Input capacitors SMPS
  • Tioleco
    • Apr 2010
    • 46
    • Brazil
    What series are recommended for the input filter of SMPS , 470uF , 680uF and 820uF / 200V?
    I´m looking for Chemicon KMH , KMQ , LXM and LXS ; Rubycon VXG , VXR ; and Nichicon GU series.
  • mscserbia
    • Dec 2013
    • 17
    • Serbia
    Re: Input capacitors SMPS
    Rubycon VXG,they are good.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      For those low end PSU's with the voltage doubler, I'd say it's safe to use just about any 200V snap in capacitor. They are hardly stressed, and ESR is not important. Even the worst brands will last a very very long time there
      • selldoor
        Slow Learner
        • 7870
        I do not know enough about PSUs to question your reply but just to err on the side of caution his mains voltage is 220-240VAC does that make a difference?
        or are we not discussing mains input filter caps?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          selldoor: The voltage selector switch puts the caps in series when set to 230v, so the 200v caps together will be able to handle 400v
          Which is well within the peak voltage expected: 240VAC x √2 ≈ 340v
          • mariushm
            • May 2011
            • 3799
            A power supply rectifies the AC voltage into DC, so you have AC Voltage x 1.414. For 240v AC, you have DC voltage that peaks at around 340v.
            If a power supply has two large 200v capacitors, they're connected in series or parallel depending on the switch position in the back.
            For 110v countries, the capacitors are in parallel, giving you 2 x capacitance and same voltage rating.
            For 220-240v countries, the capacitors are in series, giving you capacitance/2 and 2x voltage rating.
            1/Ctotal = 1/C1 + 1/C2 => C1 x C2 / Ctotal = (C2 + C1 ) => Ctotal = C1 x C2 / (C1+C2)
            If C1=C2 => Ctotal = C1xC1 / 2 x C1 = C1 / 2
            The more capacitance on the input, the power supply can handle larger drops in power in case your house electricity is not perfect. Also, larger capacitance can help a bit in the total watts of regulated power a power supply can provide to the computer.
            For 300w, about 270-330uF may be enough. For 400w, maybe 470u-680uF. For more, I would recommend 820uF. More experienced people feel free to contradict me.
            These large capacitors don't need to be low esr or be any special, and in most cases you could even use GOOD quality 85c rated capacitors (Panasonic, Rubycon etc) - it depends on the design of the power supply, if there's some distance from the heatsink so they won't heat too much.
            More modern power supplies have an Active PFC circuit which boosts whatever voltage it receives (let's say anything between 90v and 250v) to about 400-420v so in these new power supplies you often see just one capacitor with a voltage rating of about 420-450v. You should NOT use capacitors with lower voltage rating for those power supplies.
            In these types of power supplies, you should get 105c rated capacitors.
            • selldoor
              Slow Learner
              • 7870
              Thanks chaps - I know a bit more now. Remembering it might be a problem .
              Also as a side I have just read that Brasil has both 220vac and 110vac
              - can vary from city to city - nightmare
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                Not to say that I know more than some of the more experienced members here do, but I think for the voltage doubler at least (not the primary capacitors of an Active PFC circuit), 270uF-330uF is a bit low for 300W and otherwise. If the two capacitors in the voltage doubler can't smooth enough current for the main switcher(s) to chop and feed to the main transformer then the main switcher(s) have to work harder and the main transformer has to work harder as well (needs a greater turns ratio). It also allows more 100/120Hz ripple through which isn't a good thing (and is separate from the ripple voltage and current that the output filtering takes care of, though the control loop compensates for it to some extent, and the ferrite coils on the output can also suppress some of the 100/120Hz spikes, but only to a small degree; that sort of ripple goes straight through the output capacitors and magamp circuit otherwise unless the capacitance of the output capacitors is some unfeasibly high value). I think 470uF/200V x2 is a good minimum for 300W power supplies and 680uF/200V x2 for 400W power supplies respectively (but, ideally, IMO, 560uF-680uF is a good range for 300W units and 820uF+ for 400W units). It is also correct that more capacitance improves hold up time, though those capacitors will be charging for longer periods of time, the more the capacitance.
