Optoma Hd146x with bad powersupply
  • debruina
    • May 2020
    • 29
    • Nederland
    Hi
    I am repairing a Optoma HD beamer with a bad powersupply. It has a blown 6.3A fuse and a burned coil in the mains line.
    Any ideas where to get a filter like that? I am little surprised that the mains is directly connected to both lines on the coil. One wire has a bit of more isolation (light color) but still both mainlines are really close together like this. It seems to me this is asking for trouble. I mean i have seen them with seperate sides but never like this. Maybe rewire? Any advice?
    • 31161
    Re: Optoma Hd146x with bad powersupply
    its a filter, you can replace it with a couple of jump wires to test the psu
    and you should because something feels wrong about that filter burning unless too much current went through it
    • CapLeaker
      Leaking Member
      • 8296
      Just unwind it a half of a turn and solder it back on. Done. A half of a winding or even a whole turn doesn’t matter much. I try to cut only that much than I really have to. Just make sure that not more isn’t wrong with the PSU like a shorted mosfet in the primary.
      • debruina
        • May 2020
        • 29
        • Nederland
        Replaced the filter with two wires and it works again.
        Luckily nothing else damaged. I guess the wire may have been damaged at production.
        • CapLeaker
          Leaking Member
          • 8296
          A lighting strike nearby can do that. I’ve seen this a few times. For me I would just have unwound a half of a turn or a whole turn and stuck that filter back in its place.
          • chth96
            How can I test coil whether it is really broken or not?
            by chth96
            I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
            I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
            I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
            I want to replace this round black fuse and unidentified coil if it got broken.
            02-20-2024, 01:07 AM
          • chopduel
            Bad mains power causing TV malfunctions?
            by chopduel
            I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
            Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
            • TV would randomly turn off then back on.
            • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
            • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
            12-29-2024, 03:20 AM
          • waterchill
            What part is this coil from a MacBook A2681 ?
            by waterchill
            Hi everyone
            I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
            So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
            IAny ideas? It is from a MacBook A2681
            Thank you...
            08-08-2024, 01:46 AM
          • Gjackson
            ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
            by Gjackson
            Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
            01-13-2024, 10:34 AM
          • chth96
            How Can I identify IFT coil?
            by chth96
            I have a CD unit which is came from saturn game console.
            It always perceived Any retail CD or CD-R as Audio-CD.
            Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
            I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
            I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
            Is there any way to identify its frequency in order...
            11-11-2022, 05:31 AM
