My Dynex 350W lost it's mojo
  • bigbeark
    • Jan 2010
    • 661
    Last night I fired up my Gigabyte box, uses an Inte li875 chipset. This machine has always had a speed up/slow down action on boot up.
    It was booting but I was getting "video out of range" message when it went to load Linux Mint. This NEVER happens on Linux machines. So I started looking around and found that I must have dislodged the 12v auxiliary power
    4-pin connector. This is a 20-pin ATX machine, by the way. When I turned on the rocker switch on the PSU, I heard a pop. After that the machine would start up, but not boot.
    I swapped in another Dynex PSU and the machien booted right up with no racing from the PSU.
    So I took the cover off the old PSU (which was really almost new). No heat damage of any kind, no domed caps, nothing. The fuse must be intact or the PSU wouldn't run(?).
    What should I look for?
    I hooked up my dubious Thermaltake power supply tester and it shows nothing is wrong!!
    How do I use my multi-meter to test this PSU?
    I will recap if the thing is not burned out totally, but want to ensure it's worthwhile.
    I would appreciate your suggestions.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: My Dynex 350W lost it's mojo
    A pop suggests that one of the switchers could be bad
    • c_hegge
      • Sep 2009
      • 5219
      Agreed. Check the primary switching transistors
      • bigbeark
        • Jan 2010
        • 661
        So according to http://en.wikipedia.org/wiki/File:AT...ransparent.png, these would be attached to the heatsink that is between the large primary caps and the transformers?
        Can I test these with a multimeter? What is the proper testing method? Thanks, Barry
        • seanc
          • Nov 2008
          • 1319
          Did you smell anything 'cooking'?
          • bigbeark
            • Jan 2010
            • 661
            No smells or smoke at all. Just a "pop" when I turned the rocker switch to ON
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              I think what you might be hearing is the switch arcing a bit when you switch it on. Does the power supply still turn on?
              • bigbeark
                • Jan 2010
                • 661
                I think I found the problem. Looks like the red wire that attaches to what I think is a square "X" capacitor (next to the transformer) is not connected to one leg of that cap, but should be. The wire is loose, You can see its sort of pushed out of the PCB, I think the two wires should have been joined by a puddle of solder. There is a black scorch mark there. Tell me what you think.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  definitely something happened there-probably the high-voltage caused an arc aross the bad connection, making a pop noise
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    It's hard to tell from the pictures, but if the red wire is indeed loose or has become unsoldered, then that's definitely the problem. As shovenose suggested, the noise could have come from the bad connection.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      thats the voltage selection switch wire... that would explain it if you are on 120v (USA or canada)... if 240v, then nothing because turning the switch on would burn the unit out. switching it off on 120 drops the voltages... and ehnce why you have a problem.
                      resolder that wire. the scorch if from the AC arcing...
                      sigpic
                      (Insert witty quote here)
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4958
                        • New Zealand
                        Looks like part of that pad\track has actually been ripped off. I'm guessing they built it badly, there was too much strain on it and it broke.
                        Might work just fine if you reconnect that wire
                        -David VanHorn
                        • bigbeark
                          • Jan 2010
                          • 661
                          The red wire was loose. Upon closer inspection, I realized that it was supposed to be attached to a common ground plate in that area. The solution was to attach it to another wire that was firmly attached to the ground plate. Seems to have done the trick as test board now posts. Was able to document all the caps while I was in there so I can in future do a recap. Other than the caps, which are a mixture of CapXcon and FCon, the Primary side is complete with no fudges, although the Primary caps are only 470uf 200V.
                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 03:28 PM
                          • CG2
                            Janome DC3050 Sewing Machine Pedal Resistance
                            by CG2
                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                            04-14-2023, 07:53 AM
                          • Soulzink
                            Samsug washing machine. Power supply DC41-00189a board issue
                            by Soulzink
                            I am trying to fix a samsung washinmachine power supply main board.
                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                            The power supply board reference is the following: DC41-00189a
                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                            04-19-2025, 06:26 AM
                          • unimatrix93
                            How to stabilize AC voltage to CNC machine
                            by unimatrix93
                            Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                            I have a CNC machine wired to 3-phase 230V AC.
                            It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                            The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                            I contacted the electricity company but they refuse to help me solve this problem.
                            So I started to look around for some DIY...
                            03-17-2025, 05:52 AM
                          • xdever
                            820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                            by xdever
                            I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                            01-15-2025, 08:44 PM
