Replacement caps for Antec SP-450?
  • mockingbird
    replied
    Re: Replacement caps for Antec SP-450?
    You've given me an idea. I might try replacing the small caps if there's a daughterboard, because the last time I played with it, it turned on and worked fine.
  • mattday
    replied
    So a couple of years have passed since I sorted out my SP450 (see my previous posts in this thread). I meant to wrap up back then, but better late than never. Unfortunately the motherboard in that system failed a couple of weeks after the PSU. A capacitor had clearly vented, but on closer inspection a number of capacitors on the board were badly bulging after it had been fed nasty power from the SP450. I replaced 8 capacitors on the board and it went back into service. Both the SP450 and the motherboard are still in service today!
    For the SP450 schematics that I started sketching out, I found I had made a mistake tracing the circuit in sheet 1. I'm afraid I'm not going to correct it now, as there may well be other mistakes (e.g. it seems like L1 should be inline with the supply, not across it). The transformer winding that feeds D10 and R11 actually supplies the power to the PFC IC, not the VSENSE input as pictured. VSENSE is then connected via a divider to the 325VDC as in the IC datasheet.
    Regarding R11, my burned out resistor, I found that 280 ohms was much too high for the PFC to work correctly and I ended up using 3.3ohm. For C4 I just guessed at a 10nF X7R ceramic. Most of the Fuhjjyus got replaced with Panasonic FRs.
    The PSU was working correctly without the PFC circuitry, as I suspect it had been for some time. After replacing the capacitors, the outputs looked clean on the scope, it just had a horrid power factor. With the PFC circuit working, PF was 0.99 with the system idling at ~100W. I don't know how accurate my power meter is, but interestingly the same system at idle with a Corsair CMPSU-400CX used 75W with a PF of 0.87.
    Anyhow, happy recapping!
  • mockingbird
    replied
    Well, this happened a few months ago, but my SP-450 bit the dust. Shut the computer down for the weekend, including the switch on the back of the PSU, came to turn it on afterwards, the system was stone dead. Motherboard tested OK (And was used to replace a defective Asus), but today I probed around on the connector a little to see what was going on. I'm now using a re-capped EA-500D instead for my main rig.
    Jumpered green to ground, hooked the DMM common lead to ground and I am getting this weird phenomenon of low voltage and then momentarily jumping to the correct voltage. So for example, 3.3 will be 1.5~ and then for a split second might show 3.3 and 12v will go 10v and then briefly show 12v.
    I have no idea what could have happened. I really ought to have meticulously picked away at the organic glue as I now routinely do in repairs, somethign might have shorted that way. Anyone have any ideas (Or maybe the PSU voltages are ok, but it's behaving that way because there's no load)?
  • mockingbird
    replied
    Originally posted by erdos
    what safety precautions i should take to work with capacitors?
    thanks
    Make sure the primary caps are fully discharged. Here are the list of caps:
    Originally posted by mockingbird
    EC3 - Fuhjyyu 50V 4.7uF "TN" 5x11
    EC4 - Fuhjyyu 50V 4.7uF "TN" 5x11
    EC5 - Fuhjyyu 50V 22uF "TN" 5x11
    EC6 - Unpopulated
    EC7 - Cannot locate - probably nonexistant
    EC8 - Cannot locate - probably nonexistant
    EC9 - Cannot locate - probably nonexistant
    EC10 - Teapo 10V 1000uF "SEK" 8x15
    EC11 - Teapo 10V 1000uF "SEK" 8x15
    EC12 - Fuhjyyu 50V 47uF "TN" 6.3x11
    EC13 - Fuhjyyu 50V 10uF "TN" 5x11
    EC14 - Fuhjyyu 50V 1uF "TN" 5x11
    EC15 - Fuhjyyu 50V 1uF "TN" 5x11
    EC16 - Fuhjyyu 50V 1uF "TN" 5x11
    EC17 - Fuhjyyu 50V 1uF "TN" 5x11
    EC18 - Fuhjyyu 16V 220uF "TN" 6.3x11
    EC19 - Fuhjyyu 16v 3300uF "TM" 10x35
    EC20 - Teapo 16V 330uF "SC" 6.3x15
    EC21 - Fuhjyyu 10V 1000uF "TM" 10x20
    EC22 - Fuhjyyu 10V 2200uF "TM" 10x25
    EC23 - Unpopulated
    EC24 - Teapo 6.3V 4700uF "SC" 10x30 (In an 8mm marked spot)
    EC25 - Teapo 6.3V 4700uF "SC" 10x30
    EC26 - Fuhjyyu 50V 10uF "TN" 5x11
    EC27 - Fuhjyyu 50V 0.1uF "TN" 5x11
    R98 - Fuhjyyu 50V 0.22uF "TNR" 5x11 (Behind EC26 - negative lead oppoiste direction of EC26)
    If you need to know where to find replacements, let me know.
    replied
    open it and take lots of pictures.
