PSU fet sink hot when off
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i have noticed that my chieftec psu hpc-360-202 has the fet heatsink next to the primary caps being really hot when the computer is plugged in but off.
    how hot is it? well you couldnt touch it for too long.
    is that something i should worry about?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: PSU fet sink hot when off
    How long has the P/S been off? If the +5V Stby regulator (or switch device) is on that heatsink, how long has the power cord been unplugged. From your description, it sounds like the heatsink temp is about 55C-60C, so if it hasn't been off very long, that might be normal. Or your fan-speed regulator may not be responding to temperature and running the fan too slow.
    PeteS in CA
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      hmm i didnt think of that . i will check in the morning if i made that mistake. would be nice to have a circuit to run the fans for 15mins after shutdown like the cars.
      fan-reg is bypassed since this afternoon, it is getting 12v only now with new powerful pelko fan. exhaust is now cool but unfortunately i have found source for delta EHE fans so i think i will get a new cheapo case and run 2x120mm EHE and 1x80mm EHE for the psu.
      i think my music is in excess of 65db so we are probably ok for the gaming rig
      • PeteS in CA
        • Aug 2005
        • 3581
        Any helpful info here, willa?
        PeteS in CA
        • larrymoencurly
          • Oct 2004
          • 960
          Did you measure the DC voltage between the heatsink and ground before touching it? Because some of those heatsinks have over 160VDC on them, as I've found with Delta, Antec SmartPower, Enermax, and Leadman/Powmax/Raidmax.
          I don't know how much heat the power transistor of the standby regulator puts out, but I doubt that it's enough to make the big heatsink very hot because otherwise there wouldn't be so many of those transistors separate from that heatsink with just a small piece of aluminum attached to them.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            https://www.badcaps.net/forum/showthread.php?t=1306
            Ludicrous gibs!
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              wb dood thanks for the link.
              ok the heatsink is indeed hot even after the comp was left off overnight. actually i can only find medical thermometers in the house at the moment. the digital one informs me that my psu has a fever . the analog read its maximum 42oC. so i guess it is like pete said
              anyway like Rainbow said on the link and pete said here i guess it is normal. it is just suprising.
              The heatsink measured to ground 156vdc like larry said.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                now you know what to touch for your daily electroshock therapy
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  dammit how did you find out about that?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Maybe like this? :P
                    https://www.badcaps.net/forum/showpo...94&postcount=4
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      no i wanted to know how he found out about my daily electroshock therapy
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        we have ways of finding out....
                        • arneson
                          • Sep 2005
                          • 1267
                          I like the IGEA Electrosage machine "as seen on TV".
                          Just don't hook up to your balls.
                          Jim
                          • harp
                            Metod for removing glued heatsink from fragile component
                            by harp
                            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                            06-23-2025, 02:01 PM
                          • Ven
                            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                            by Ven
                            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                            07-08-2024, 09:32 AM
                          • harp
                            can fanless heatsink replace poor original on RX26PG2
                            by harp
                            I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                            06-25-2025, 10:56 AM
                          • szreder6
                            HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                            by szreder6
                            Hello guys,
                            I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                            What I did:
                            - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                            As far as I know the laptop was in another service center...
                            11-22-2024, 05:17 PM
                            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                            Securing a good thermal interface between...
                            10-07-2024, 04:35 AM
