A2337 new M1 MacBook Air problem Logic Board related, no video backlight 820-02016
  • slimmy182
    • Apr 2021
    • 119
    • italy
    MacBook Air A2337, logic board number 820-02016-A . Long story short, this Air was display damaged with no image and no backlight at all but internal webcam was working , all other parts seems to be in good working condition. Trying with a know good working original Display show image but have no backlight at all and now also internal camera and ALS (Ambient Light Sensor) is not working anymore.
    Inspecting the logic board I found this bad looking smd component just under the display connector, but I haven't schematics, can you help me please identify it to be proper changed?
  • mon2
    • Dec 2019
    • 14667
    Re: A2337 new M1 MacBook Air problem Logic Board related, no video backlight 820-0201
    Hi. See attached. The damaged part (@LP670) is a very low cost ferrite bead (0402 size; 120 ohm @ 1.5A). In a pinch and for testing, you can remove the damaged part and short the 2 pads. This should fix your webcam fault.
    Otherwise, Arrow will have these. If you need a few, can drop ship them to you. Send me a PM.
    • mon2
      • Dec 2019
      • 14667
      On the backlight missing - see attached. Proceed with caution due to the very dense PCB layout.
      Measure the voltage on any of the bulk caps that should offer the backlight voltage for the LCD panel. What is the voltage reading for your logic board?
      If you do not see 25v+ volts here then remove all power.
      Meter in resistance mode (2k setting)
      Red meter probe on the same (any of the bulk) caps.
      Black meter probe to ground (shield is ok).
      What is the resistance to ground ?
      If the resistance is low then you have a bad cap or short on the backlight voltage.
      • slimmy182
        • Apr 2021
        • 119
        • italy
        Hi mon2! Thank you so much for the crystal clear explanations, I really appriciated your help!
        Voltage reading of the bulk caps offer the backlight voltage is 0V
        resistance to ground = 0.55
        voltage on backlight fuse FP800 is 12.2V both before and after, beep in continuity mode.
        There is anything else I can do?
        I haven't tried it yet to short the two @LP670 pads to test webcam functionality.
        • mon2
          • Dec 2019
          • 14667
          1) Can you review and post the resistance to ground again? Remove all power to the logic board. Meter in resistance mode (2k should be ok).
          Red meter lead on the requested (any) bulk caps.
          Black meter lead on ground.
          The resistance should be in ohms. What does the meter show ?
          It is ok if it is OL (over the limit of the 2k) - you can then select the next higher resistance setting on your meter till you have a reading. Higher resistance is a good sign on that rail.
          2) As you have no voltage on the backlight rail, either the backlight IC is not being enabled or the I2C communication lines are not working as they should. The communication lines are 2 interface lines used in the digital logic world to select a value for the slave device. One is used as the CLOCK (SCL) and the other as the DATA (SDA). The slave device here is the backlight IC and the host CPU will stream out values to light up the panel. Each I2C slave has an unique address on the I2C bus. Respectively, when you increase / decrease the backlight intensity, it is this pair of communication lines that define the LED configuration used by the LCD panel.
          Have seen cases where these I2C lines are being strapped to a logic low for other reasons which can halt this 'party' rail from working.
          Check as follows:
          Meter in DC voltage mode (20V scale should be ok).
          a) Carefully connect the red meter probe to RP842 resistor. Once you locate this part - check the voltage on BOTH sides of this 0 ohm resistor. With 0 ohms showing in the schematic - this is just a jumper so the reading should be the same on either side of RP842.
          Black meter probe to ground.
          What are the voltage readings here ?
          We need to know if the voltage is high enough to ENABLE the backlight IC.
          b) Repeat the same voltage testing for the I2C lines:
          I2C_BKLT_SCL (2) - in the attached drawing
          I2C_BKLT_SDA (3) - in the attached drawing
          What are the voltage readings for each of these 2 lines ?
          • slimmy182
            • Apr 2021
            • 119
            • italy
            Again, thank you so much for the support and for spending your time helping me and explaining all this stuff in this helpfoul and kind manner.
