple next time I drag out the o-scope. Everything looks good and well within spec according to OCCT, but I don't know that the health monitor chip and OCCT has a good enough sample rate to accurately measure ripple (I'm gonna guess the answer is probably not).
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Nope it doesn't. It's for DC. Response is way too slow.
                                      - Dr Seuss
                                      • learnmore
                                        Help choosing replacement transformer for Levoit 600S SMPS
                                        by learnmore
                                        Hello Community,
                                        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                        Peace
                                        LM...
                                        11-04-2025, 09:35 AM
                                      • chth96
                                        How Can I test PWM DM0365R?
                                        by chth96
                                        Hello
                                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                        06-18-2025, 04:14 PM
                                      • ohren
                                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                        by ohren
                                        Hello!
                                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                        Measured voltages with no load:
                                        After rectifier diodes
                                        12V: 6.17 V
                                        5V: 5.67 V
                                        Secondary transformer pins AC measurement (really don't know if this says anything)
                                        12V: 2-2.5 V
                                        5V: 1.04 V
                                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                        03-18-2023, 10:33 AM
                                      • khelane
                                        test active pfc power with lamp test
                                        by khelane
                                        Hello
                                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                        Is there a way...
                                        06-03-2025, 01:00 AM
                                      • chronic519
                                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                        by chronic519
                                        Hello.
                                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                        Found issue with a RAM block
                                        Replaced, green lines gone.
                                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                        Used a good card to test and same results low errors 32+.
                                        I am just search for some form of command to do a full test on the GPU.
                                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                                        The repaired one, ran...
                                        05-20-2025, 07:56 PM
