Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Provisor
  • Azaka
    • Nov 2022
    • 6
    • Uzbekistan
    #81
    Re: Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Prov
    Attached the photo
    • LadyDeathKZN
      • Feb 2023
      • South Africa
      #82
      Originally posted by slimmy182
      Hi whizkidz,
      Inspecting the logic board I found this bad looking smd component just under the display connector, but I haven't schematics, can you help me please identify it to be proper changed? This A2337 show image in LCD but has no backlight at all and no detect internal camera
      @slimmy182, I have the exact same problem, same SMD. MAy you share on what you did to remedy this or what you did to fix this issue?
      I'm fresh out electronics and this is my first repair. Any advice would be appreciated.
      • Ihab98
        • Feb 2023
        Hello, i have some problems to open the brv file... i just downloaded openboardviewer, do i need some plugins? Thx
        • dfear
          • Mar 2013
          • 53
          Originally posted by whizkidz
          Finished the task of creating the board view file and cleaning up the schematic pdf file
          So if you find any error please reply here and will see if a can and/or want to correct them.
          So enjoy the work.
          Thanks for your hard work!
          • slimmy182
            • Apr 2021
            • 117
            • italy
            #85
            Take a look
            https://www.badcaps.net/forum/showthread.php?t=102194
            • marlin297
              • Nov 2022
              • africa
              #86
              thank you
              • mihaitoro
                • Apr 2023
                #87
                BoardView V1.3 not work.
                • siroos_tz
                  • Feb 2014
                  • 120
                  • the UK
                  #88
                  Originally posted by nikemok
                  here the schematic
                  please someone post the silkscreen
                  come on
                  d0gan your are right, here the revised version
                  Originally posted by piernov
                  Fixed, R8313 pin 2 and R8318 pin 1 connected to MPMU_XOUT.
                  • advancedtechs
                    • Aug 2023
                    • 9
                    • FL
                    #89
                    • mferna14
                      • Jun 2018
                      • 1028
                      MacBook Air A2337 audio Board
                      Hi All., does anyone have the schematics for Apple MacBook Air A2337 audio Board P/n: 820-01929-A or if someone knows the values of these 5 caps (4 big same size & one small) Thanks in advance
                      • mferna14
                        • Jun 2018
                        • 1028
                        Guys, never mind I got the values of these caps. The larger 4 caps are .01MF 25V & the smaller caps is 220PF 25v... My package for the .01 was not the exact pack, I installed the smaller pack & all worked fine. Audio is perfect. Thanks though
                        • chuckjuggernaut
                          • Sep 2023
                          • 10
                          Bro... ur Awesome, thank you very much!
                          • augustusii
                            • Sep 2022
                            • 7
                            I have shelled out the cash for Flexbv and love it! But can't find the Flexbv version of board view and schematic for the A2337 800-02016.
                            Anyone have it or know where I can get it?
                            Thank you!
                            • Pedro147
                              • Sep 2016
                              • 161
                              Thank you!
                              https://www.badcaps.net/forum/showpo...5&postcount=15
                              My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
                              • jegerjon
                                • Mar 2022
                                • 6
                                • Denmark
                                #95
                                Thank you so much for your hard work on the board view! Minor correction for a comming v1.4; RP603 is GND on leg 2, not PP3V3_SW_LCD.
                                • Pedro147
                                  • Sep 2016
                                  • 161
                                  Yes, I just confirmed this on an actual logic board too. As far as I see it the schematic is wrong and this cannot be corrected AFAIK. Hence the board view is incorrect because I assume it is following the schematic. It's a tricky situation for @whizkidz
                                  • inflex
                                    • Aug 2012
                                    • 545
                                    I can fix the the boardviews, can't fix the schems though ( at least not yet )
                                    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                                    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                                    • fighter158
                                      • Sep 2018
                                      • 15
                                      • Czech
                                      #98
                                      Originally posted by callmec2001
                                      I download the openboardview 9.0.3 but soon as i try to open it just close the app
                                      Try https://www.badcaps.net/forum/attach...1&d=1657726998
                                      • Dwitty
                                        • Jul 2021
                                        • 21
                                        • Earth
                                        #99
                                        Thx
                                        • penyapc
                                          • Dec 2021
                                          • spain
                                          #100
                                          thanks for the work!!!