            1) resistance to ground of the bulk caps offer the backlight (CP860) =
            20k mode = 0.05 ohms, 2k mode = .056 ohms, 200 mode = 56.3
            Is that a short to ground?
            2) DC voltage RP842 = 0V both side
            also CP842, both pin 0V
            3) I2C_BKLT_SCL = 5.21V
            I2C_BKLT_SDA = 5.21V
            ALL measures are taken with just board alone and DC chord, no display connected or other things.
            An other interesting thing is that when I turn on the computer on external monitor without the internal display assembly, not connected at all, the mac still show internal display in the pheriperical connected (see attached). I don't know if it's due to a different managment of display for this A2337 M1 model, but the same year intel Air A2179 behavour is different: if I disconnet internal display and use only external one it does not detect anymore the internal display.
            I already tried DFU revive and restore but it doesn't help
            • mon2
              • Dec 2019
              • 14667
              Yes, this resistance @ ~56 ohms looks low for this rail.
              You may have a bad capacitor on this rail OR the issue could be inside the LCD panel itself.
              To confirm, always with all power REMOVED from the logic board - disconnect the LCD panel (if it is mated to the logic board).
              Again with no power - meter in resistance mode (2k is ok) - check the resistance to ground of CP860 (since the group are together - this is a good one to use).
              Do you still see about 56 ohms to ground resistance ?
              If yes, carefully with that great microscope of yours - zoom over each and every cap in this cluster. Look for a possible damaged / cracked / off color capacitor. If they all look to be mint, then it may be worthwhile to remove the diode @ DP800.
              Just lift up one leg on DP800 so that it does not impact the meter readings for the resistance checks. Then check again, what is the resistance @ CP860 ?
              Still ~56 ohms ?
              This is the ENABLE pin for the backlight. With 0v on this line = the backlight IC has been instructed to remain OFF.
              This voltage could be low due to the driver pin for this line or this line has a fault with too much of a load.
              Remove all power. Meter in resistance mode (2k is ok). Check the resistance to ground for this line.
              Post the reading.
              These are good values.
              • slimmy182
                • Apr 2021
                • 119
                • italy
                1) resistance to ground of CP860 56 ohms, both LCD connected or disconnected.
                Unfortunately I don't see any sing of damaged / cracked / off color capacitor in this cluster.
                I removed DP800 diode using rework hot air gun,
                resistance to ground of CP860 now is 43 ohms.
                It's stay 43 ohms even after put back DP800 diode. This could be the hot air worsening the short to ground?
                2) resistance to ground for ENABLE Backlight
                pin 1 CP842 = 1 ohms
                pin 2 CP842 = 0.00 ohms
                pin1 RP842 = 1 ohms
                pin2 RP842= 1 ohms
                1 ohms is the reading on Multimeter display in 2k mode, and it's the same results as when the probe are not touching anything, like there is no continuity
                I re-mesured a lot of times, same results.
                I attach here magnified photos of the only suspect cap I found explorating the board, but I guess they are not related to this issue, and a magnified photo of the LP670 blown camera filter
                • mon2
                  • Dec 2019
                  • 14667
                  1) Remove each of the damaged parts and test the resistance to ground again. See attached.
                  One is cracked. The other is burnt.
                  2) Post the resistance to ground of the cap cluster which looks liquid damaged.
                  3) After the above, check the resistance again on RP842. RP842 is a 0 ohm resistor / jumper. Carefully with low air pressure but with high heat, remove RP842 with tweezers. Then RP842 will be removed out of circuit.
                  Next, with RP842 off the logic board - measure the resistance to ground of both SMD pads for RP842. Which side is showing the very low resistance to ground ?
                  • slimmy182
                    • Apr 2021
                    • 119
                    • italy
                    1) removed both damaged parts, resistance to ground of CP860 group caps still being 43 ohms.
