Just couldn't resist....here is a Dynex DX-PS300W.......with cover removed!
Do no remove this cover under any circumstances
Re: Do no remove this cover under any circumstances
I've seen worse.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
I was referring to the writing on the label on the case. It says "Do not remove this cover under any circumstances". LOL! Once inside it is just a cheapo half bridge configuration with KA7500 pwm chip, 2 transistor 5vsb circuit, and primary caps are 330 uF. I doubt that it would stand up to 300 watts.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
"Fan controlled Power Supply"?
So, the fan controls the psu?Comment
KA7500 is TL494 under a different name.
It has good input filtering, lots of heatshrinking, good quality soldering, output filtering and perhaps what I see even 5Vsb made with a linear regulator. It even has a fan connector, very nice. Shielded caps from input transitors/Fets and an input switch. LM339 for Overvoltage protection. Recap and it should run fine.
I have seen PSU's made far worse. No output chokes, input RFI filters were just wires, underrated resistors.Last edited by Pyr0Beast; 12-04-2010, 10:31 AM.Comment
I hope there is plastic insulation among the pcb back and the metal case...
It could do 300W if the input caps are replaced with 680uF and the primary transistors are something like 13009 or better.
I would also check the secondary silicon and recap the output caps with 2x2200uF for every output (3.3V, 5V, 12V) just to be safeComment
Translations from Chinese to Engrish are always funny.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I see HEC.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
KSC. Very low end huntkey. Knowing huntkey its a 200w, 300w peak.Comment
I wouldn't call anything with a transient filter "very low end". Though agreed, that won't do more than 200-250W.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Yes, the two power supplies do look very much alike. In fact, the part numbers on the three transformers between the heat sinks are identical!
The primary caps are HEC 330 uF/200 voltsOld proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
-David VanHornComment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by NolesFanLike the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
Channel: BIOS Requests ONLY!
by Maxpower3every time I open the tool, I have the screen that appears
and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
It annoys me lol.
2 solutions to remove it.
Either you remove pic.bmp and it no longer appears so no more links when clicking.
hope this helps users...01-15-2025, 03:24 PM -
by howardc64TV was fixed just after removing Samsung's rear snap cover.
This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
Maybe PSU->backlight connector didn't have a good contact?...Today, 12:34 AM - Loading...
