Raidmax RX-380K (ky-480atx)
  • bsweasel
    • Jun 2010
    • 82
    So I have this Raidmax SMPS (I know yuck), but I would kinda like to revive it. I've been poking around with my novice skills and am a bit lost. I only has +5v standby power, nothing else. I've replaced some caps that failed my ESR tests, checked the mosfets on the secondary side. Check some diodes and resisters in the area near the hot zone around the mosfets. still no go. Looking for some expert guidance if anyone can help me.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Raidmax RX-380K (ky-480atx)
    Throw it away. It's really not worth it. If you want the educational experience, choose a "not as crap" crap brand to rebuild, putting parts into these low end sunpro units is kind of pointless as they are just terrible no matter what.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Primary side switching transistors (usually 13007s on this kind of units) failed open. Very common failure mode. But agreed with 370forlife - they are junk.
      A working TV? How boring!
      • bsweasel
        • Jun 2010
        • 82
        I don't dispute they are junk, but it is the only one I have to work on, and it is exactly what 370forlife says, an "educational experience". I was just testing the 13007k and found one that reads both ways....so I'm assuming this is the bad one...Now I just need to find a donor....I'm surely not going to spend any money on new parts for this pile.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          If one is indeed shorted, the other one is guaranteed open. When the primary side isn't working but the fuse hasn't blown, it always means that at least one primary switch has failed open circuit.
          • bsweasel
            • Jun 2010
            • 82
            The Unique, your right! It was the 13007, I found a donor, tested the 13007 and it was good. I slapped it in and it fires up. So, no money spent, all donar parts. 4 caps, 2 transistors. I spent some time testing and poking, but it was worth it just in learning and practicing my testing skills. Now yes I realize I brought back to life a complete pile. But it will be a good backup PSU in a pinch. Thanks for the tips guys! This is why I love this site and its forums.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Yes, a good back up PSU in case you use a really crappy one and it doesn't kill your computer. Then you can put this one in there and make sure it definitely kills your computer.
              No seriously, don't use this power supply in any computer, ever. It's just asking for trouble.
              If you want, keep it for parts or use it only to test electronics that don't care much about ripple (such as motors, lamps, etc.)
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Cheap power supplies that can be somehow decent after some modifications and recap are very easy to get.
                That raidmax is NOT one of them!
                • c_hegge
                  • Sep 2009
                  • 5219
                  I love using cheapies for fireworks. It's easy now that I have a load tester.
                  • BlackScreen_22
                    Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                    by BlackScreen_22
                    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                    I had no problems connecting mosfets and capacitors,...
                    08-27-2024, 12:46 PM
                  • kotel studios
                    Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                    by kotel studios
                    Finally got time to fix this board up.
                    At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                    Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                    04-22-2025, 05:08 AM
                  • DrDos
                    kenwood kr-6030 Mosfets?????
                    by DrDos
                    Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                    09-20-2025, 04:42 PM
                  • flerre
                    Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                    by flerre
                    Hi!
                    Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                    No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                    So, could I safely assume all of these 3 mosfets are...
                    03-13-2022, 12:14 PM
                  • NanoTesting
                    Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                    by NanoTesting
                    I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                    With charger it turns on, fan spins but gives no image.
                    Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                    Reflashed BIOS, same problem.
                    Replaced both main mosfets.
                    Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                    10-30-2024, 10:48 PM