  • erdos
    replied
    my homebuilt PC with Antec Sonata case just died, it made loud noises and emit burning smell when i powered up the PC. it came with the same Antec Smart Power 450W, model SP-450 Power Supply described in this thread.
    i figure it had to be the Power supply with bad caps, i wonder if i decided to replace the the caps, what safety precautions i should take to work with capacitors?
    thanks
  • mattday
    replied
    Any expert insight into why the resistor and zener could have gone?
    I didn't get much out of tracing the extra part of the circuit connected to the failed cap EC5. I have very little experience of this kind of circuit, so it is difficult for me to see what is going on. It is clear that if ZD5 were to go short circuit, then R11 could dissipate excessive power, but I don't know if failed capacitors in other parts of the circuit could cause ZD5 to fail.
    @Toasty: if you have C4, would you be kind enough to measure its value? (In circuit should be fine). I have managed to destroy my C4
    Thanks.
  • mattday
    replied
    Toasty, you are right, those designations got a bit mixed up. An edited schematic is attached. IC1 was actually 1C1, and is presumably the capacitor next to IC3. The real IC1 is the opto.
    Some more schematic attached: underlined means SMD
    Trace side image attached: Marker pen and link wire are not original
    EC5 had dried up and measured 0.04uF
  • Toasty
    replied
    Can you get a photo of the foil side. From above the slit for the opto all the way over to the PFC section. Well lighted so you can see the traces.
    I am curious as to why the diode & resistor blew.
    You have IC1 as the MOSFET and mounted to the heatsink? That looks odd...? It's not where IC1 is marked on my board. It's right next to the inboard end of IC3. Are you sure that's not Q5 you're talking about?
    Top down with the mains caps to the right:
    IC3 is the 8-pin DIP
    IC1 sits directly above it
    Q5 sits to the left on the heatsink
    Your schematic needs adjustment of those designations.
    T
  • mattday
    replied
    It looks like my board has additional PFC circuitry. I have traced out some of the circuit and attached it. If you don't have IC1 and IC3, then I'm guessing you don't have the large choke L1 either (see attached photo). Also note on my diagram: R38 and R39 are sleeved with heat-shrink, so I can't read the values, but they measure less than the resistance of my meter probes.
    As Toasty had guessed already, R11 looks like a current limiter. I'm guessing a lowish value which will not be critical. I have attached the datasheet for IC1, but the application example is a bit different to my schematic. I am currently thinking of going with maybe a couple of hundred ohms for R11?
    The original resistor was about the same size as the blue one I have in there now - probably 0.5W. It is larger than most of the small ones along that edge of the board, but smaller than the large pink one (R48) by the 5VSB output caps.
  • Toasty
    replied
    I have this supply but no resistor nor zener were ever attached to that area. Sorry.
    What was the physical size of the burned resistor? That would give a clue as to wattage.
    Are you sure that was a 1N4746 (18v, 1w)?
    Is the board marked ZD# or just D#.
    I ask because the setup looks wrong for a Zener regulator - there's no output/connection from the resistor-diode junction.
    It looks like a diode with a resistor in line to limit current, coming off a feedback loop in the transformer...?
    [EDIT]: It looks to be supplying power on the other side of the board to IC3 (8 pin DIP) or IC1. Neither of which are present on my supply, going by my photos.
    T
    PS: Here's a link to a Zener calculator I found. If you save the page to your computer, you can have it available anytime.
    http://hyperphysics.phy-astr.gsu.edu...c/zenereg.html
  • mattday
    replied
    Sorry to resurrect an old thread, but it seemed like the most appropriate place. I have a SP-450 from a Sonata II case that recently died. It is amazing it lasted so long - I got it 2nd hand and have been using it for over 5 years. There were obvious signs of electrolyte leakage on several of the fuhjyyus.
    Anyhow, in addition to some capacitors, a resistor and a zener diode on the primary side had failed. The resistor had burnt the PCB badly (see photo), and the zener was acting like a short. I was able to get a replacement zener (1N4746) but the resistor markings were gone. It measured over 600kOhms, but was obviously a much lower value originally or it would never have dissipated enough power to burn the PCB.
