My turn to fix my PSU. Silverstone 350W
  • Wizard
    • Mar 2008
    • 2296
    Bloated 1000uF 10V Teapo in 5V standby output. Made mainboard's standby LED to blink, blink continuously. Swapped in Samxon XLR 1000uF 16V and changed other two 47uF 50V just in case in hot side of 5V standby circuit.
    Other capacitors are jamicon and Teapo on all the outputs are fine.
    The 120mm fan is ADDA and still spinning fine, designer/maker of PSU is enhance.
    Cheers, Wizard
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: My turn to fix my PSU. Silverstone 350W
    Post some photos
    • Wizard
      • Mar 2008
      • 2296
      No need to snap whole PSU. Those details I told you already is sufficient and PSU is pre-ROHS and year on the PCB is not right. Actually bought 4 years ago.
      No power correction at all and 115V only. Dual big chopper transistors and group regulation. The rest of stand-up circuity is removed for this repair and this photo before I reassembled the PSU and returned to service with no issues.
      Yearly dusting do HELPS with keeping PSU cool and long life.
      Cheers, Wizard
      • c_hegge
        • Sep 2009
        • 5219
        You poly-modded the PSU?
        • Scenic
          o.O
          • Sep 2007
          • 2642
          i see samwha
          edit: and engrish
          • Wizard
            • Mar 2008
            • 2296
            Hehehe, I know my english is not my strong point and I have to redo several time on writing, I'm deaf guy but you should see that I do have full-time job repairing TVs.
            Regarding Samxon capacitors, they are good one. And this is biggest reason for strictly sourcing these we do not like buying stuff from multiple suppliers and especially from USA due to shipping and customs taxes & broker fees.
            I do not understand the surprise and disgust of Samxon, actually is good one as long as you get them from trusted sources and all of you have good sources right here and use correct series in specific applications. So far, with our work, there is NO callbacks with Samxon capacitors in TVs, electronics and other stuff for 2 years now. Ones that co-coworker against my advice used generic capacitors and came back bloated again, no ifs or buts. And I do not use GF either due to fakes and one of my source is concerned about those Samxon fakes.
            There are many good and high end PSUs using polymer capacitors these days. So what?, do your research. Don't be acting like a deer standing there outlined by headlights.
            PS: I should scold you for playing bait, this is not samwha capacitors, I got these polymer ULR line from King of Cap King to try them out at Joe's urging when I put in capacitor resupply order and are genuinely Samxon's. I corrected to ULR not XLR, I misremembered, my apologies.
            Cheers, Wizard
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              He means samwha, not samxon. I see them on the right in that picture next to that big resistor there.
              • Wizard
                • Mar 2008
                • 2296
                Nope. ULR line from Samxon. I know the other smaller two is not polymer, I do not have any in 47uF 50V and I did test them before reusing them, I know these are Samwha. I have no problem with these. Keep in mind Shawha is very *specific* batch run were bad that caused capacitors to bloat while rest are fine.
                Cheers, Wizard
                • Wizard
                  • Mar 2008
                  • 2296
                  Oh yes, I maintain my plymouth voyager 1987 caravan. Yes ditto rebuilding a 2.5L and swap old sick 2.2L once I have enough money.
                  Cheers, Wizard
                  • POM_MJ
                    • Aug 2009
                    • 228
                    Cheers, Wizard
                    Agreed, ULR is polymer from X-CON (Samxon) http://capacitor.web.fc2.com/solidcapacitor.html#xcon
                    Good job there, I will do polymod my PSU like that soon.
                    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      uhm.. with engrish i meant the fuse text at the bottom of the PCB... not your post
                      • Wizard
                        • Mar 2008
                        • 2296
                        Hahaha. Now I get that.
                        Cheers, Wizard
                        • b700029
                          Banned
                          • Sep 2010
                          • 640
                          Whoever drew the board probably thought "this text is too long to fit... so I'll just cut off some piece of it". I have no idea why they even keep that message since almost no one is going to read it 99% of the time.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Personally, I don't like the idea of poly-moddiong a PSU, since the PI filters are tuned to the ESR of the original caps. Polys will have a significantly lower ESR, which will make the ripple a lot worse. PSUs which have polymer caps when new can function that way because they were designed around polys.
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              Bingo.
                              "pokemon go... to hell!"
                              EOL it...
                              All style and no substance.
                              guilty,guilty,guilty,guilty!
                              guilty of being cheap-made!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Personally, I don't like the idea of poly-moddiong a PSU since the PI filters are tuned to the ESR of the original caps.
                                But the standby switcher is usually of the self-oscillating type. Therefore it tunes itself to the output filter, not the other way around. Also if you really want to get a technical explanation, it's the control loop that is tuned for a specific filter. Changing the caps with drastically different ones could cause the control loop to oscillate.
                                A working TV? How boring!
                                • PNI E.
                                  Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                  by PNI E.
                                  Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                  03-17-2025, 04:23 AM
                                • madsox
                                  Harman Kardon AVR 171S - standby led lights up, does not turn on
                                  by madsox
                                  Greetings!
                                  Thank you in advance for your understanding, I am writing to you through a translator.
                                  A Harman Kardon AVR171S amplifier was given.
                                  The history of the machine is as follows:
                                  It was faulty when I bought it, I want to fix it.
                                  I replaced the HDMI switch and one of the DAC ICs in it.
                                  After that it worked without a problem.
                                  I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                  The cooling was faulty, I will fix this later.
                                  I switched it to standby mode, waited for...
                                  09-24-2022, 10:46 AM
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • Doodle43
                                  Samsung LN32B540 - won’t turn on but gets standby power
                                  by Doodle43
                                  My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                  It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                  05-26-2020, 12:02 PM
                                • Adenitz
                                  Troubleshooting Vestel TV, has standby, but cannot turn ON
                                  by Adenitz
                                  I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                  Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                  Both boards are shown in the attached photos.
                                  What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                  12-27-2023, 03:43 AM