                    2) resistance to ground of the cap cluster which looks liquid damaged
                    @CR607 1.579 ohms, same on CW14A
                    3) with RP842 removed out of circuit neither pad 1 or pad 2 give me a value, still 1 on multimeter display. Only pad 2 CP842 show = 0.00 ohms
                    • mon2
                      • Dec 2019
                      • 14667
                      The '1' reading could mean that your scale for the resistance is too low.
                      Configure the meter to be the higher scale till you have a reading.
                      Post again.
                      • slimmy182
                        • Apr 2021
                        • 119
                        • italy
                        Post again.
                        Is the same thing I tought, even using all the scale same results. Sometimes, but very rarely, seems to "bumbs to 1.890" before come back to '1' when switching from pad 2 to 1, but if I stay firmly in one pad just display '1'.
                        • mon2
                          • Dec 2019
                          • 14667
                          CP842, pad # 2 = Ground in the design. So this makes sense that the meter is showing 0 ohms for the reading.
                          On your meter, the resistance on pad # 1 (CP842) = 1 ohms ??
                          What is the resistance for RP842, pad # 1 ?
                          • slimmy182
                            • Apr 2021
                            • 119
                            • italy
                            exactly, the resistance on pad # 1 (CP842) = '1' ohms
                            resistance for RP842, pad # 1 = '1' ohms
                            maybe that's could be a sort of 'OL', becouse 1' ohms it's the same measure displayed in resistance mode when probe are not touching anything!
                            I checkd also continuity mode and i've got continuity beep only in CP842 pad # 2, not in pin 2 or RP842 both pin 2 and 1
                            PS: if it's needed I own also a 820-3023 as donor boards for components
                            • mon2
                              • Dec 2019
                              • 14667
                              The measurements do not sound correct. Agree that it may be a "OL" reading.
                              If you are in resistance mode, short the meter leads and you should read close to '0.00'.
                              Confirm this and dial up a higher scale setting. Even 100k+ ohms is ok. Then check again.
                              Post a picture of your meter as well.
                              • slimmy182
                                • Apr 2021
                                • 119
                                • italy
                                Shorting the probes in resistance mode I got 0.00/0.001 ohms, same thing put probes on ground.
                                Still got this damn ‘1’ using upper scale
                                • mon2
                                  • Dec 2019
                                  • 14667
                                  Try with 20k or 200k scale.
                                  • slimmy182
                                    • Apr 2021
                                    • 119
                                    • italy
                                    Already done, it's the same
                                    now I got on pin 1 CP842 = 1.880 ohms then get solid '1' (2k mode), no reads with 20k or 200k scale.
                                    testing RP851 and RP850 i've got solid 1.920 ohms
                                    RP842 still being '1' both pads
                                    Checking the camera part when I removed damaged parts I noticed also this other two components who seems to have sings of burnt, I attached Photos
                                    • mon2
                                      • Dec 2019
                                      • 14667
                                      Leave the IC (first picture) alone. It is ok to me. But the cap does not look great. Make a note of this location and remove this part. Check if the readings change.
                                      • slimmy182
                                        • Apr 2021
                                        • 119
                                        • italy
                                        Unfortunately, no changes.. it's discouraging
                                        • ledbylight
                                          M1 A2337 Macbook - No Display, likely due to logic board
                                          by ledbylight
                                          Hi all!
                                          This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                          I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                          11-04-2024, 06:36 PM
                                        • Guest
                                          A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                          by Guest
                                          Hello all!
                                          Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                          After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                          09-26-2024, 03:31 AM
                                        • mkdj
                                          MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                          by mkdj
                                          About me, my goal and the equipment I (don't) have:
                                          I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                          About my issue and my goal:
                                          A friend of mine has a MacBook Air M1 A2337 that does not...
                                          04-03-2025, 08:28 AM
                                        • korben_dallas
                                          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                          by korben_dallas
                                          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                          MY QUESTION:
                                          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                          02-14-2024, 12:23 AM
                                        • Adogabriel100
                                          where to get trusted CD3217. Problem with A2337 Macbook Air
                                          by Adogabriel100
                                          Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                          The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                          09-06-2024, 12:06 PM
