Rexpower PL-400 rebuild
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Rexpower PL-400 rebuild
    You didnt overrate it enough. Turn it into an "okia 900w" lol.
    But seriously, whats with the 10a 12v rail, you need to improve that.
    • c_hegge
      • Sep 2009
      • 5219
      The 12V diode pack is actually rated for 30A, so it could probably do more.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #43
        I think it could do ~20A.
        • c_hegge
          • Sep 2009
          • 5219
          Revised label
          • c_hegge
            • Sep 2009
            • 5219
            OK. I powered it on. 5vsb came right up at 5.06v, however, I put it on a PSU tester and nothing happened, no power on, but thankfully, no explosions either.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #46
              Did the psu fan move for a second?
              • c_hegge
                • Sep 2009
                • 5219
                No. Absoloutley nothing happens on the tester. Fan doesn't twitch or anything.
                  master hoarder
                  • May 2008
                  • 12175
                  #48
                  Since 5vsb is there, see if there is some voltage on the PS-ON signal. There should be close to 5v I think.
                  Check for short circuit on all of the rails to ground as well. If none, check for short circuit between the rails themselves.
                  Also, did you replace the original 12v fast rectifier with a schottky? That could certainly be it.
                  Lastly, the PSU tester may not be providing a big enough load. If you have an old computer you don't care about or any hardware you don't care about, attach it to the PSU to give it a better load.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    PS-on is 4.72v. I replaced the 12v fast recovery with an ultrafast recovery. It looks like the 5 and 12v rails are shorted both to ground and to each other. The 3.3v rail shows about 10 ohms to ground. Why would both be shorted??
                    • POM_MJ
                      • Aug 2009
                      • 228
                      #50
                      Did you've forget some isolator?
                      | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                      | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                      | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Fixed that and still no go.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          OK. I found a solder blod shorting the 5vsb with another trace. I removed that and my DMM no longer shews the 5v as being shorted to ground. I'll have to look at the 12v some more when I get home from work.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Did you replace the primary transformer with a different one? I don't know why, but sometimes they may be pin compatable but it will not work in other power supplies. Have this problem with a "35" sized transformer out of a keerda. Will not work in my Yue-Lin or my Golden Tiger. Golden Tiger's works in the Yue-Lin though and vice versa.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Yes, I did swap the primary transformer as the orignal was only a size 33.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                I should say both the Yue-Lin and Golden Tiger display the same problems, only 5vsb but they refuse to power up.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  I removed the main transfromer, but still the short on the 12v persists. What should I look for next? I can't find any evidence that the solder is shorting the rail.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #57
                                    Take out the rectifier diode.
                                    A working TV? How boring!
                                    • POM_MJ
                                      • Aug 2009
                                      • 228
                                      #58
                                      Yes, possibly your rectifier was gone.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #59
                                        +1
                                        Also, it looks like you used thermal compound between the diodes/pads and pads/heatsinks - this is unnecessary. Moreover if the thermal compound is conductive, this could be the problem as well.
                                        • shovenose
                                          Send Doge Memes
                                          • Aug 2010
                                          • 6575
                                          you should use either real non-conductive thermal pads or nothing at all - depends how the psu was designed.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
                                          • JayPoorJay
                                            Hot Water Rad - A Few ECU Fans and a Timer Switch
                                            by JayPoorJay
                                            Good Afternoon, Good People.
                                            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                            I REALLY would appreciate y'alls help.
                                            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                            10-29-2024, 12:54 PM
                                          • sda sad
                                            my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                                            by sda sad
                                            Hope this is the right place, someone can help me.
                                            My laptop started having a really strange problem....
                                            When I turn it on the fans start working at a crazy rate and with random breaks...
                                            They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                                            And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                                            The model of the computer:
                                            Xiaomi Notebook Pro X 15 OLED (A30)
                                            04-23-2024, 09:55 AM
                                          • joesmoe91
                                            Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                                            by joesmoe91
                                            My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                                            02-22-2024, 07:38 PM
