My Dynex 350W lost it's mojo
  • bigbeark
    • Jan 2010
    • 661
    Last night I fired up my Gigabyte box, uses an Inte li875 chipset. This machine has always had a speed up/slow down action on boot up.
    It was booting but I was getting "video out of range" message when it went to load Linux Mint. This NEVER happens on Linux machines. So I started looking around and found that I must have dislodged the 12v auxiliary power
    4-pin connector. This is a 20-pin ATX machine, by the way. When I turned on the rocker switch on the PSU, I heard a pop. After that the machine would start up, but not boot.
    I swapped in another Dynex PSU and the machien booted right up with no racing from the PSU.
    So I took the cover off the old PSU (which was really almost new). No heat damage of any kind, no domed caps, nothing. The fuse must be intact or the PSU wouldn't run(?).
    What should I look for?
    I hooked up my dubious Thermaltake power supply tester and it shows nothing is wrong!!
    How do I use my multi-meter to test this PSU?
    I will recap if the thing is not burned out totally, but want to ensure it's worthwhile.
    I would appreciate your suggestions.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: My Dynex 350W lost it's mojo
    A pop suggests that one of the switchers could be bad
    • c_hegge
      • Sep 2009
      • 5219
      Agreed. Check the primary switching transistors
      • bigbeark
        • Jan 2010
        • 661
        So according to http://en.wikipedia.org/wiki/File:AT...ransparent.png, these would be attached to the heatsink that is between the large primary caps and the transformers?
        Can I test these with a multimeter? What is the proper testing method? Thanks, Barry
        • seanc
          • Nov 2008
          • 1319
          Did you smell anything 'cooking'?
          • bigbeark
            • Jan 2010
            • 661
            No smells or smoke at all. Just a "pop" when I turned the rocker switch to ON
            • 370forlife
              Large Marge
              • Aug 2008
              • 3113
              I think what you might be hearing is the switch arcing a bit when you switch it on. Does the power supply still turn on?
              • bigbeark
                • Jan 2010
                • 661
                I think I found the problem. Looks like the red wire that attaches to what I think is a square "X" capacitor (next to the transformer) is not connected to one leg of that cap, but should be. The wire is loose, You can see its sort of pushed out of the PCB, I think the two wires should have been joined by a puddle of solder. There is a black scorch mark there. Tell me what you think.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  definitely something happened there-probably the high-voltage caused an arc aross the bad connection, making a pop noise
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    It's hard to tell from the pictures, but if the red wire is indeed loose or has become unsoldered, then that's definitely the problem. As shovenose suggested, the noise could have come from the bad connection.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      thats the voltage selection switch wire... that would explain it if you are on 120v (USA or canada)... if 240v, then nothing because turning the switch on would burn the unit out. switching it off on 120 drops the voltages... and ehnce why you have a problem.
                      resolder that wire. the scorch if from the AC arcing...
                      sigpic
                      (Insert witty quote here)
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5096
                        • New Zealand
                        Looks like part of that pad\track has actually been ripped off. I'm guessing they built it badly, there was too much strain on it and it broke.
                        Might work just fine if you reconnect that wire
                        -David VanHorn
                        • bigbeark
                          • Jan 2010
                          • 661
                          The red wire was loose. Upon closer inspection, I realized that it was supposed to be attached to a common ground plate in that area. The solution was to attach it to another wire that was firmly attached to the ground plate. Seems to have done the trick as test board now posts. Was able to document all the caps while I was in there so I can in future do a recap. Other than the caps, which are a mixture of CapXcon and FCon, the Primary side is complete with no fudges, although the Primary caps are only 470uf 200V.