                Also, because the capacitors in the voltage doubler are not ESR critical, they are relatively unstressed and capacitance (assuming the voltage rating is correct) is really only the important facet when it comes to them. However, because the truly bad brands especially lose their capacitance a lot faster than the Japanese ones, I would recommend sticking to Japanese brands if possible (even 105*C ones if possible since they don't dry out as fast as 85*C ones despite the lower ripple ratings). Also, some of the truly horrendous brands overrate their high voltage capacitors by quite a bit capacitance wise. Also, to my knowledge, the capacitors charge in parallel and discharge in series.
                  Filter cap cal.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    One thing that's surprising to me is that most power supplies seem to not live up to the hold up time of min 16ms that the ATX spec mandates.
                    Scroll down a bit to "Hold-up Time"
                    http://www.techpowerup.com/reviews/C.../CS650M/5.html
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      There are ways to fudge a hold-up time test. One would be to remove AC power just after the peak of the sine wave (just after the input caps got a slug of charging current) rather than at the zero-volt crossing (as done in the article's test). And cheapie units are probably sold with the assumption that the actual system load will be less than full rated power, and that the user can't know the difference, anyway.
                      PeteS in CA
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Yea I guess so, but as an end-user it is very easy to notice.
                        Because if you live in a place with bad power and you get a UPS it will be designed with the ATX spec in mind.
                        So if the blackout happens in the peak of a sine wave it might have time to switch the load over.
                        But if the blackout happens not on a peak (most likely, ref: "Murphys law" and also "sandwich law") then the supply might not have the time to switch and so the end-user will blame the UPS, when it's actually the power supplies fault...
                        • TELVM
                          • Oct 2012
                          • 547
                          • Spain
                          One thing that's surprising to me is that most power supplies seem to not live up to the hold up time of min 16ms that the ATX spec mandates ...
                          Penny pinching on the bulk cap, those 400+V caps are expensive.
                          Of the two PSUs that pass ATX hold-up in that table, the Cooler Master GM 550W has one 470uF for 550W, the Antec VP450F has one 330uF for 450W.
                          The Corsair CS subject of the article has a much lower ratio of one 220uF for 650W, and fails.
                          • ugamazing
                            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                            by ugamazing
                            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                            04-10-2024, 08:06 AM
                          • eigma
                            Samsung UN40H5003 boot loop every ~8 seconds
                            by eigma
                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                            Main board: BN94-07592P / BN97-08922R...
                            11-20-2024, 10:31 PM
                          • ketone
                            SMPS - Can they all handle wide range of Input Voltage?
                            by ketone
                            Hello Forum - See I got this SMPS Module!....its sourced from a US device and I'm in Australia.
                            As we know Supply voltages in Australia 240v Versus 120V US.
                            The Model of the SMPS is EAX39561401 and is used in LG and JVC DVD/VCR Player/Recorders...same model is used in both Australia and US...but perhaps they have differences??
                            What's the chances I can use it in Australia - plugging it in to 240v instead of its origin country at 120v?
                            Is it expected that most SMPS in such devices would handle between 100-240V by default?
                            How can I...
                            12-17-2022, 02:40 AM
                          • Perry Babin
                            samwha capacitors 10uf 200v/250v
                            by Perry Babin
                            The attached capacitors are used in the output filters of class D amplifiers and hold up well but when they fail, replacements are difficult to find. I've tried the various options on eBay and crossover caps and none survived. Mouser, Digi-key... don't stock many bi-polar electrolytic caps. The only thing that I found survived (never a failure) was the Mouser E2106 (part number 667-ECQ-E2106JF) and the same from Digi-key. They look different but survive. Does anyone know a readily available drop-in replacement electrolytic? The dimensions are approximately 16mm x 25mm....
                            04-03-2024, 05:46 AM
                          • Dannyx
                            Modifying SMPS input voltage range
                            by Dannyx
                            Good day folks. Long time no see. It's been a while since I've tinkered with any new projects, despite one thinking this would be the perfect time, with the pandemic and the quarantine, people tend to stay indoors....it's not my case anyway: I go to work like normal, but it's here where I'm bored out of my mind with nothing to do, so here's something.
                            A while back, I got myself this adjustable load kit form off Ali. I put it together and it works. It's powered by an AC or DC input and I've been running it off a 12v wall adapter on the bench. What good is such a device if it doesn't...
                            03-30-2020, 06:45 AM
