Rexpower PL-400 rebuild
  • c_hegge
    • Sep 2009
    • 5219
    Success!
    SUCCESS!
    It turned out that there were two problems The first was another solder blob shorting the 12v rail. The second was an incompatible transformer. I replaced it with another 35 size from another dead PSU. Put it on the tester and it fired right up. The 12v was a little high at 12.6, probably due to not having much load, but all the other rails looked fine.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Re: Rexpower PL-400 rebuild
      cool. how did u make the big text are you gonna make a new label for the psu reflecting its awesomeness? like SUCCESSPOWER 700w PSU?
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #63
        Congratulations! Well done!
        I have never replaced transformer or switching transistors in a power supply.. Maybe one day I will find the courage and try it.
        • c_hegge
          • Sep 2009
          • 5219
          Here is how you change the text size. I'll just stick with my "C H PC Power MOD-400" Label
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            More official-looking model number, maybe rpm400atx (rexpower modded 400w atx)Not to be confused with diablotek rpm series
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #66
              That 12v rail is going to be fine if you use the power supply in a Pentium 4 or anything newer than that. Just don't try it on an AXP.
              A working TV? How boring!
              • c_hegge
                • Sep 2009
                • 5219
                Oh, What? That's why I beefed up the 5v rail so much, so it could handle systems that use it for CPU power. Oh well...
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #68
                  If it's already at 12.6 while the other rails are reading normal, think of what would happen when you load up the 5v rail only. Most parts will handle up to 15 volts, but don't trust ALL of them to be able to do so.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I did another run on the tester, and what I failed to notice last time is that, although this is a single rail PSU, the tester shows 12.3v on 12v1 and the 12.6v is on 12v2, so I'm begining to think it might be the 12v2 meter in the tester. The 5 and 3.3v rails showed 5.1 and 3.3v respectively.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #70
                      At 12.3 it's well in spec. Drop it into a spare computer and see how it does. Use a regular multimeter to read the rails.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Unfortunately, I don't have a spare PC. That's why I'm building a load tester.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #72
                          If you lived in Greece I would give you old p4 PCs and psus with bad caps to play with.
                          There are PLENTY of them here!
                          • c_hegge
                            • Sep 2009
                            • 5219
                            After all that it's still only 200W! If I attempt to pull any more than 10A from the 5 and 3.3v rails and 5A from the 12v, the OPP shuts it off!
                            • kiddznet
                              • Jul 2010
                              • 176
                              #74
                              Congratulations. It seems I have the very same power supply. it succumbed to a dead short in a HDD and will now only give five volts. Poking my MM in the CEF02NG transistor doesn't show any life. Could it be as simple as replacing that?
                              939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                              Abit AN8 / Fatal1ty AN8 SLI Series
                              3072 MB (PC3200 DDR SDRAM)
                              ATI Radeon HD 4300/4500 Series (1024 MB
                              Lian LI Aluminium mesh case
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Try going a bit lighter on the 5v/3.3v and heavier on the 12v.
                                • kiddznet
                                  • Jul 2010
                                  • 176
                                  #76
                                  KAAA...BLOOEY!
                                  Nope
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #77
                                    Then trace the OPP line and reconfigure it. It uses a SG6105, doesn't it?
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      #78
                                      Are you sure it is the OPP that is shutting it down and not something else?
                                      For example, check all the voltages seconds before it stops working. It might be UVP/OVP.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Thats what I was thinking, maybe he was crossloading it by putting too high of a load on the 5v/3.3v and not enough on the 12v.
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          #80
                                          No chance it's UVP/OVP, they are set to such obscene values that they basically don't exist.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
                                          • JayPoorJay
                                            Hot Water Rad - A Few ECU Fans and a Timer Switch
                                            by JayPoorJay
                                            Good Afternoon, Good People.
                                            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                            I REALLY would appreciate y'alls help.
                                            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                            10-29-2024, 12:54 PM
                                          • sda sad
                                            my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                                            by sda sad
                                            Hope this is the right place, someone can help me.
                                            My laptop started having a really strange problem....
                                            When I turn it on the fans start working at a crazy rate and with random breaks...
                                            They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                                            And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                                            The model of the computer:
                                            Xiaomi Notebook Pro X 15 OLED (A30)
                                            04-23-2024, 09:55 AM
                                          • joesmoe91
                                            Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                                            by joesmoe91
                                            My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                                            02-22-2024, 07:38 PM