    Would anyone with this PSU be kind enough to tell me the value of R11? See attached picture (ignoring the blue temporary part). The same PCB was used for a few variations, and the photos of similar boards I have found on this forum do not have this part populated. For example:
    https://www.badcaps.net/forum/attach...6&d=1294553638
    https://www.badcaps.net/forum/attach...6&d=1260051418
    Thanks for any info you can offer, even it it just helps me guess a reasonable value
  • mockingbird
    replied
    Originally posted by c_hegge
    HP-D3057F3H? I LOVE recapping those things. I've never had one not work after a recap.
    "3R", but probably identical... What do you use? For the two 16V 2200uF caps I squeezed in 12.5mm Nichicon HE instead of the 10mm 16V 2200uF Ltec "LZP", and for the 10V 2200uF "LZP" I used 10x31.5mm Nichicon HE.
    Lots of tiny caps on this one, eh? In total, there are 25 caps on the PCB, and I replaced every last one of them.
    Question: Do you think these are true ATX 2.0 units or did they hack in the extra cables for the 24-pin connector? I ask because my PSU has a manufacture date of 2005!
  • Toasty
    replied
    >>seeing as I have a really lousy multimeter with blunt probes<<
    Concrete sidewalk fixes that....
  • c_hegge
    replied
    HiPro model HP-D3057F3R... HiPro layout and design is simple, straighforward and easy to service. They even labeled the 5VSB cap on the PCB so I went ahead and put a Panasonic FM there because it can take the abuse.
  • mockingbird
    replied
    Thanks for all your help...
    I was so encouraged with my success with the SP-450, that I re-capped a Hipro 300W... You see, I got a whole bunch of caps from Newark last week for PSUs that I had been planning to re-cap for a while.
    Next I want to repair those 350W FSP (Sparkle) PSUs I told you about. I was pondering for a while on how to measure the 10V caps to see if they are really 10V or if they were 6.3V, seeing as I have a really lousy multimeter with blunt probes, I had the idea to put all 16V 3300uF RS caps, leave the long leads on, and then use aligator clips to measure the voltage. A lot safer than using probes.
  • PCBONEZ
    replied
    I used all 16V 3300uF 10x30 caps, Manyue confirms their rating at 1675 ripple, 0.041 ESR.
    Now that sounds like a realistic number for a 10x30mm RS.
    Thanks for taking the trouble.
    I didn't figure they'd answer for a custom size.
    [Edit]
    And Congrats!
  • mockingbird
    replied
    An update,
    My recap was a success... I replaced the ailing EA-500D in my main rig with the re-capped SP-450 and I'm typing from it now... Voltages checked ok in the BIOS:
    +3.3 = 3.31V
    +12 = 11.84V~11.90
    +5 = 4.91V
    Re-cap was done per PCBONEZ' suggestion of replacing the 2200uF+ caps with Samxon RS (I used all 16V 3300uF 10x30 caps, Manyue confirms their rating at 1675 ripple, 0.041 ESR), and a combination of Nichicon PW or HE or whatever Newark had in stock for the rest.
    EDIT:
    In the middle of writing this post, I remembered that I forgot to put in the replacement for the infamous 50V 0.22uF cap behind EC26, and EC26 itself. I'm so thankful it didn't blow up! Not only that, it was pretty stable without them.
    Voltages after adding the two caps:
    +3.3 = 3.28V
    +12 = 11.84V~11.90
    +5 = 4.91V
  • mockingbird
    replied
    Ah... It is sitting right next to two coils, I thought it was part of the output filter of EC22 which is going to be a Samxon RS which was 0.035 so I tried to match it as best as I could.
    Looking at the traces at the back, it doesn't seem to be part of it, instead I can see one of the traces going to what Toasty has lead me to believe is the -12V line.
    Thanks, I will change this accordingly.
  • PCBONEZ
    replied
    Finally had time to really look at the replacement BOM
    What is up with EC20?
    An 8x15mm 330uF/16v SC is like 750-mA/0.100-ohm
    An 6.3x15mm 330uF/16v SC would have worse specs if it was in the data sheet.
    ... Probably close to what they give for the 8x11mm which is 620/0.120
    The FM at .030 ohms is way over-kill.
    I think I would use...
    FC 8x15mm 330uF/25v - 730/0.085
    KY 8x15mm 330uF/25v - 840/0.087
    Everything else looks fine.
