Noname 350w dead
  • bluebear
    • 90
    Noname 350w dead
    Hi!
    I have this unknown PSU that seems to be dead. When shorting green with black the fan twitches but nothing more. My CD drive, also hooked up, LED glows for under a second and then turns off again. Repetitive shorting makes it blink, if you understand what I mean.
    I have checked all condensators with ESR and they seem fine.
    Input side are HEC 680uF and the rest are nicon brand.
    No bulging or leaking. Sad really as i hoped to find something wrong.
    I moved on to didoes, schottky and rectifier on output side. All seems ok.
    One coil on the output side seems to have been slightly overheated since some glue on top of it has turned black.
    It has three IC:
    WT751002 monitoring voltage on the output side
    DM311 FS
    UC3843A High Performance currrent mode PWM controller
    Any pointer would be appreciated. Pictures attached and IC datasheet.
  • everell
    • Jan 2009
    • 1514
    Re: Noname 350w dead
    First step, let's see if the 5vsb is working correctly. you will need to plug the power supply in to ac wall outlet. You don't need to short green and black wire to turn on power supply. Just measure between the violet wire and one of the black wires. You should get 5 volts.
    When working with a power supply out of the case, be very careful. Best to wear safety glasses as sometimes parts explode.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • bluebear
      • 90
      Sry, missed to write that down. I had already measured +5vsb and it was
      5.04v so its ok.
      Hehe, thanks for the hint. I´m going commando at the moment
      I might also say that the reason I don´t know the brand or wattage is because the sticker is missing (torn away). On the pcb it is written "atxl-350p 2008".
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Omg! That power supply looks identical to that Konig that I have:
        https://www.badcaps.net/forum/showthread.php?t=10076
        It has Nicon caps, DM311 for 5vsb and the same WT751002 monitoring ic.
        My power supply had the same problem with yours. 5vsb was ok but the psu acted like shorted when green wire was shorted with ground.
        I checked every cap, schottky and mosfet and found nothing bad.
        Finally, I replaced the big toroid coil that had some burnt glue on it with another one that I found from a dead power supply:
        https://www.badcaps.net/forum/attach...2&d=1280409453
        Then the psu worked! I fully recapped it, fan-modded it to run cooler and added some parts to make the input filter complete and there it is:
        https://www.badcaps.net/forum/showpo...7&postcount=24
        • bluebear
          • 90
          Agree!
          It looks very much the same. I´m switching the coil tomorrow.
          Thanks for the hint goodpsusearch!
          • bluebear
            • 90
            Switched with a coil that looked like the one I have.
            No change, still dead with a fan twitch. I will most likely switch back to the original coil.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              I'm sorry that didn't work for you...
              You say you have already tried to power it with load connected to it..
              I would check the solder side and every output rail for possible shorts.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                ........ with load connected to it
                Mann-Made Global Warming.
                - Dr Seuss
                • bluebear
                  • 90
                  I have always tried with a cdrom and a hdd connected. Made a test with moterboard hooked up today, still no dice.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4981
                    • New Zealand
                    Perhaps the glue has gone conductive and shorted something out. Have you tried removing the glue?
                    -David VanHorn
                    • everell
                      • Jan 2009
                      • 1514
                      I have built a handy tester for troubleshooting power supplies. See this thread:
                      https://www.badcaps.net/forum/showth...hlight=everell
                      When using this tester, you will notice that when the fan twitches, the LEDs also blink. In my experience, when you have problems on the primary side (switching transistors, mains capacitors, bad transformer) the LEDs don't blink, and fan doesn't twitch. When LEDs do blink, problems are usually on the output side.
                      Sometimes, one of the LEDs doesn't blink, but the others do. The nonblinking one points to which rail is giving the problem. I have fixed several psu which had 3.3 volt rail not blinking, and the regulating transistor in the 3.3 volt circuit was the culprit.
                      • bluebear
                        • 90
                        I know this is very late, but things came between. I checked and both 12v and 5v comes up, but 3.3v doesn´t. I will check the regulating transistor. Any idea where it could be?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          It's on the secondary heatsink next to the 12v and 5v schottkys.
                          A working TV? How boring!
                          • bluebear
                            • 90
                            2x SB20100CT Dual Schottky barrier rectifier 20A (12v)
                            2x STPS 2045CT Schottky diode 10A (5v)
                            1x MOSPEC S30D45C Dual Schottky barrier rectifier 30A (3.3v)
                            No voltage regulator, is the S30D45C acting as one?
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              I don't think switchmode PSUs typically have any regulators on the output. Just the rectifiers and then some filtering capacitors etc.
                              The voltage control is done by the main controller IC that takes feedback from some or all of the rails.
                              I would check that S30D45C for being open-circuit.
                              -David VanHorn
                              • bluebear
                                • 90
                                Yes, you are right! Can´t belive how i could have missed this.
                                Its short on all legs. Have to find a replacment then. Not that easy.
                                Edit: Could this be the right stuff?
                                http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1728wt_1306
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4981
                                  • New Zealand
                                  Looking at the datasheets it should be OK.
                                  If anything the Vishay looks slightly better on paper than the Mospec.
                                  Maybe a bit expensive for just one PSU but then you are getting 10 of them so not a bad deal.
                                  I think though these rectifiers are fairly generic so anything with the same or better specifications should work...
                                  -David VanHorn
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I think that it will be fine. The only thing to bear in mind it that it could be physically bigger than the original, so you may have to bend the two outer legs inward slightly, but it will still work. I did that when I re-built my 400W Rexpower PSU with both the 5v and 3.3v rectifiers and the primary switching transistors.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      When you have to bend leads for a different spacing make sure they fit smoothly into the holes so the leads are not being pulled to the side in the cap's bung once it's mounted.
                                      Want no side pressure on the rubber.
                                      Can cause leaks over time.
                                      - Dr Seuss
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Some do, some don't. The ones with the second coil for the 3.3v rail have one, but it's still a switching regulator. It's called a "magamp regulator" and it uses the coil as both energy storage AND the control element. There is a second coil in that PSU - you typically find a 40A MOSFET for the 3.3v rail.
