List of power supplies manufactured by Deer/L&C - post them here
    Last night, I opened a Vogue 230W AT supply, and it had "DEER" on the PCB.
    My current sightings of Deer/L&C supplies are:
    FRD (uses L&C model numbers)
    Sky Hawk
    Vogue (as mentioned before)
    If you have any other units manufactured by Deer/L&C (look for "DEER" on the PCB or an L&C-style model number e.g. LC-B400ATX), list them here!
    Re: List of power supplies manufactured by Deer/L&C - post them here
    Deer is all over the place - here's a few more: Allied, Austin, Eagle, Duro, Mustang, US-Can, Turbolink (some models), and Tsunami.
      Allied are by Deer? Damn... no wonder we had one die at the school, 2 months after being put into service. Warranty covered it and we got a new one from newegg...
      Ludicrous gibs!
        EagleTec
        TMP-ANS
        The great capacitor showdown!
          Greenline. I haven't seen one of these in about four years though.
            Originally posted by dood
            Allied are by Deer?
            Yup, though I will say they looked to be a little better in quality than most of Deer's other aliases last time I saw one. IIRC Allied and L&C are actual Deer owned companies.
              Hyena, Foxconn (supplier to them), Foxlink, Codegen, L&C, Logic
                Codegen? Sh!t. I bought a Codegen 400w 12cm fan one for $18 a few weeks ago to replace an EVER 250w with failed fan.
                  No! Not Codegen! I'm striking out big-time here. I just built a system for my uncle with a Codegen supply, that came in a Codegen case. It's running an Athlon64 3000+, I think. So far, no stability problems, but he doesn't use his desktop all that much... favors the laptop (perhaps a good thing, now )
                  Ludicrous gibs!
                    Just FYI it does not need to say "Deer" on the PCB, my L&C says "DR-ASIC ATX Ver:1.0B"
                      Were those Codegen power supplies heavy?
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                        Newbie- dunno... it came pre-installed in the case I bought for the system. So, I'm guessing "no" is the answer
                        Ludicrous gibs!
                          Newbie2 - It wasn't so heavy - about 2lbs iirc.
                            Keep in mind not all Codegen's and Skyhaws are Deer. These are completely separate companies from Foxconn Deer.
                            I dare say that I've seen some pretty decent Skyhawks.. none of them were made by Deer, of course.
                            What's ironic is Deer is a "partner" of Foxconn, but when Foxconn needs a decent power supply, they turn to Lite-On.
                            Rest in peace BFG. You were... a job...
                              Or Channel Well
                              Welcome aboard btw
                                Thanks. I come in here and do a head count and I'm like, "OKW's here. LarryMoeCurly, MDW are here..." WTF?!? I already know everyone in here from other forums!!!!
                                  ...lol...
                                  Welcome aboard Jonny
                                  Ya'll think us folk from the country's real funny-like, dontcha?
                                  The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                                    Zebronics, model LC-200C 200W AT with a 2003 sticker.. It's stuffed with those caps with a logo that looks like the planet Saturn and its ring, as well as a few Jun Fus (mostly smaller values). The primary-side mains filter is missing several components. The largest secondary cap is 1000uF, 16v and it's 10mm, packed tight - not much scope for putting larger/better caps here. No proprietary ICs here - it uses the stock TL494/LM339 combo that first showed up 17 years ago in AT PSUs - the designer of that configuration must be a genius, if nobody has been able to improve on it in all these years.
                                      Both chips have been around since the 70s, and, obviously, are used a lot some 30 years later. Some things are just good enough that improved versions end up being confined to specialized products/marketplaces. If you check the switch devices in TL494-based P/Ss, you'll probably find that many of them are transistors instead of MOSFETs. Some of the ones I've seen, the P/N has some prefix, followed by "13007". This means that it is a transistor that is a copy of a part Motorola introduced in the late 70s or early 80s, the MJE1300x series.
                                      PeteS in CA
                                        Today I found a "JPAC", model 500ATX, that had the classic signs of L&C-ness...
                                        It was marked as a 500W power supply. The primary caps are 470uf 200v Canicons. All the components inside were pretty cheesy-looking (seemed 30% of the PCB was bare with only silkscreens showing where components should have gone!) and the wires and heatsinks thin almost to the point of being flimsy. It used a mixture of Canicon and 'Seacon' caps of widely varying (mostly low) values. Personally I wouldn't use this thing even for 200W, it looks so lame.
                                        Sorry I can't provide pictures (yet)...
                                        The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
                                        I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
