list of PS5 Internal Fuses
This is a sticky topic.
  • MarkRocket
    • Jan 2020
    • 17
    This is not a definitive list, and I do not claim if it is 100% accurate so please do your own research, based on the information from littlefuse, RS, Farnell and a few other places, using information about the markings on the fuses
    Please feel free to distribute, amend, correct, etc
  • BwE
    • Dec 2024
    • 12
    Or use the schematics?
    • MarkRocket
      • Jan 2020
      • 17
      Yes, or course use schematics, but I personally don't have them and didn't realise they were available.
      • adamski1952
        • Oct 2021
        • 108
        • england
        If schematics are available please share.
        • Saiyaman45
          • Mar 2024
          • 8
          • Fix Electronic, Paintball,
          I have not schematics, but check this, may can help you...
          • MarkRocket
            • Jan 2020
            • 17
            Thank you very much Saiyaman45​, what program is used to open the PCB files, I have RIMU for Windows, but it errors saying it can't open the file
            • ourlissene
              • Jan 2021
              • France
              Thank you very much
              • vojo
                • Apr 2025
                • thailand
                • Boardview and Schematic Bot
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • PatElectron
                  Denon AVR-X1400H — no audio from any source, internal test tone OK, no HDMI output, "Assigning" phase at every boot
                  by PatElectron
                  I bought this AVR-X1400H (E2, Europe) cheap as faulty, to repair. Seller said it died suddenly: no sound, no picture, headphones silent too. I have the service manual and a **working AVR-X1500H** on the bench as a reference. I've done a fairly complete diagnostic already — full details below so nobody wastes time on ground I've covered.
                  Symptoms
                  - No audio from any source: HDMI, USB, network/HEOS, analog IN1 and IN2, tuner. Nothing, on any input.
                  - The internal DSP test tone plays correctly** through the speakers, on every channel.
                  - No...
                  09-10-2026, 09:11 AM
                • Sik_6ty_Sixx
                  HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                  by Sik_6ty_Sixx
                  So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                  02-18-2025, 05:06 AM
                  Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                  12-14-2023, 07:45 PM
                • Giggle2562
                  Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                  by Giggle2562
                  I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                  The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                  Here's what I've tried so far:
                  • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                  • The laptop shows an image on the internal display for a few seconds before it shuts down.
                  • I tried swapping the LCD panel with a known good one.
                  • I tried swapping the LCD cable
                  11-06-2025, 12:36 PM
