Do no remove this cover under any circumstances
  • everell
    • Jan 2009
    • 1514
    Just couldn't resist....here is a Dynex DX-PS300W.......with cover removed!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Do no remove this cover under any circumstances
    I've seen worse.
    A working TV? How boring!
    • everell
      • Jan 2009
      • 1514
      I was referring to the writing on the label on the case. It says "Do not remove this cover under any circumstances". LOL! Once inside it is just a cheapo half bridge configuration with KA7500 pwm chip, 2 transistor 5vsb circuit, and primary caps are 330 uF. I doubt that it would stand up to 300 watts.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        "Fan controlled Power Supply"?
        So, the fan controls the psu?
        • Pyr0Beast
          • Feb 2009
          • 406
          It would be good for 150-200W. It seems quite decent psu.
          KA7500 is TL494 under a different name.
          It has good input filtering, lots of heatshrinking, good quality soldering, output filtering and perhaps what I see even 5Vsb made with a linear regulator. It even has a fan connector, very nice. Shielded caps from input transitors/Fets and an input switch. LM339 for Overvoltage protection. Recap and it should run fine.
          I have seen PSU's made far worse. No output chokes, input RFI filters were just wires, underrated resistors.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            I hope there is plastic insulation among the pcb back and the metal case...
            It could do 300W if the input caps are replaced with 680uF and the primary transistors are something like 13009 or better.
            I would also check the secondary silicon and recap the output caps with 2x2200uF for every output (3.3V, 5V, 12V) just to be safe
            • everell
              • Jan 2009
              • 1514
              That too is funny. I wonder who thinks up such "technical" information to put on labels.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Translations from Chinese to Engrish are always funny.
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  What brand are those primary caps? GSC?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I see HEC.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      KSC. Very low end huntkey. Knowing huntkey its a 200w, 300w peak.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        I wouldn't call anything with a transient filter "very low end". Though agreed, that won't do more than 200-250W.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Looks similar to this.
                          • everell
                            • Jan 2009
                            • 1514
                            Yes, the two power supplies do look very much alike. In fact, the part numbers on the three transformers between the heat sinks are identical!
                            The primary caps are HEC 330 uF/200 volts
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5021
                              • New Zealand
                              Yeah, do not remove cover lest you notice how crappy the PSU is.
                              -David VanHorn
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                You might get electrocu ... err, shocked !
                                • dood
                                  Deputy dood
                                  • Mar 2004
                                  • 2462
                                  I have a picture around here somewhere of a crappy PSU that actually had this STAMPED in the metal - "Do not screw off!", with an arrow pointing to a screw.
                                  Ludicrous gibs!
