ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
  • feliks912
    • Jul 2020
    • 5
    • Croatia
    Attached schematic šŸ™‚.
    Laptop gives no signs of life. No fan and no CPU heat.
    Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
    Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
    Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
    What do you guys think happened? I've got two theories:
    If the think engine shorted to ground first, how could have it caused the 5v low side FET to fault by shorting to ground? Those things rarely if ever happen on current controlled PMICs. One speculation I have, is the sudden voltage increase on the node pin due to current increase EMI. If the normal load is ~800mohms, and the short is ~200mohms, then the combination is ~160mohms which at 5v is ~30A of current. This is a change of 24 amps in what, like 2 micro seconds on that line. U = -L di / dt that's high. If this happened during the low-high dead time, the voltage on the node would have skyrocketed and possibly shorted the FET. Note how this doesn't make sense, since all di current would have been supplied through output capacitors at first, increasing the dt. Also, the timing would have to have been PERFECT, with the short happening at exactly the half H-bridge dead time. At 60kHz that's ~1.6us.
    Mind you, the 3v3 LDO of that same 5V PMIC was also shorted to ground, even though there is only one resistor to one mosfet on it (first time seeing that happen). That means the chip either uses the common leads for the voltages internally, or multiple 'compartments' got damaged at once. I'd go with the second one.
    The second possibility is the low side FET dies first, and the ThinkEngine IC keeps getting digital signals from other ICs. Every IO pin on a chip has 2 diodes in reverse polarity to GND and VCC. If VCC = GND then we have a diode between any pin straight to GND (this is a probable cause if the IC stayed half-functional). The combined current from communication and other logical nonsense slowly cooked the chip over time until something went off.
    The funny thing is how that same IC turns the input power FETs so it had to be functional at first, although very hot to the touch. Well, after leaving it on for a minute or two I heard a high pitch inductor resonance sound which lasted for good 30 seconds then came down. After that no power has been distributed on the board, and no signal has been sent to power the FETs on (main PMIC did, but ThinkEngine didn't) so ThinkEngine is dead too.
    Ordered both the BD4179MWV and NB690GRP from AliExpress. Now we're waiting. Do You think replacing them should work? EC seems fine.
    NOTE how if the above is correct, I can't test either components separately. I MUST soldier them both on and test at once. Otherwise it either won't work, or it will cook the chip again.
    What are Your thoughts people? I might edit this to add screenshots from the schematic tomorrow.
    Any experiences? This is my most complex issue so far.
    Thank you,
    Feliks
    2
    I think ThinkEngine shorted first
    50.00%
    1
    I think 5V SMIC shorted first
    0%
    0
    I think something else happened
    50.00%
    1
    • 21635
    LINK to schematic --> https://www.badcaps.net/forum/troubl...rdview-request
    • mon2
      • 14632
      Are you testing with a Low ESR meter? Which meter was used for these measurements?
      Rare to see resistance in milli-ohm measurements.
      • feliks912
        • Jul 2020
        • 5
        • Croatia
        mon2 glad to see You reply. Your posts show rare expertise... that 5 volt line is capable of pulling 6 amps on full load as per the schematic. It doesn't mean it DID pull that much, but for speculation I assumed it did as most issues occur at full load. 5 volts / 6 amps ~= 800 mohm. The short is between the regulator and ThinkEngine IC, around 200m ohm -ish measured with a UNI-T multimeter +- 100mohms from experience
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
        • adelfr2009
          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
          by adelfr2009
          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
          09-28-2025, 10:21 PM
          Lenovo ThinkPad T490 Notebook T Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490 boardview and T490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
          09-06-2024, 04:10 PM
